Old 12-25-2013, 12:44 AM   #1
Jayooheeewhy
Jayooheeewhy is an unknown quantity at this point
s13 SOHC MAF/idle issue
My first thread, always looked here for help and though i'd make an account.
I have A Ka24e, hooked up a cold air intake, didn't have a spot for the MAF sensor so I hooked it up without it, started up fine but died after some time and wouldn't rev past 3k, once i hooked up the sensor it would turn over and die almost immediately. Not sure if its a bad sensor? If i need to relearn the ECU or if its the IAC.
1989 240sx, SOHC, full EGR/vacuum delete, AC delete, rebuilt head, bolt ons.
Jayooheeewhy is offline   Reply With Quote
Old 12-25-2013, 02:53 AM   #2
frankies1390
frankies1390 is an unknown quantity at this point
did they not provide the MAF adapter? it needs to be in line so it can read ur air/fuel to give your ecu the info. hopefully u didnt fry the MAF. unhook your battery for a couple minutes and try adapting ur MAF to the intake tube. it needs to be sealed so all the air is passed through the sensor inside the MAF.
frankies1390 is offline   Reply With Quote
Old 12-25-2013, 02:53 AM   #3
frankies1390
or are u talking about the intake temp sensor?
Old 12-27-2013, 03:19 AM   #4
Jayooheeewhy
I'm talking about the MAF, they didnt provide an adapter but i ordered one and its coming in soon so i'll hook that up but i dont have a sealed spot for the actual little sensor, where do i screw that to? Just drill a hole in the tubing and screw it in or are there adapters? And wheres the Intake temp sensor located?
Old 12-28-2013, 07:11 PM   #5
Jayooheeewhy
UPDATE
Maf and intake air sensor are hooked up and car revs fine but wont idle. Could it be my IACV?
Old 01-03-2014, 07:27 PM   #6
kruked
Trader Rating: (37)
kruked is an unknown quantity at this point
Feedback Score: 37 reviews
IACV would be the first place to start
S13 coupe, KA-t
kruked is offline   Reply With Quote
Old 01-06-2014, 12:42 PM   #7
Jayooheeewhy
I clean the valve and reconnected everything and checked tbe ignition. What else could cause it die? Air fuel ratio?
Old 01-06-2014, 02:40 PM   #8
bmxer882x
bmxer882x is an unknown quantity at this point
Did you try disconnecting the battery and letting the computer reset like suggested above?
bmxer882x is offline   Reply With Quote
Old 01-06-2014, 03:15 PM   #9
frankies1390
If you've done everything stated above and it still dies, ur maf sounds dead. Keep ur maf plugged and disconnect the TPS located on the side of ur throttle body. See if there is a change in the time it stays running. Then vice/versa unplug ur maf and leave ur TPS plugged in. This will ultimately tell u if u have a bad sensor between the 2. Check ur engine grounds on intake manifold. The engine is grounded throughout the loom to 2 ground spades on the harness. I've had ecu failure as I thought it to be. Turns out the spades or connectors were broken.
Old 01-06-2014, 10:32 PM   #10
Jayooheeewhy
Tried, recharged the battery, tested starter and got new sparkplugs to make sure the start was fine. I'm going to check grounds, tps and maf tomorrow and see what happens.
iac, ka24e, maf, maf sensor, sohc
