Old 08-16-2013, 07:23 PM   #1
Lockiess15
Lockiess15 is an unknown quantity at this point
S15 Spec R VVL kicked in YO
Hi all, been a member of the forum for a little while now but have barely been active on the forum. As I've been building up a SR20VET for my S15 as you'll see below you in the information/pictures, I thought it was about time I start my own build topic seeing as I haven't yet!
Hope you enjoy
Standard SR20DET VS fully worked SR20VE [spec list below]
SR20VE inlet ports
SR20DET inlet ports [yes I realise they're standard]
"Baby" turbo [GTX3076R]
Skyline RB25DET gearbox with adaptor plate etc
Dummy fitting
Engine bay getting ready for paint:
Painted:
VVl kit on:
As the engine currently sitted before being mounted:
Mounted:
-----SPECS----
Head:
P11 Cylinder head
Exhaust cams 268 11.8 lift
Inlet cams 272 and 305 11.2 and 12.4 lift
2mm over size valves
larger valve seats with 3 angle grind
New exhaust valve guides
New high performance valve springs
Re-shaped combustion chamber
Race port and polish
Vernier cam wheels (dialed in for max power)
Block/other:
-Link G4 wire in ECU
-Bosch 044 fuel pumps [x2]
-ID2000cc top feed fuel injectors [x4]
-Custom polished intercooler piping
-Custom polished intake plenuim with 70mm throttle body
-Greddy fuel rail modified to mount VE head
-Tial external wastegate
-Top mount extractors
-Braided oil and water lines to turbo and back
-Full engine balance
-CP forged pistons in 86.5mm
-ACL race main and big end bearings
-Acid dipped block
-New genuine Nissan OEM jet oil squirters
-New bearings and seals throughout
Currently that's how the car is sitting at the moment from Wednesday just passed. Few little things remaining now until it gets fired up for the first time such as wiring, front mount piping etc.
Looking forward to hearing this thing start up for the first time
Lockiess15 is offline   Reply With Quote
Old 08-17-2013, 09:27 AM   #2
Phlip
Yes, I look like that
Phlip's Avatar
What blue is that?
Weirdo
And I write too!
Old 08-17-2013, 09:51 AM   #3
jr_ss
Have the trans bolted up? You could see some issues when you do with that P12 CAS. I had to remove mine in my S14 and go with the Mazworx pickup because I didn't have room between the CAS and bulkhead.
Old 08-17-2013, 01:22 PM   #4
tricky_ab
tricky_ab's Avatar
I'm down for a SR20VET build! I'll be following this one for sure...
Old 08-17-2013, 01:28 PM   #5
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Ooooh...looks like you forgot to notch the transmission tunnel. You're probably gonna have to beat the tunnel out to make space for the RB25 transmission.
CLICK HERE!!!
Old 08-17-2013, 04:58 PM   #6
Lockiess15
They've already smashed the tunnel out a little bit according to them to allow the gearbox to fit before it had been painted. As for the CAS, I'm not sure on the whole thing but they've told me they're not running it. I believe they're putting a hall effect system on it or something but whatever they do I've told it won't have a CAS on it...
It's the standard S15 blue, just been painted again as pictures show. It's not as dark in person as you see in the pictures. It's a little bit brighter when you actually see it as the pictures are taken at night time
Old 08-20-2013, 03:06 PM   #7
conrad_s13.5
conrad_s13.5's Avatar
conrad_s13.5 is making a name for him/her selfconrad_s13.5 is making a name for him/her self
Hellz yeah
makes me excite!
cONtRol FReAkS
conrad_s13.5 is offline   Reply With Quote
Old 08-23-2013, 05:27 PM   #8
Lockiess15
Little bit of a update, gearbox mated to engine now and currently being trial fitted in to the car with engine
Old 08-29-2013, 12:33 AM   #9
Lockiess15
SR porn
Old 08-29-2013, 12:58 AM   #10
jp69
jp69 is an unknown quantity at this point
Nice motor
jp69 is offline   Reply With Quote
Old 08-29-2013, 02:56 AM   #11
Lockiess15
Thankyou
Old 08-29-2013, 05:38 AM   #12
tricky_ab
tricky_ab's Avatar
Looking good! When do you think you'll have the swap completed?
Old 08-29-2013, 10:43 PM   #13
Lockiess15
On a rough guess, within a month. But probably a good two as the team are full on doing other big and small builds as well at the moment.
Old 08-29-2013, 10:51 PM   #14
GetSydWys
GetSydWys is an unknown quantity at this point
oooof! this is tooo too clean lol.. awesome build Sir !
GetSydWys is offline   Reply With Quote
Old 08-29-2013, 11:15 PM   #15
Lockiess15
Thanks man .
I know at the moment downpipe/wastegate pipe currently underway, wiring doesn't have much to go [unless I didn't understand what my tuner said properly? Lol] and intake manifold is on it's way back after final fitment tweaks
Old 08-30-2013, 10:16 AM   #16
Toomuchboost12
Toomuchboost12's Avatar
Toomuchboost12 can only hope to improve
Beautiful i love the Color . Plan on Doing this Exact Build in my S14
Toomuchboost12 is offline   Reply With Quote
Old 08-30-2013, 04:07 PM   #17
Lockiess15
Thanks man. They're definitely better motors to build from then an sr20det and the best thing going with these is that you're not adding extra weight that an RB/JZ/V8 would
Old 08-31-2013, 07:04 PM   #18
Lockiess15
Old 09-01-2013, 05:46 PM   #19
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
What is that giant box on the right with the lines coming out of it? It seems that you would have more room if you could remove it or at least relocate it. Is it for ABS brakes or something?
Old 09-01-2013, 08:06 PM   #20
jr_ss
That is the ABS controller.
Old 09-01-2013, 11:36 PM   #21
Lockiess15
As mentioned, it's the ABS unit . It's why I couldn't go with a 60mm wastegate and had to end up using a 44mm instead >_<
Old 09-02-2013, 12:56 AM   #22
Om1kron
Om1kron's Avatar
I said a goddamn!
Wayne Edwards
https://om1kron.blogspot.com
Old 09-02-2013, 10:30 AM   #23
jr_ss
Smaller wastegates control exhaust gases better. 60mm would've been completely overkill for the turbo you are running.
Old 09-02-2013, 11:55 AM   #24
tricky_ab
tricky_ab's Avatar
Are you planning to heat treat that downpipe?
Old 09-02-2013, 12:04 PM   #25
Jack Bauer S14
Jack Bauer S14's Avatar
Jack Bauer S14 is an unknown quantity at this point
Damn this is pretty good man!! From which car did the engine came from?
Sent from my XT910 using Tapatalk 2
Jack Bauer S14 is offline   Reply With Quote
Old 09-02-2013, 06:48 PM   #26
Lockiess15
They thought it might boost creep just a tiny bit which is why they were going to run a 60mm to start with it, but that's a might. Downpipe is going to be heat wrapped and so goes for any rubber hoses that's next to anything hot. They're also either heat wrapping the abs or putting a heat shield around it.
Head is out of a P11 Primera and the block is just the S15 sr20det block
Old 09-02-2013, 07:02 PM   #27
jr_ss
You're running factory cams right?
Old 09-02-2013, 08:02 PM   #28
Rico180
Rico180 is an unknown quantity at this point
Where did you buy that kit to do the vet conversion??? I love the way your doing with the build.
Rico180 is offline   Reply With Quote
Old 09-02-2013, 11:54 PM   #29
Lockiess15
Custom cams. I believe the relocation block is a mazworx item and then how they've bolted the solenoids on the side there is completely custom
Old 09-03-2013, 01:51 AM   #30
Lockiess15
Not a huge update, but other parts to my exhaust/wastegate piping:
