Old 11-04-2013, 05:23 PM   #1
maxwagner
maxwagner is an unknown quantity at this point
SR cp pistons in sr20det, oiler clearance
I was trying to put in cp 86.5mm 8.5:1 compression pistons and I noticed on the oem piston that it had kind of like a cut out specifically for the oiler.
So I put the piston down into the cylinder and spun the crank to its lowest point and the oiler didn't hit it but it was extremely close.
does anyone know the clearance from the piston to the oiler?
has anyone grinded the pistons down in that area, to get a little more clearance?
kind of a weird question, I just don't want a oiler breaking off for such a simple fix.
maxwagner is offline   Reply With Quote
Old 11-04-2013, 06:10 PM   #2
pete240
pete240 is making a name for him/her selfpete240 is making a name for him/her self
That's the same problem with the mahle pistons I ordered. They recommended grinding the locator nub on the squirter and clocking it so it clears the skirt.
pete240 is offline   Reply With Quote
Old 11-04-2013, 06:35 PM   #3
jr_ss
You'll be fine... You can't hyper extend or rotate the crank and have the piston travel further down the cylinder unless you blow a rod through the block. In that case oiler clearance is the least of your issues.
Old 11-04-2013, 06:49 PM   #4
Def
I thought CPs had a small notch for the piston oil squirter? Or am I imagining things?
DEFSPORT
Old 11-04-2013, 07:56 PM   #5
jr_ss
As far as I know, they do. He is worried about the close proximity it comes to when at BDC.
Old 11-04-2013, 08:02 PM   #6
rotation3x
rotation3x's Avatar
rotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choicesrotation3x has made poor choices
Send a message via AIM to rotation3x
installed cp 9:1 86mm pistons in my sr and have no problems with the oil squirters clearing piston skirt they are closer than oem pistons
rotation3x is offline   Reply With Quote
Old 11-07-2013, 11:16 AM   #7
KoukiMonsta
KoukiMonsta's Avatar
KoukiMonsta is a well-known jackass
you will be fine, i run a similar setup
KoukiMonsta is offline   Reply With Quote
