![]() Join Date: Sep 2011
![]() Feedback Score: 35 reviews
sr20det engine set. (part out, or as whole)
Parting out sr20det redtop.
Wire harness $70 -will work fine..needs maf pig tail, and o2 pigtail. The main interfaces started converting (just cut the jdm grey plug off, was about to soldier in usdm plug. Ignitor sodier and heat shunk extented. Maf extented with SHEILDED oem maf wire and soldered and heat shrink. Bottom end $550 -works fine, cylinder walls look good. New acl bearings. Bare block, with side sensors snd internals. New bearings! Bottom end is assembled. I would sell head and block together. Head sr20 $500 -works fine. Looks like all oil changes done. Head is currently on block. I would sell them un seperated as well. Comes with cams, cas, gears. All internals in head of course. Intake manifold sr20 with all sensors (no injectors) $200 Injectors sr20 75 all 4 with rail 5speed trans sr20 $175 -unknown condition Turbo set up $250 Tial 38mm external wastegate, t25 turbo, waste gate removed, oem manifold drilled for external wastegate. Xs power dump tube, Oem sr20det turbo. New gaskets. New manifold multi layer gasket $15 Steel braided turbo lines $60 T25 ruber inlet with alu. elbow $65 T25 alu. Outlet $40 T25 exhaust elbow $15 Light used sr20 clutch Exedy oe $65 Light used 50k miles flywheel sr20 $50 Flywheel bolts sr20 $10 Sr20 ignitor works $55 Sr20 starter works $60 Sr20 alternator with bracket housing lightly grinded $75 Sr20 oil pan lower $20 Sr20 upper oil pan $50 Sr20 oem shifter $40 Sr20 mounts with brackets $45 Anything else, i wont start the part out till the block/head is sold. I will sell whole engine set for $1700 everything included. It is 100 percent assembled |
