Old 09-04-2004, 10:44 AM   #1
tastyratz
tastyratz's Avatar
tastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to behold
Send a message via AIM to tastyratz
clunking brakes?
ok so ive been driving on the highway and noticed steering wheel shake alot. its very intermittent cuz sometimes i brake and its fine but sometimes my wheel moves up to an inch and its kinda scary like a wheels gonna fall off or something. the thing ive really been noticing however is when i engage the brakes (you can hear it more going slower) my car makes a loud clunking sound from the front end. like im not talking low im talking loud and it sounds like something is really smacking hard, almost like im taking a lead p ipe and hitting my brakes with it. it also makes the same sound when i disengage the breaks however. if i engage and disengage but move my foot faster it gets louder. the car was pulling slightly to the left earlier but its not now and if i slam on the brakes it stays straight all the way to stop and brakes fine. id had a feeling that maybe one of my brake pads feel off but i dunno it dont really seem to make sense, if a pad fell off id hear grinding against the rotor and have a significant pull. the sound scares me enough to not drive my car however and im gonna take apart my brakes today but i wanted to know if you guys had any ideas...
tastyratz is offline   Reply With Quote
Old 09-04-2004, 10:59 AM   #2
s0ldats
s0ldats is on the path to ruins0ldats is on the path to ruin
check your t/c rods and rear subframe bushings. also, diff mounts. (but not usually the case)
does your car clunk on jerky acceleration too?
s0ldats is offline   Reply With Quote
Old 09-04-2004, 11:02 AM   #3
tastyratz
tastyratz's Avatar
no it doesnt. i have pillowball tc rods but one of the bolts holding it in is slightly smaller than the bolt is supposed to be, do you think that could be it? unfortuanately this car is an auto for right now :-( so it even does it when im coming from a stop and let off the brakes hard, the thing is its not like im really moving much or jerking or anything
edit: i forgot to mention ive been driving on that same bolt for almost a month now id say in lately is when it started really acting up.
Old 09-04-2004, 11:41 AM   #4
papershot
papershot's Avatar
papershot is an unknown quantity at this point
Send a message via ICQ to papershot Send a message via MSN to papershot
check to see if your rotors are warped.
you might want to get the correct bolt too..
papershot is offline   Reply With Quote
Old 09-04-2004, 11:42 AM   #5
tastyratz
tastyratz's Avatar
one of them is slightly warped but not enough to cause something like this! its pretty bad...
Old 09-04-2004, 04:15 PM   #6
_JDMU
_JDMU is an unknown quantity at this point
Check to see if the caliper bolt is broken. I had a simalar problem and it was the caliper bolt.
_JDMU is offline   Reply With Quote
Old 09-05-2004, 12:21 AM   #7
thx247
thx247 is an unknown quantity at this point
Sliding pin on caliper stuck? Wrong size bolt on the TC rod could lead to interesting tire wear and braking performance...
Finally down to 1 car again. Thank god.
thx247 is offline   Reply With Quote
