#61 |
![]() Join Date: Jun 2009
Trader Rating: (24)
![]() Feedback Score: 24 reviews
i have a JDM blower motor speed controller with cut wire... and from my DCC harness i have 5 wires cut(purple/red spots, pink/red spots,orange/blue stripes/ red spots, pink/black stripes/red spots, pink/blue stripe/red spots...
can i just plug the USDM blower motor speed controller plug to the JDM blower motor.. does it work? also for the DCC led swap, do i just get the 4 leds out from the back of the DCC controller and just buy the same led size then plug and play? im not really good at wiring leds.... |
#62 |
you have to use a jdm sensor. its been awhile but i dont remember rewiring anything on the sensor plug. the jdm sensor just plugged right in, the only thing is that you need to shorten the fins or else it will ground and stay at full speed.
#63 | |
Trader Rating: (24)
wat sensor? fins of the ? and i think the plug thats suppose to go to the blower motor is the one that is cut. |
#65 | |
![]() Join Date: Mar 2007
Trader Rating: (31)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 31 reviews
Wire it up like Shown and just don't bother Using/mounting the Servo motor. My race car has it in there (had an Extra unit) w/ No A/C.All you need to do diff is Skip the Servo Damper motor and just keep the door OPEN,...so jam some paper under the lever that opens and closes the door and keep it open. I have it Just For heat For Coolant Bleeding and Track temps,..as well as if I ever drive in the cold.
z-tERty-2 |
#67 |
i know im reviving a bit of an old thread but i have a question pertaining to the subject of this post.
okay so i got a whole dcc with all wiring and all sensors. everything is still hooked up to the sub harness except for the outside ambient air temp sensor which is only connected to the connector with pigtail. so my question is where does the sensor connect to on the sub harness?? both wires on the pigtail comming from the sensor connector are black. ![]() |
#70 |
Trader Rating: (24)
im having trouble on mine, so heres what i have. this is for my S13 by the way.
this is my door mix motor(actuator) with plug and pigtail. do i have the right one? from what i see to what other people have, they have less wires on their plugs and some have different color wires that i do. ![]() IMG_3084 by d_2jzgte, on Flickr ![]() IMG_3085 by d_2jzgte, on Flickr this is my main unit connectors. where does the 2 pink wires go from the small plug(less wire plug), where does the pink and orange wire go from the bigger plug? ![]() IMG_3086 by d_2jzgte, on Flickr does this green wire/black stripe wire really jump from these 2 connectors? ![]() IMG_3088 by d_2jzgte, on Flickr and last where does this blue wire go from the 5 wire connector? and where does it plug into? ![]() IMG_3087 by d_2jzgte, on Flickr
REVIEW |
#71 |
![]() Join Date: Aug 2006
![]() Feedback Score: 9 reviews
Hey guys for those still struggling to do this ive made a video following
driftenthusiast write up on how the wiring should be set up and a little bit of the air box, blend motor and sunload sensor set up check it out and thanks again for the write up https://www.youtube.com/watch?v=Nt1dnTQMo8Y |
#73 | |
![]() Join Date: Jul 2013
hello
#75 |
Reviving this thread to add some info so it will be consolidated in one place for eternity.
Most of us don't get all the accesories for the DCC when we buy it... I've found almost any mid 90's nissan with dcc (pathfinder,maxima,q45) blower speed resistor will work. It is the one on the left pictured. Cut it to the length of the stock one and the plug clips right in ![]() Next is my LED DCC install; broadfield has a post without steps, he should receive the credit for this. (My pics) First go to superbrightleds.com for 3mm leds, any color, and also buy some resistors. You will need 4 of each Start by removing your stock leds ![]() Slide the new leds into place and wrap the short wire around the track (they make contact in the front obviously ![]() Now solder the resistor to the long wire of the led...be careful to leave enough slack to wrap through the track ![]() Make sure the resistor wires are not contacting themselves; wrap the lead up through the track. ![]() Simply screw back in, if they dont come one, turn the socket 180* ![]()
MRP Manufacturing |
#76 | |
Sent from my SM-N950U using Tapatalk |
#78 |
My 2014 Update DCC thread on NICO, pics work if you use Chrome Photobucket Fix Extension.
http://forums.nicoclub.com/topic590737.html |
