grounding thru the brake light in gauge cluster
95 240sx brake light in guage cluster in stays on when key on power, when brakes are hit headunit resets and the door dinger goes off. Checked all grounds power to the blower moter is only 5v at the fuse block. No shorts or bad grounds found, any ideas would help alot thanks
anyone know where the blue/white tracer pos wire from the blower motor goes on its way to the fuse block, i cant seem to find were it runs from the motor to the fuse block after tearing up the dash. does look like it stops at the hvac controler either
