Old 12-12-2013, 06:46 PM   #1
YesImLDS
YesImLDS is an unknown quantity at this point
KA KA24DE base timing correct?
I just want some feedback to make sure this is the way it is suppose to be on before fine tuning with a timing light. I want to rule out this as a reason for my possible no start.
Cam lobes faces fenders
Crank pulley showing TDC
Distributor on number 1
I just want to make sure I am on the dot on this one and it should technically start.
YesImLDS is offline   Reply With Quote
Old 12-12-2013, 08:36 PM   #2
hatchtastic
hatchtastic is an unknown quantity at this point
It's hard to tell from the pic but it looks like you might be a tooth off on the dizzy. It should be rotated counterclockwise slightly more. And its very hard to tell if your cams are correct. They should both be opposite from each other and pointed straight out towards fenders.
hatchtastic is offline   Reply With Quote
Old 12-12-2013, 08:41 PM   #3
YesImLDS
I haven't tried to start it yet so I'll pull it and adjust and come back with another photo. I have been having troubles with this thing for a few days and just want to make sure it will at least start up so I can move it. Be right back
Old 12-12-2013, 08:41 PM   #4
JBPUSA
JBPUSA is an unknown quantity at this point
To check mechanical timing. Remove valve cover. Just because the lobe is facing the fender doesnt mean its correct. You have to look at both cams. The links and the distributor marks and crank marks. If all correct. Will fire right up and u can check it with a timing light. Repost pics if possible with cover off
JBPUSA is offline   Reply With Quote
Old 12-12-2013, 08:51 PM   #5
YesImLDS
I did a 248/248 cam swap and it is set at TDC from when I did the swap. I just wanted to make sure that the cams showed that I was in the compression cycle. It's late and if it doesn't fire up tonight I'll open her up tomorrow as it is dark and rather cold out right now.
Old 12-12-2013, 08:52 PM   #6
YesImLDS
Are you saying more so like this?
Old 12-12-2013, 08:59 PM   #7
hatchtastic
Do not try and start before you do a complete cycle by hand to make sure that there are no interferences!!!
Old 12-12-2013, 09:13 PM   #8
YesImLDS
Good point. Everything seems free, but will it start is my question? It fired up before hand hopefully it will now!
Old 12-12-2013, 09:34 PM   #9
YesImLDS
Well I have a bad injector and the cold as a combination just doesn't want it to start up. Guess I'll have to wait until I get that injector before another try.
Old 12-13-2013, 08:03 AM   #10
YesImLDS
Started right up this morning! Thanks for the help guys I appreciate it
Old 12-13-2013, 08:10 AM   #11
davirene
davirene's Avatar
davirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nicedavirene is just really nice
Well great it started.....can you keep us posted on your hot cam swap? Have you done this swap before??
I am almost done rebuilding my motor but being a budget I am considering this same swap...
Thanks
wanted:filter relocation, front Coilover, Brake, Rims,seats,quick release
davirene is offline   Reply With Quote
Old 12-13-2013, 01:35 PM   #12
YesImLDS
Thanks
I hadn't even touched the inside of the motor or seen it before I already had the cam. I bought it off a guy here. I went off the fsm and a jim wolf technology guide on how to change cams. I needed a valve cover gasket due to a small oil leak and decided to do it then. It wasn't difficult just getting the chain back on was hard. That's why I had problems with timing because I had never done it before. It was about $30 for the cam and not hard at all to do. Take one out put the other back in the same way. Pm me if you need any help.
Old 12-22-2013, 10:04 PM   #13
shift_down
shift_down is an unknown quantity at this point
Its not about where the rotor is pointing as much as it is about the marks on the dizzy lining up.
Glad you got it sorted out.
Ka24 t3/t04b + Z32MAF + 550 subys + Walbro 255 + enthalpy Tune + 91 octane
shift_down is offline   Reply With Quote
