Old 09-21-2013, 11:38 AM   #1
Jfornachon
Jfornachon is an unknown quantity at this point
S14 sr20det koni greddy aem z32 brakes 300zx turbo garrett
Please read listing for updates. Prices are listed so please don't ask what I want for them. You can make a reasonable offer though. If it is not listed then I don't have it however I may find more parts later down the line. Please text/call me on my cell at 3one074077one6. These prices are NOT shipped unless we work a deal.
Engine parts:
$3600 S14 sr20det NA ecu, Wiring solutions Upper and Lower harness for s14 NA ECU into s13 chassis, ACT streetlight flywheel, and stage 1 clutch, Nismo thermostat, Circuit sports engine pullys, alt and ps pump, 8mo old water pump and Nismo thermostat, factory NA ecu, igniter, maf and FR sport inline fuel pressure gauge, S15 turbo Garrett (very lightly used maybe 1k miles if that much) W/SS lines(new). It will need to be reclocked. I will explain if interested) has not been installed on to motor, 97 g20 throttle body.
$400 Factory gasket kit minus v/c gasket NEW, Factory timing chain kit NEW, Factory Oil pump NEW
Suspension Parts:
$60 Circuit sports tension rods.
Electronic parts:
$1750 Aem 30-6600 standalone with patch harness pre wired with AEM map, o2, iat, Factory clutch switch (W/sensors and gauges) and MAC EBC not wired in yet.
Exhaust Parts
$100 greddy down pipe. Has scratches and a slight dent. Its small so I cant imagine that it really affects performance much if at all and Megan 3in test pipe
$60 New ps rack in the last year with new outer tie rods lines and resavor
$100 Greddy turbo outlet pipe/ o2 housing NEW
Brake Parts
$300 300xz brakes front calipers DIF SS lines and rotors. Iron calipers.
$300 300zx brakes Rear dif ss lines (w/parking brake cables, backing plates, and components included) Aluminum calipers.
Drivetrain Parts:
$300 Ichiba Hubs FT and RR w/extended arp speed tip studs 20 19mm aluminum lug nuts, extra spare studs.
$600 S15 Torsen HLSD with flanges. New side bearing were installed when installed into my car. About 5k on the bearings. Also comes with new pinion seal and new bearing.
Interior Parts:
$40 duel gauge pod mounted on steering column clam shell. Comes with upper and lower parts of clam shell.
$20 Sun visor aftermarket
$50 Autometer 3 gauge a pillar pod
$40 Both manual window regulators with cranks
Jared
Last edited by Jfornachon; 01-20-2014 at 01:00 AM.. Reason: Removed sold items and added one as well.
Jfornachon is offline   Reply With Quote
Old 10-12-2013, 08:31 AM   #2
jtimcort
jtimcort is an unknown quantity at this point
is the dif fan controller still available? if so which model is it?
jtimcort is offline   Reply With Quote
Old 10-18-2013, 03:51 PM   #3
Jfornachon
Yes, it is. I don't know the exact model it is. I just know it operated both fans independently. Sorry for the late reply. I didn't get a notification. I have changed my settings. LMK.
Have a great day,
Jared
Old 10-18-2013, 03:52 PM   #4
Jfornachon
I have lowered my prices.
Have a great day,
Jared
Old 10-18-2013, 03:53 PM   #5
lilbnort93
lilbnort93 is an unknown quantity at this point
damn im having trouble selling a complete s14 sr swap that's fully built for 3500 lol
lilbnort93 is offline   Reply With Quote
Old 10-18-2013, 08:29 PM   #6
208s14.5
208s14.5 is an unknown quantity at this point
willing to sell just the conversion lines for the z32 brakes? i can pick up.
208s14.5 is offline   Reply With Quote
Old 10-19-2013, 09:45 AM   #7
jtimcort
I'll definitely take the fan controller off your hands. do you happen to have any install instructions? If not I am sure I can find them somewhere. Thank you.
Old 10-22-2013, 10:42 AM   #8
Jfornachon
You can find them online.
Have a great day,
Jared
Old 11-30-2013, 03:56 PM   #9
Jfornachon
konis sold thank you.
Have a great day,
Jared
Old 12-01-2013, 03:43 PM   #10
CaliforniaMayhem
CaliforniaMayhem's Avatar
CaliforniaMayhem is an unknown quantity at this point
Jared, are these aluminum or iron calipers? Also do you have the complete ebrake assembly with shroud?
Sent from my XT907 using Tapatalk
CaliforniaMayhem is offline   Reply With Quote
Old 12-02-2013, 01:59 AM   #11
Jfornachon
I am going to assume that you are only referring to the rears. I think they are iron but I will have to check before I can give you a accurate answer. Yes the ebrake assembly is complete.
Have a great day,
Jared
Old 12-02-2013, 03:44 PM   #12
Jfornachon
They are aluminum calipers.
Have a great day,
Jared
Old 12-02-2013, 03:45 PM   #13
Jfornachon
Sold parts went out today. Thank you. Also updated caliper info.
Have a great day,
Jared
Old 12-10-2013, 01:37 PM   #14
Jfornachon
UPDATED. Adjusted prices.
I will be driving from boise Id. to San Francisco to Los Angeles for Christmas and New Years. I can bring parts with me with a non refundable deposit. Let me know as I have to dig parts out of storage.
Have a great day,
Jared
Old 12-19-2013, 04:23 PM   #15
Jfornachon
I will be leaving on Monday to head towards San Francisco. If you want parts let me know ASAP so I can dig them out of storage.
Have a great day,
Jared
Old 12-30-2013, 12:20 PM   #16
Jfornachon
Adjusted prices.
Have a great day,
Jared
Old 01-06-2014, 01:22 PM   #17
Jfornachon
Updated listing.
Have a great day,
Jared
Old 01-20-2014, 01:01 AM   #18
Jfornachon
Removed sold items and added S15 diff.
Have a great day,
Jared
Old 01-23-2014, 09:03 AM   #19
looneys14
looneys14 is an unknown quantity at this point
Need the 300z parking breaks how much??
looneys14 is offline   Reply With Quote
Old 02-02-2014, 02:40 PM   #20
nextproject
nextproject is an unknown quantity at this point
PM sent on the S15 HLSD.
nextproject is offline   Reply With Quote
Old 02-03-2014, 09:33 AM   #21
Backintoans13
Backintoans13's Avatar
Backintoans13 is an unknown quantity at this point
What all would be needed to install the s15 diff on an s13??
Backintoans13 is offline   Reply With Quote
Old 02-03-2014, 07:00 PM   #22
Jfornachon
If you have a diff in your car then you have every thing that is needed. You remove your diff and install thins one. Then reinstall it into your car. Do a search on it. It is very easy if you know how to work on cars.
Have a great day,
Jared
Old 04-13-2014, 10:16 AM   #23
Jfornachon
All parts are still for sale.
Have a great day,
Jared
Old 06-16-2014, 10:26 AM   #24
Jfornachon
Parts still for sale.
Have a great day,
Jared
Old 06-16-2014, 07:44 PM   #25
wslugantz
wslugantz's Avatar
wslugantz is an unknown quantity at this point
I would be interested in the s15 diff just let me know what your thinking on it
wslugantz is offline   Reply With Quote
Old 06-17-2014, 07:45 AM   #26
Jfornachon
It is out of the housing. It will come with the flanges and a new pinion seal and bearing. I am off tomorrow so I can take it to get a shipping quote. Lmk.
Have a great day,
Jared
Old 06-17-2014, 04:07 PM   #27
wslugantz
wslugantz's Avatar
Ok sounds good, just let me know
Old 06-17-2014, 05:48 PM   #28
Jfornachon
I need you sexy in order to get a price.
Have a great day,
Jared
Old 06-18-2014, 04:11 PM   #29
wslugantz
wslugantz's Avatar
1059 s broadway
Lexington ky 40504
Old 06-18-2014, 05:07 PM   #30
wslugantz
wslugantz's Avatar
Have a great day,
Jared
I'm confused, don't know what your talking about
