Old 12-29-2013, 10:12 PM   #1
s13_whoa
s13_whoa's Avatar
s13_whoa is an unknown quantity at this point
changing cap and rotor
so i feel like i should take off the battery cable before replacing this part but my shit is stuck. it was loose before and i took my car to a battery place and they added a shim and tightened the F*** out of it. and my bolt is practically strippd so a screwdriver cant loosen it and a socket wont fit on it. im speaking of my negative battery cable btw. SO should i just go ahead and replace or find someway to get that damn cable off?
s13_whoa is offline   Reply With Quote
Old 12-29-2013, 11:17 PM   #2
bmxer882x
bmxer882x is an unknown quantity at this point
Not necessary. but you could just take the positive off if your that paranoid. But as for taking it off try vice grips... or hitting it with a punch to try to get it to twist.
bmxer882x is offline   Reply With Quote
Old 12-29-2013, 11:50 PM   #3
Jesus_lopez405
Jesus_lopez405's Avatar
Jesus_lopez405 is an unknown quantity at this point
Better to take the time and fix your terminal now at home than on the side of the road somewhere. Then disconnect your negative cable and do it better than doing it and somebody accidentally turns the ignition.switch and you get a bad day. GL
Jesus_lopez405 is offline   Reply With Quote
Old 01-03-2014, 10:30 PM   #4
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Agreed on fixing that as well!
Old 01-03-2014, 10:45 PM   #5
MamangSorbetero
MamangSorbetero's Avatar
MamangSorbetero is a jewel in the roughMamangSorbetero is a jewel in the roughMamangSorbetero is a jewel in the roughMamangSorbetero is a jewel in the roughMamangSorbetero is a jewel in the roughMamangSorbetero is a jewel in the roughMamangSorbetero is a jewel in the rough
You can always try spraying some WD40 or some sort of lubricant and the terminal should slide right off. I don't see why you can't just take a 10mm or 12mm to the nut though.
Patience is key; don't rush things and think before you act. Save the headache
MamangSorbetero is offline   Reply With Quote
Old 01-07-2014, 01:34 AM   #6
pancakes562
pancakes562's Avatar
pancakes562 is an unknown quantity at this point
I sprayed some break cleaner or wd-40 on my shit before and used pliers lol
pancakes562 is offline   Reply With Quote
