Hks ssqv compressor surge
Hey guys, first time posting on zilvia,I own a 93 180sx with sr20det. so I bought a hks ssqv off my brother it is authentic, I bought a isis hot pipe with hks ssqv flange. I got everything I'm hooked up the vaccume line to it and it doesn't work? All I get is compressor surge, like it's hooked up to the vaccume, the hks ssqv moves in and out manually (with my finger) but doesn't work when i rev or drive. Idk what's wrong, and the line isn't bent. Anyone have a solution? There's lots of threads on here but I can't find the answer
![]() Join Date: Apr 2013
My type s I had to disassemble and lube up when it froze. May be something similar. I used wd40. The top two ports on the throttle body are vacuum, the bottom one is boost. Make sure your on only vacuum.
ITS LISA'S FAULT!!!
![]() Join Date: Jun 2003
Trader Rating: (41)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 41 reviews
one of many things below is happening..
1) you have boost leaks (not uncommon). when you have even a minor boost leak, it will cause major vacuum issues. especially with the response from your SSQV 2) your SSQV is indeed fake. doesnt matter if your brother, your mother or your gold fish says its real. unless it was purchased directly from an authorized or well known HKS dealer, you may gotten a fake...which leads me to #3 3) if your SSQV is fake, then it will work like shit. there should be 2 different valves in the front of the SSQV, most fakes only have one. authentic SSQVs move in and out with ease, fakes tend to be fairly stiff. the diaphragms used in the fake SSQVs tear and wear out very easily so they will not create vacuum. 4) your vacuum is routed from the wrong place. not meaning this in an insulting way, but we all make silly mistakes with our cars at times. make sure you are running your BOV's vacuum from one of the two nipples located directly above your throttle body. 5) try spraying a small amount of WD40 around the front valves as well as the piston chamber (by pushing both valves in with your finger) to make sure everything is lubed up. work the valves in and out a bit to make sure a liberal amount of WD40 makes it into the needed areas. you can also take the valve off and spray some in from the bottom port. 6) your SSQV is not seated properly in the flange on the hotpipe. if the c-clip doesnt not seat itself in the groove completely to lock in the SSQV (by making its distinct "clink" noise when the c-clip expands and locks), your BOV will leak from the flange and possibly competely shoot off under higher boost amounts. also, did you make sure that the rubber o-ring wasnt torn or ripped in any way? i can speak from personal experience that the mass produced hot pipes (isis, circuit sports etc) use shitty fake SSQV flanges that require some minor modification to make fit the c-clamp and o-ring properly. if you didnt order an authentic HKS flange and weld it on yourself, the flange you are using may not be allowing the SSQV to seat correctly! my best guess in all of this is either you have boost leaks, your SSQV isnt setting itself properly in its flange or your BOV needs minor lubrication. Last edited by dorkidori_s13; 01-12-2014 at 03:09 PM.. |
#7 | |
If you are surging your turbo is the wrong size for your motor.
If you are fluttering your bov isn't opening. They are stupid easy to take apart to inspect. China diaphrams are SHIT. I always get the china shit and mod it with real parts til it suits my needs. I dont condone it and feel halfway bad about it but i'm a driver so fuck all the hipster shit. This could be as simple as your spring being too tight. They are adjustable. Keep trouble shooting simple and take this with a grain of salt when i say "FLUTTER" and "SURGE" are not the same thing. It's a pet peeve when people confuse the two and own turbo cars.....
Just another broke ass drifter ![]() |
Tags |
compressor, sr20, surge, turbo |
