Old 08-31-2013, 12:27 AM   #1
Shifty671
Shifty671's Avatar
Trader Rating: (51)
Shifty671 is on the path to ruinShifty671 is on the path to ruin
Feedback Score: 51 reviews
Odometer and speedo not working.
Like the title says I have been having this issue. I recently drop my tranny to replace my release bearing and pilot bushing. After putting it together I noticed my speedo stop working. Then a couple days want by and I noticed my miles stayed the same. I am sure I hooked up all the sensors correctly. Can somebody give me some insight or point in the right direction? I been reading around but can't find any solutions.
Thank you.
Shifty671 is offline   Reply With Quote
Old 08-31-2013, 08:55 AM   #2
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Definitely sounds like the speed sensor is disconnected in some way shape or form.
Old 08-31-2013, 09:52 AM   #3
240dream
240dream's Avatar
240dream is an unknown quantity at this point
Speed sensor unhooked will cause this just happened to me I got under the car unplugged and replugged in and all is good now
All I read was "I'm a little bitch and don't belong in this thread".
240dream is offline   Reply With Quote
Old 08-31-2013, 06:37 PM   #4
zerodameaon
zerodameaon's Avatar
zerodameaon is an unknown quantity at this point
or the gear got stripped or otherwise broken.
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
Old 08-31-2013, 08:13 PM   #5
Shifty671
Shifty671's Avatar
Trader Rating: (51)
What gear would that be?
Old 08-31-2013, 09:04 PM   #6
zerodameaon
The one on the end of the speedo sensor. It is just a plastic gear and they can sometimes fail.
Old 08-31-2013, 09:08 PM   #7
Shifty671
Shifty671's Avatar
Trader Rating: (51)
R u talking about the one in the gauge? I'm gonna under the car tomorrow and double check the sensors. Maybe I missed something.
Old 08-31-2013, 09:35 PM   #8
KevinEdgar
KevinEdgar's Avatar
KevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to all
Plastic gear he is talking about sits inside the transmission which is the sensor. Check your speed sensor wiring, you may have accidentally cut one of the 2 wires when removing/installing.
http://milktea-man.com
KevinEdgar is offline   Reply With Quote
Old 08-31-2013, 10:06 PM   #9
Shifty671
Shifty671's Avatar
Trader Rating: (51)
Gotcha. I will double check that. Thanks.
Old 09-01-2013, 11:17 AM   #10
Mikester
Mikester's Avatar
If that doesn't work, try switching the VSS polarity (reverse the two wires)... It's a polar signal (phased AC) and could be 180* off.
Old 09-03-2013, 06:35 PM   #11
KoukiMonsta
KoukiMonsta's Avatar
KoukiMonsta is a well-known jackass
Mike, I verified polarity does not matter when tracing down my speedo issues. (Friendly FYI..since u def helped me to get it solved)
OP - I went through 2 clusters with bad speedos. What a pain..finally a third and it all works.
But then it went out AGAIN! I bent the prongs on the clip where it goes into cluster rear and bam. We are good.
But I feel you disconnected it while pulling tranny.
KoukiMonsta is offline   Reply With Quote
