Old 12-14-2013, 08:13 AM   #1
dallasb53
dallasb53 is an unknown quantity at this point
lock actuator
so my passenger door lock actuator is messed up, i cant even unlock the door by pulling up on the lock mechanism inside the door.
its basically welded shut. so my idea is the take the passenger rear quarter interior trim off and drill the screws holding the door latch out so i can open the door. do you guys think ill have enough room to do that, or do you have any other ideas?
dallasb53 is offline   Reply With Quote
Old 12-14-2013, 06:31 PM   #2
zerodameaon
zerodameaon's Avatar
zerodameaon is an unknown quantity at this point
Take it off and take a look. The trim would take less time to get off then it would to make this post and wait for someone to reply back 10hrs later.
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
Old 12-14-2013, 08:06 PM   #3
dallasb53
was hoping somebody had done it before and might be able to tell me yay or nay before i get outside in sub freezing temps a do it ....BITCH
Old 12-15-2013, 01:23 AM   #4
zerodameaon
Why are you calling me a bitch, you seem to be the one bitching out not me. Also you forgot to say what car it is, that makes a little bit of difference.
Old 12-15-2013, 07:25 PM   #5
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
It sounds more like the door latch that's messed up. Trying to drill the screws out will be very difficult. I would try to get the doorpanel loose and try to open the door manually. It's probably just a clip that broke and the rod that actually opens the latch is no longer connected. Any way you look at it it's going to be a bitch.
SPEAKING OF WHICH...
If you're going to post a thread and ask for advice it is best to not fly off the handle and call people names. There was NOTHING particularly offensive about zerodameaon's post and you were COMPLETELY out of line. His point was simply that if you've got the mental capacity to come up with the solution you proposed in the OP, then perhaps your time would be better spent working on the car and figuring out the problem than posting a thread looking for some magical solution. There is NO magical easy solution. Your issue is NOT a common issue. You're going to have to figure it out on your own...
Old 12-16-2013, 10:23 AM   #6
dallasb53
Yes I do apologize. I was in a bad mood that night and made that post without thinking. I'm sorry zerodameaon.
Old 12-16-2013, 03:43 PM   #7
zerodameaon
Its all good. As for my advice I would do as racepar suggested, do every last thing you can on the door side because if you break something there the door can always be replaced. If you screw something up inside the QP its a lot harder to fix. Do you have the door trim off? if so start with PB Blaster and spray the locking/latching assembly down with the stuff. Try to also get some down in between the door and the B pillar area where the latch is at as long as it does not eat paint(wouldn't know haven't sprayed it on paint.)
Is this a S14? If so there are a few threads on this common problem.
http://zilvia.net/f/tech-talk/159149...-t-unlock.html
Old 12-16-2013, 05:23 PM   #8
dallasb53
Yes it is an s14. I've seen that thread but they never come to a conclusion. I had a locksmith look at it but he couldnt get it undone either
Old 12-16-2013, 06:10 PM   #9
Frank_Jaeger
Do you have problems with the lock in warmer weather?
Frank_Jaeger is offline   Reply With Quote
Old 12-16-2013, 11:54 PM   #10
zerodameaon
I hope you can get it figured out without having to take the drastic measures others have. Frank brings up a good point, if its only the cold wait till it warms up then take it all apart and oil it all up. There is a thread on another site about fixing door issues on other Nissan chassis of the same years. They are all pretty similar so it might work.
Old 12-18-2013, 04:51 PM   #11
dallasb53
well i got the door opened, it took a little drilling, but nothing a few filler welds and some paint wont cover. im thinking about doing a write up but idk since its not a common problem.
so far i think i might be the only one to have found out a solution, i even called the nissan dealership and they suggested i break the door panel. lol
Old 12-18-2013, 11:18 PM   #12
zerodameaon
Do a write up on it anyways if you would, if it was something to do with the locking rods being frozen in place its pretty common and there is no real info beyond break the door panel or cut the skin off your door. It really sounds like your method is pretty low impact vs the other ones.
Glad you got it sorted out.
