Old 11-15-2013, 09:51 PM   #1
alwyzDTF
alwyzDTF's Avatar
alwyzDTF is an unknown quantity at this point
SR Swirl Pot leaking. PLEASE Help.
I have a question for you guys.
I got the Greddy swirl pot and I'm running the Greddy cap it came with (1.3kpg). When I fill up my radiator with what I believe to be the right level of coolant and turn the car on, coolant starts pouring out of the bottom hose of the Greddy swirl pot. So, I tightened the hose clamp down a little more and put grey RTV on it and it still leaks when the cars running...When its off the leaking slowly stops.
I'm thinking I might need a new cap that opens under less pressure so the coolant can go to my catch can instead of being rejected and forced out the bottom hose of the greddy can (swirl pot). My catch can for the swirl pot has barely ANY coolant in it so instead of coolant overflowing from the swirl pot into the catch can next to it, its deciding to force its self out of the bottom port on my greddy swirl pot unit.
Swirl cap opens at 1.3
Radiator cap opens at .9 (pretty sure, have to double check)
Then I thought I could switch the two caps but thought the same thing might happen to the radiator and possibly start blowing coolant out of other weird places.
Can I switch the (.9kpg) radiator cap with the (1.3kpg) swirl pot cap? or should I get a cap for the swirl pot that doesnt open under any pressure. basically a radiator cap that doesnt require any pressure to pop open.
alwyzDTF is offline   Reply With Quote
Old 11-16-2013, 01:40 PM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Umm...you're not supposed to have a radiator cap on the radiator if you're running a swirl pot. That cap is supposed to be a pass thru with no pressure. Only pressurized cap you have should only be on the swirl pot.
But if its leaking under the pot when it pressurizes, you have a bad swirl pot. You got 2 options, buy another pot or get the leaky one welded closed.
CLICK HERE!!!
Old 11-18-2013, 09:44 AM   #3
sleepyS14se
sleepyS14se's Avatar
sleepyS14se is an unknown quantity at this point
what cap goes on the radiator when using a swirl pot.
95 S14 se RB25DET 348whp
sleepyS14se is offline   Reply With Quote
Old 11-18-2013, 09:54 AM   #4
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
Greddy includes a "Blank" cap with no spring.
Also, OP you should be filling the system via the swirl pot not the radiator, and the swirl pot should be the highest point in the system.
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 11-18-2013, 11:13 AM   #5
shogun!
shogun!'s Avatar
shogun! is on a distinguished road
My +700hp RS13
shogun! is offline   Reply With Quote
Old 11-19-2013, 09:26 AM   #6
alwyzDTF
alwyzDTF's Avatar
Thanks man! that was all I needed to hear. Its only leaking out of the bottom of the swirl pot because I have the 1.3kpg cap on there.
I got all that figured out already, I was mainly seeing if it was possible to use the 1.3kpg greddy cap my greddy siwlr pot came with, but I got it all figured out now. I appreciate everything buddy!
So, non pressurized cap on the radiator and move the .9 kpg radiator cap to the swirl pot and I should be good. Thanks again guys.
Old 11-26-2013, 07:44 PM   #7
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
mr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond reputemr.nismo. has a reputation beyond repute
Feedback Score: 31 reviews
You need to use the 1.3 bar cap. It comes with it for a reason. Let me elaborate. Forget the swirl pot lets just look at stock system. The pressurized cap needs to be at the highest point in the cooling system, otherwise air will not bleed out correctly. Now. Say you have a .9 bar cap on. That does not mean the WHOLE system will be at .9 bar. The farthest part of the cooling system will have least amount of pressure. So say at the cap it's .9 it could be .6 somewhere else in the block. Now let's add the swirl pot. Yes it constantly bleeds the system. However it's useless if it's not the highest point. So make sure it is. Second, your adding "distance" to the cooling system. So now instead of the farthest point being .6 it's not .4 (again I'm just throwing number). So they give you a higher pressure cap to compensate for it. Now that that's clear, if your running a .9 bar cap and are just driving normal I doubt itl really be an issue, however it WILL cause your coolant to boil when abusing it. As for your leak, fix it. Don't use rtv. Either weld or use jb weld if you have to or get another pot. If a metal tank that's supposed to be sealed cannot handle 1.3 bar thats an issue. I'd fix that ASAP
mr.nismo. is offline   Reply With Quote
Old 11-26-2013, 08:00 PM   #8
Hashiriya415
Hashiriya415's Avatar
Trader Rating: (22)
Hashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enoughHashiriya415 will become famous soon enough
Feedback Score: 22 reviews
I always pressure test cooling systems to 20psi.
If your leaking at 1.3 bar = about 18psi, that is no good. Putting a lower cap on and if it doesn't leak now, your just assuming everything is fine. It's not. Sooner or later it will start leaking at lower pressure.
Hashiriya415 is offline   Reply With Quote
Old 11-30-2013, 04:24 PM   #9
alwyzDTF
alwyzDTF's Avatar
The pot isnt leaking. the pot is 100% fine. I was running the 1.3 cap on the swirl pot and there wasnt enough pressure in the system to po pthe cap open and coolant would leak out of the hose only when the motors running.
So youre saying put my non pressurized cap on my radiator (which it is now that I bought one) and run the 1.3kpg cap on my swirl pot, correct?
Old 12-17-2013, 02:21 PM   #10
EvoVIII808
EvoVIII808 is an unknown quantity at this point
Send a message via AIM to EvoVIII808 Send a message via Yahoo to EvoVIII808
^^^^ Yup Yup.
Check Out My S13 Build
EvoVIII808 is offline   Reply With Quote
Old 12-17-2013, 02:29 PM   #11
sleepyS14se
can't believe this thread is still going lol
Old 12-17-2013, 09:06 PM   #12
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
so if the pot isnt leaking then the hose is? im not following you anymore
Old 12-17-2013, 09:34 PM   #13
alwyzDTF
alwyzDTF's Avatar
so if the pot isn't leaking then the hose is? im not following you anymore
The hose that connects to the bottom of the pot. coolant was coming out of the hose even though it was clamped because I was running a 1.3kpg cap on my radiator instead of a non pressurized cap. Its running the correct way now and it isn't leaking anymore.
Old 12-17-2013, 11:35 PM   #14
mr.nismo.
mr.nismo.'s Avatar
Trader Rating: (31)
gotcha msglength
coolant, cooling, sr20det, swirl pot
