Old 10-27-2013, 12:10 PM   #1
s13kicker
s13kicker is an unknown quantity at this point
SR 400hp sr20 swap $2800 OBO
located in georgia
400 hp sr20det turn key swap 2800 OBO with options
500 miles on the motor 1500 miles on the accessories everything was purchased brand new
all machine work done by twister engines/ GRIMES machine shop
the gt35 setup was installed needs to be tuned. The motor had a gt2871r on it before
bottom end:
hot tanked
decked
honed
brand new oem pistons
brand new piston rings.
eagle rods
acl race bearings.
brand new nissan oem oil pump
s15 oil pick up
arp mains.
apexi head gasket 1.8 mm
new timing chain
new timing chain guide and tensioner.
new nissan oem watter pump.
head:
ported head.
new tomei rocker arm stoppers.
new oem valver cover gasket.
new circuit sports thermal intake manifold gasket.
new s15 7 layer exhaust gasket.
new isis intake manifold.
550cc injectors
real turbo xs RFL blow off valve.
emusa top mount turbo manifold.
emusa 17 pound waste gate.
cx racing GT35-2 dual ball bearing turbo
stainless steel lines for turbo only oil cooled
earl fittings
s15 waterneck with looped coolant line to block
accesories:
chase bays power steering kit for s13
circuit sport oil filter relocation kit
safc neo wired in already
heat is deleted
no ac
new clutch fan
new shroud
z32 maf blow through
emusa intercooler.
cxracing radiator
custom piping
samco lime green hoses
1000 degree catch can lines
cusco catch can
general
Bkr7e spark plugs
50/50 vp114 race gas and 93 octane mix always used
stri oil pressure gauge and harness
stri coolant temp gauge and harness
hks intake
404-401-7854
s13kicker is offline   Reply With Quote
sr20 240 s13 sr20det
