Old 10-23-2013, 06:31 PM   #1
Serban
Serban is an unknown quantity at this point
Super Ultra Mega Garage Sale S13 KA-T and other parts!!
My 240 is gone, now this stuff does me no good, so it's gotta go! Shipping is not included in any of the prices. I'd prefer to sell the big stuff locally, but if you want to pay for shipping, I will send it.
You can PM me, email me at [email protected], or call/text at 954-257-0147.
My paypal address is above. ^^^^^^^^^^^^^^^
The first few photos are for reference to see how all the CX Racing and custom parts go together.
CX Racing SR20DET intercooler pipe kit modified to fit KA-T with top mount T3 and CX Racing KA24DET turbo manifold, and delta fin intercooler. Comes with assorted t-bolt and worm clamps - $200
CX Racing tubular T3/T4 KA24DET turbo manifold with flange for 38mm wastegate - SOLD
CX Racing 3" downpipe with heat wrap. Will work with manifold above and T3 turbo. Has flange for 38mm wastegate dump tube. Can always be blocked off if you like to run a screamer pipe. Comes with dump tube. If you use a Tial wastegate, everything lines up great. Also has second O2 sensor hole for wideband - $150
3" stainless exhaust with Apexi style muffler and siliencer. The front flange was cut, and rotated a few degrees to line up with CX Racing downpipe. Its best to run this whole system, as it all fits together - SOLD
Q45 370cc injectors with new pintle caps - SOLD
AFC Neo - SOLD
Calum S13 Basic ecu comes with 3 sets of roms, but I'd recommend doing your own tune - SOLD
Two E60 Maxima MAFs. One had a corner break off, it was glued back together and it holds fine. Both work well. $35 for the one that was glued back together, and $50 for the other one. Both come with pigtails.
ACT Heavy duty clutch and street disc, very little use - SOLD
Exedy OEM replacement clutch disc - SOLD
Solid engine mounts - SOLD
Adjustable rear upper control arms - SOLD
KA24DE flywheel - SOLD
S13 KA24DE 5 speed manual transmission. Grinds in second and third gear. Should just be a couple of synchros, not sure, never cracked it open - $100
S13 KA24DE automatic driveshaft - SOLD
S13 4 lug rotors, front and rear - SOLD
S13 4 lug hubs, front and rear - SOLD
S13 stock exhaust cam (for those who want to do the hot cam swap) - $45
S13 convertible small side windows - $25 each
S13 convertible small outer cover thing - $10 each
S13 fan shrouds. I have two of them, one is a 2 piece, the other is a one piece shroud. Both are undamaged in the usual contact spot between the shroud and fan blade. But each one has a broken mounting tab - $20 each
S13 front turn signals, one left, one right - $10 each
MOMO steering wheel bub # 3507. I don't believe its the part # required for an S13, but it works. I've also used it on B12 and B13 Sentras - $45
Falken ZE912 tires. 215/55/17, decent amount of tread left - $60 all 4
Serban is offline   Reply With Quote
Old 10-23-2013, 08:35 PM   #2
d_nice
d_nice's Avatar
Trader Rating: (39)
Feedback Score: 39 reviews
bump for good parts here
Old 10-23-2013, 10:45 PM   #3
path s13
path s13 is an unknown quantity at this point
Cool
How much for that break master heat shield?
path s13 is offline   Reply With Quote
Old 10-24-2013, 04:37 AM   #4
Serban
I don't have that anymore. It's not one of the parts listed for sale. You can probably find them for about $25 online.
Old 10-24-2013, 12:10 PM   #5
Serban
Forgot to mention, AFC will come with the stand. I took it off and used velcro to hold it in the cubby hole under the radio.
Here it is in action!
Old 10-25-2013, 01:15 PM   #6
Serban
Bump it up!
Old 10-27-2013, 04:00 PM   #7
Serban
Sunday bump! C'mon folks, make offers!
Old 11-05-2013, 06:41 AM   #8
Serban
Still have some stuff available!
Old 11-10-2013, 06:34 AM   #9
jtimcort
jtimcort is an unknown quantity at this point
hey I could use the passenger side front turn signal if still available
jtimcort is offline   Reply With Quote
Old 11-10-2013, 04:58 PM   #10
Serban
Yup, still have a right turn signal.
Old 11-15-2013, 08:49 AM   #11
Serban
Updated list with all items that have been sold.
Old 02-11-2014, 03:48 PM   #12
Serban
Bump, still have a few things left.
Old 02-11-2014, 05:12 PM   #13
240Fubs
240Fubs is an unknown quantity at this point
right turn signal still available?
240Fubs is offline   Reply With Quote
Old 02-11-2014, 06:24 PM   #14
Serban
Yup, still available
