Old 03-04-2013, 03:40 PM   #31
Danial
Danial is an unknown quantity at this point
Any word on this?
Danial is offline   Reply With Quote
Old 03-05-2013, 11:26 AM   #32
PLAYERO_LOKO
PLAYERO_LOKO is an unknown quantity at this point
very nice build bro... nice!
PLAYERO_LOKO is offline   Reply With Quote
Old 09-25-2013, 04:23 PM   #33
BryanR00
BryanR00's Avatar
BryanR00 is an unknown quantity at this point
Any updates on this?
S13 Coupe > All
BryanR00 is offline   Reply With Quote
Old 09-26-2013, 11:46 PM   #34
hobbdebub
hobbdebub is an unknown quantity at this point
Plate is currently at the machine shop getting fixed up. I had it trimmed down and added dowels for the transmission. Depending on how many are made at once it will be anywhere between $350-450 for the plate. Waiting to hear back from a few places on manufacturing flywheels so a spacer isn't needed.
First time in months I've thought to do anything with the car. Opening a kitchen required 1000x more effort than I had planned.
hobbdebub is offline   Reply With Quote
Old 09-27-2013, 01:49 AM   #35
az_240
az_240's Avatar
Trader Rating: (41)
az_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really niceaz_240 is just really nice
Feedback Score: 41 reviews
Send a message via AIM to az_240
^Looking forward to this.... I'm sure mounting a z33 trans wouldn't be much different.
az_240 is offline   Reply With Quote
Old 09-27-2013, 01:51 PM   #36
hobbdebub
I've been looking into doing that as well. The main issue I see is the starter placement w/ the Z33 trans and how much the linkage and bracket will need to be cut.
with the Z32 trans it was as easy as getting the linkage and bracket from Xcessive for a sr/z32 setup and hammering a larger pocket into the body
Old 11-20-2013, 03:47 PM   #37
maverickmotorsports
maverickmotorsports is an unknown quantity at this point
Z33 bellhousing won't fit over the LS clutch.
You'd have to go with some sort of smaller clutch with a smaller ring gear. Then you'd also have to go with a starter setup that would work(if it would even work).
In the end it would probably be cheaper to go with a T56.
The Z32 trans is easier because the starter is on the trans side so you can get away with some of the clutch shenanigans needed.
-George Marstanovic
Sr to VQ transmission adapter, dual caliper brackets, high angle tensions rods, and more!
http://www.maverick-motorsports.com/collections/all
maverickmotorsports is offline   Reply With Quote
Old 02-02-2014, 05:11 PM   #38
jfcalisse
jfcalisse is an unknown quantity at this point
Originally Posted by StockSC300 View Post
Yo, I can build an adapter plate if you guys want this... here is a picture of the design in the computer..
Let me know.. I could probably do the Flywheel spacer too if you guys want this sort of thing..
Does anyone know if we can buy this adapter kit???
jfcalisse is offline   Reply With Quote
Old 02-02-2014, 05:20 PM   #39
Duker
Duker is an unknown quantity at this point
Loji innovations make that adapter. Along with a complete z32 ls swap kit using the Z32 tranny.
Duker is offline   Reply With Quote
Old 02-02-2014, 05:45 PM   #40
jfcalisse
thanks a lot, its kind of expensive.... it looks really good, but its expensive.
Does somebody else sells a kit with only adapter plate and flywheel spacer?
Old 02-28-2015, 05:52 PM   #41
Vetal
Vetal is an unknown quantity at this point
I've always wondered, when doing adapter plates or just welding piece of one bellhousing onto another tranny bellhousing, how do you guarantee that the trans shaft is perfectly centered in the crank pilot bushing?
12.0@121mph 2.0 60ft, CA18 S13
Evo3 16G,XSPower ex mani, Nistune 950cc E85
Vetal is offline   Reply With Quote
Old 04-12-2019, 07:08 PM   #42
r man
r man is an unknown quantity at this point
Wait! Time out - how did you mount up the TT Trans to the LQ4?
What flywheel/Clutch did you use? Custom adaptor?
Cost?
I'm putting a LM7 into a '79 Z28 with a 4L80, the only reason I didn't go manual was the lack of an inexpensive trans.
did you get this done? meaning did you connect the tt trans to a lm7?
r man is offline   Reply With Quote
Old 04-17-2019, 10:17 AM   #43
S14Serge
S14Serge's Avatar
S14Serge is an unknown quantity at this point
Dam this is pretty sick using the Z32 transmission! Great setup!
S14Serge is offline   Reply With Quote
