Old 09-02-2013, 12:02 PM   #1
NJ3ndri
NJ3ndri is an unknown quantity at this point
NEW 340lph pump + more
Most items are for ka24de
NEW _______SOLDDDDD Circuit Sport 340lph fuel pump (s14 fitment kit) $70.00
USED 01 Maxima vq30dek injectors. 6x make offer
USED s13 cylinder head ka24de $100.00
NEW s13 ka24de gasket set $40.00
USED s14 ka24de injectors $30.00
USED aprox 120 miles mishimoto racing thermostat $30.00 (lifetime warranty)
NEW OBD1 Nissan Consult cables and program $60.00
USED 15LB Boost gauge (maximum performance) $15.00
USED (painted) s14 Valve covers (2x) $70.00
USED (painted) s13 Valve cover $30.00
USED ka24de Oil Pan with oil return fitting welded on $60.00
USED s14 & s13 front lower timing cover $20.00 each
USED ka24de stock rods (4x) $50.00
USED ka24de pistons (3) make offer
NEW s14 ka24de distributor $110.00
USED s14 ka24de distributor $70.00
USED s13 distributor $50.00
USED NGK spark plug wires $30.00
USED _______SOLDDDDD z32 maf + pigtail $50.00
USED maxima maf $30.00
USED t25 turbo elbow $25.00
NEW _______SOLDDDDDCometic exhaust gasket steel $25.00
New _______SOLDDDDDCircuit sport intake gasket/spacer/heat reducer $25.00
NEW _______SOLDDDDDCometic stock bore gasket $80.00
NEW _______SOLDDDDDOEM KA24DE Front Timing cover (modified oil pump for higher pressure) $320.00
USED s14 painted upper timing cover $30.00
USED s13 upper timing cover $25.00
USED brian crower 272 cams + highrev valvetrain $600.00
NEW Brian Crower oversized valves intake+exhaust $250.00
NEW OEM ka24de Coolant plugs for block (set). $20.00
NEW OEM oil dipstick guide tube $15.00
NEW/USED OEM Crank balanced
Prices are negotiable. please text 2014038547 for more details and pics. I have other stuff also
NJ3ndri is offline   Reply With Quote
Old 09-02-2013, 02:51 PM   #2
NJ3ndri
bumppppppp
Old 09-04-2013, 12:34 PM   #3
NJ3ndri
Bumpp I need them gone lol
Old 09-05-2013, 08:01 AM   #4
NJ3ndri
To the top lots of stu ff here
Old 09-06-2013, 05:42 PM   #5
NJ3ndri
bump bump bump bump
Old 09-08-2013, 10:41 PM   #6
NJ3ndri
bump bump bump bump
Old 09-12-2013, 05:42 PM   #7
NJ3ndri
bump bump bump bump UPDATED
Old 09-13-2013, 05:33 PM   #8
NJ3ndri
Old 09-14-2013, 06:50 AM   #9
NJ3ndri
Old 09-18-2013, 10:17 PM   #10
NJ3ndri
Old 09-20-2013, 10:03 AM   #11
NJ3ndri
Bump parts still available
Old 09-21-2013, 09:01 AM   #12
NJ3ndri
bump bump bump bump
