Old 08-07-2013, 04:17 PM   #2911
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
Originally Posted by coupekid99 View Post
Anyone know what rims he was running?
desmond regamaster evo
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 08-08-2013, 08:53 PM   #2912
DirtySanchezS14
DirtySanchezS14 is an unknown quantity at this point
Question Will they fit?
Currently lookin to buy new wheels and was just wondering how the former of some 18x9 +32 would fit on the front and back of my stock body s14?
Or would +20 be better in the front or maybe even in the rear?
Somewhat, actually pretty big noob at offset and all that with wheels
First set of wheels I'm buying for my s14 actually
Thanks
DirtySanchezS14 is offline   Reply With Quote
Old 08-09-2013, 04:28 AM   #2913
itsguyguy
itsguyguy's Avatar
itsguyguy is an unknown quantity at this point
Nismo LM GT2
Front - 17x8 - 245/40/17 Nitto Invo
Rear - 17x9 - 275/40/17 Mickey Thompson Street ET
Nothing fancy or over the top, but just enough to get the job done on a street tune which feels a little over 500 to the wheels from personal experience on 16lbs/93 pump gas running a little towards the rich side.
I have 15x10 5.5BS Weld Prostar on 275/60/15 Mickey Thompson OutlawX for when the numbers are turned up over 800 to the wheels.
Running 20mm spacers front to clear brakes and 5mm spacers rear.
Let me know what you all think.
itsguyguy is offline   Reply With Quote
Old 08-09-2013, 07:00 AM   #2914
STURGauto
STURGauto's Avatar
STURGauto is an unknown quantity at this point
I like the meat on the black kouki^^^ Its not very often you see tire sticking out past the lip of the wheel here on zilvia.
STURGauto is offline   Reply With Quote
Old 08-09-2013, 09:11 AM   #2915
silviaks2nr
silviaks2nr's Avatar
Thanks
I'd do +20 front and +32 rear. You should be able to do 255/35 front and rear or 275/35 rear if you want a lot of rubber on 9's.
Old 08-09-2013, 09:22 AM   #2916
2muchboost
Trader Rating: (33)
2muchboost is an unknown quantity at this point
Feedback Score: 33 reviews
@ITS....looks great man. Only thing I would do (just my opinion) is lower the front a tad if possible.
I have 17x8.5 front (224/45) and 17x9.5 rear (275/40 MT ET Streets). Now I have an idea of how it will look. I am thinking I might want to switch fronts back to a 245/40 seeing your setup. My fronts look small as hell compared to the rears. Havent mounted them so I dont have any pix.
2muchboost is offline   Reply With Quote
Old 08-09-2013, 10:02 PM   #2917
itsguyguy
itsguyguy's Avatar
Thank you, I appreciate it man. Not very many nowadays have respect towards the originality of the S chassis. You don't need to slam your car with wide and large wheels that are in the negative offset, stretch out the tires to hell, use knock off parts and aggressive kits for your "daily drifter," which probably won't qualify at a local event.
I like to keep things simple and OEM JDM/aftermarket manufacture.
Get the 245/40 fronts, they grip extremely well in high speeds, at least for me they do. It lifts weight off my shoulders knowing I have that extra grip on the road going over 100.
As for the height, I would rather not lower her anymore than she is now. I'm working on getting a lip, a complete splitter/underbody panel/diffusers setup to help improve aerodynamics at higher speeds, and possibly switching out to the 18x8.5 245/40 LMGT4's in the front with Weld's 275/60/15 in the rear.
With these Texas roads, I'll play it safe and keep her at a reasonable height until the Texas Mile and TX2K14.
Old 08-10-2013, 08:03 AM   #2918
2muchboost
Trader Rating: (33)
Makes sense....didn't assume Texas roads were that bad. Here in NY that would surely be a proper ride height. Will def pick up some 245/40 fronts based off your suggestion....thanx
Old 08-10-2013, 10:07 AM   #2919
S14DB
AFC #1
S14DB's Avatar
That's what this thread is about. Getting more rubber on the road and making it stick.
225/275 is a 50mm difference. Anything over 30mm you will feel and affect your cornering. I would definitely go with a 245 up front.
Old 08-10-2013, 09:36 PM   #2920
2muchboost
Trader Rating: (33)
To be honest I wasn't too worried about cornering since I was planning on mostly tracking the car with an occasional street drive but since I sold my other project this will become somewhat of a daily project car.
Old 08-10-2013, 11:58 PM   #2921
itsguyguy
itsguyguy's Avatar
A couple other local 240's running some meaty setups.
RB26 Kouki with 76mm
Volk GT7
18x9 - 245/40 Nitto Invo
18x10 - 285/40 Nitto NT05R
Autech SR20DE - turbo Zenki
SSR Koenig
17x8.5 - 225/40 Nitto NeoGen (blah, horrible for grip over 110MPH)
17x9.5 - 275/40 Nitto NT05R
Old 08-11-2013, 12:02 AM   #2922
itsguyguy
itsguyguy's Avatar
SR20 3076 Zenki
Enkei RPF1
18x9 - 235/40 Bridgestone Potenza?
18x10 - 265/35 Michelin Pilot Sport SP2/3?
Old 08-11-2013, 12:24 AM   #2923
Yellow4g63
Yellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of light
Send a message via AIM to Yellow4g63
What were the offset's?
95 240sx RB20 415whp
91 Nx2000 VVL yo
Yellow4g63 is offline   Reply With Quote
Old 08-11-2013, 01:02 AM   #2924
brianphung
brianphung is an unknown quantity at this point
Mustang reps, 17x9 +26 front with 255/40R17 NT05 and 17x10.5 +27 rear with 315/35R17 NT05R
brianphung is offline   Reply With Quote
Old 08-11-2013, 11:05 AM   #2925
DJDANGER24
DJDANGER24's Avatar
Looks good. Any daytime shots of the car?
Sent from my HTC VLE_U using Tapatalk 2
DJDANGER24 is offline   Reply With Quote
Old 08-11-2013, 11:20 AM   #2926
itsguyguy
itsguyguy's Avatar
Jesus, Brian!
What kind of power are you making for tires that wide?!
Why not just go smaller wheel with more sidewall for hook?
Old 08-11-2013, 05:43 PM   #2927
newslidz
newslidz's Avatar
newslidz is an unknown quantity at this point
Send a message via AIM to newslidz
since were sneaking in with the drag cars ill get my moment in as well.
still a work in progress
temp wheels xxr 527s? 17x8.25 f&r 225/45/17s and Mickey T et streets 275/40/17
JUST A RED TOP SR
newslidz is offline   Reply With Quote
Old 08-11-2013, 11:33 PM   #2928
HighwaystarJC
HighwaystarJC is an unknown quantity at this point
is there a zenki running 255/40/17 on 17x10+18 RPF1's? i've been looking for hours and cant find the post that says what is wrong with fitting the front. This is the setup i plan on running so i'm trying to research it as much as possible
HighwaystarJC is offline   Reply With Quote
Old 08-12-2013, 12:19 AM   #2929
itsguyguy
itsguyguy's Avatar
@Highwaystar, honestly I think 10J is overkill for fronts unless you have a widebody or overfenders. I have never gone anything passed 9.5J front, usually aroound 7.5-9 depending on the purpose of the tires/wheels, whether they are for daily driving around to break in, test the car on low/high boost, or track.
IMO you should stick with 8.5-9.5 and choose a tire from there, preferably 245/255 in the 40's. 245/40 is pretty beefy itself, although you could always go taller with 245/45.
Old 08-12-2013, 02:02 AM   #2930
HighwaystarJC
Ive seen the setup on a zenki with widened front fenders and on a kouki but the question i was asking was what is it that gets in the way or what needs to be modified to run this setup.
i know its a decent setup and an aggressive fitment but i do plan on running the 255/40/17 hankook rs3's and i'll run camber in the front to fit them with the zenki front since it is narrower than the kouki front and i'll run minimal camber in the rear
the guy in this thread states he needed 13mm spacers in the front to clear coils thats a 17x10 +5 w/ 255/40/17 on stock kouki front
http://www.ka-t.org/forums/viewtopic...=asc&start=380
Old 08-14-2013, 04:44 PM   #2931
bnf
bnf is an unknown quantity at this point
17x9 +12 All round
255/40/17 Nitto NT-01 All round
bnf is offline   Reply With Quote
Old 08-15-2013, 12:45 AM   #2932
Kingbaby
Kingbaby's Avatar
Kingbaby is an unknown quantity at this point
my favorite thread on any chassis
#0191 "Lin'da" 2AMR>2AMR>
Originally Posted by Bambi View Post
That's pretty cool. Never sell it, you'll regret it.
Originally Posted by thisisastickup View Post
I donut see an FC on this page, man
Kingbaby is offline   Reply With Quote
Old 08-15-2013, 09:26 AM   #2933
Flicktitty
Flicktitty's Avatar
Took off the 255/40/17 Toyo R888's and put on a 275/40/17 Mickey Thompson ET Street. (17x9 +35)
Old 08-15-2013, 09:56 AM   #2934
2muchboost
Trader Rating: (33)
^^^Love it FLICK! Should help you out some with your traction issues. Love my MT ET Streets.
Old 08-15-2013, 12:20 PM   #2935
Flicktitty
Flicktitty's Avatar
Thanks but! feels like a whole new car! i *might* raise the back a bit more as i feel it may rub over bumps. But 10mph roll ons are pretty effortless now
Old 08-16-2013, 12:24 PM   #2936
MikeySand
MikeySand is an unknown quantity at this point
255/35/18 Bridgestone Potenza RE050A's on 18x9 +20 fronts (probably going to switch to a 40 series tire) ~2.7* camber
275/35/18 Bridgestone Potenza RE050A's on 18x10 +18 rears ~3.6* camber
With a roll and slight pull there's no rubbing either while turning or squatting.
MikeySand is offline   Reply With Quote
Old 08-18-2013, 07:35 PM   #2937
Rak123
Rak123's Avatar
Rak123 is an unknown quantity at this point
Originally Posted by itsguyguy View Post
SR20 3076 Zenki
Enkei RPF1
What off sets are you running? This is the exact setup I want to run on my zenki.
Rak123 is offline   Reply With Quote
Old 08-18-2013, 09:27 PM   #2938
Flicktitty
Flicktitty's Avatar
Figured i'd throw up a picture my buddy Jay took last night.
275/40/17 on a 17x9 +35 Rolled fenders no pull.
Old 08-19-2013, 04:58 AM   #2939
itsguyguy
itsguyguy's Avatar
@Flick
That's a sexy coupe you have there! Raise her up in the rear about .4-.6 and soften the suspension a little more for better hooking! What psi do you run when you race?
@Rak
Not exactly sure because it's not my car, but I can ask my friend when I see him again.
@bnf
Looking good!
@newslidz
What engine combo did you go with? And what type of racing, track, street, roll? Not trying to dog on you, but I wouldn't stick XXR's on anything that is making more than 400 to the wheels. They're heavy...
Old 08-19-2013, 09:33 AM   #2940
Flicktitty
Flicktitty's Avatar
@Flick
Right now the coils are set to full soft. They are HKS Hypermax coilovers. which are pretty soft out of the box which is nice. I might try and raise it up a little more but we will see as of now it works. Right now the tire pressure is at 25 psi. Seems to hook good from a small roll. Haven't tracked it yet, I'm sure i'll lower it down another 5-7psi at the track.
