Old 09-12-2004, 07:51 AM   #1
TeamRush42
TeamRush42 is making his/her stupidity well-knownTeamRush42 is making his/her stupidity well-knownTeamRush42 is making his/her stupidity well-knownTeamRush42 is making his/her stupidity well-knownTeamRush42 is making his/her stupidity well-known
s14 PLEASE HELP WITH SR Install/Idle Problems!!!!!
Ok...like it says I got the S14 SR n the car this week...been trying to get it running for the last 2 days...here is whats going on...
Harness was done by Heavy Throttle , z32 ignitor was wired by me, z32maf wired in by HT, I put in the afc (set to Hotwire 2 in 6out) - all the plugs seem to be on correctly and everything seems to be wired ok
PROBLEMS:
Car will crank but no idle - will revv over 2500 if i step on gas. Same result wether MAF is on or off. Car actually runs like a IC piping is loose but i am about 98% sure no connections are loose(when i do rev past 2500 puffs of black smoke come out and car will still rev but stumbles badly)
AFC is reading the RPM signal but seems like adding or decreasing fuel makes no difference on how car runs but im am 95% sure the pressure wire is hooked up correctly. I also have the grey throttle wire hooked in correctly but im getting no voltage reading....
I WILL TRY TO:
Replace MAFS with another tonight when my friend comes by
Recheck the AFC wiring
Recheck the TPS voltage with a volt meter
Recheck the IC Piping for a 5th time
Recheck the Spark Plugs for being fouled out
Recheck the harness for any loose or wrong connections (but dont all the plugs fit only a certain way???)
Please list any and all possibilities or thoughts on what my problem may be...unfortuneately i will be at work from 10am -9:30pm so i wont be able to respong but im hoping that there will be some responces so i can try stuff once i get home...THANKS FOR ANY HELP THAT CAN BE OFFERED!!!!!!
TeamRush42 is offline   Reply With Quote
Old 09-12-2004, 12:21 PM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
SOund like a Maf issue...try running the stock maf for now and see how that goes. Ive been having some issues too everytime I stick my Z32 Maf in *idles weird and seems to run better with stock S13 maf* Yah, the set up is 2-6 but the S14 SR might be different, you might wanna look that up.
CLICK HERE!!!
Old 09-13-2004, 02:44 PM   #3
Luke
Luke is an unknown quantity at this point
Send a message via AIM to Luke
2 of my MAFS signal wires were cut by one of those zip tie things that hold the harness to the body of the car. Follow your MAFS wiring all the way back because it could be that. I spent 3 weeks of frustration and checking and rechecking my splicing, swapping MAFS, and checking other crap that didn't help. GL
'93 240sx Coupe
SR20DET Blacktop
Luke is offline   Reply With Quote
