Old 03-03-2014, 07:13 AM   #61
rbs14kouki
rbs14kouki's Avatar
rbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to all
Its a billet lower section with a greddy s14 intake !
http://www.nissansilvia.com/forums/i...tach_id=401137
AV FABRICATION
Built thread sr20vet s14
http://zilvia.net/f/showthread.php?t=535574
rbs14kouki is offline   Reply With Quote
Old 03-03-2014, 11:42 AM   #62
hobbs
Trader Rating: (43)
hobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the roughhobbs is a jewel in the rough
Feedback Score: 43 reviews
Oh woah, that is fucking awesome!
hobbs is offline   Reply With Quote
Old 03-03-2014, 01:02 PM   #63
krysknowles
krysknowles's Avatar
krysknowles is an unknown quantity at this point
My Old Motor...Miss it a lot :-(
krysknowles is offline   Reply With Quote
Old 03-03-2014, 01:08 PM   #64
SamsonS4
SamsonS4 is an unknown quantity at this point
pretty cool but the hyper tune manifold is best!
SamsonS4 is offline   Reply With Quote
Old 03-03-2014, 01:12 PM   #65
hobbs
Trader Rating: (43)
Shame the intake runners are so short, I was really considering hacking up a S14 manifold for use on a VE.
Old 03-03-2014, 01:28 PM   #66
SamsonS4
i posted the wrong one.
Old 03-03-2014, 06:47 PM   #67
slideways2004
slideways2004 will become famous soon enoughslideways2004 will become famous soon enoughslideways2004 will become famous soon enoughslideways2004 will become famous soon enough
Send a message via AIM to slideways2004
Originally Posted by mewantkouki View Post
^ serious..?
1. P11 or P12 head
2. VVL relocation plates if you have a p11 head. (solenoid is larger)
3. Sr20ve oil pump
4. Pistons with valve reliefs if you plan on running anything larger than p11 cams
5. 20V cas (won't clear s14 lhd firewall)
6. Hall sensor kit if you opt not to use 20v cas
7. fwd sr20de or any other aftermarket sr20 cam gears.
8. sr20ve oil pump drive gear or mazworx spacer
9. machined stock pulley
10. plug oil drain port on block
11. plug oil drain port on head
12. Drill and tap oil feed for vvl solenoid. (side of head)
13. Oil feed line to vvl
14. Oval bolt holes on sr20det manifold of choice or build one with ve flange
15. Mazworx oil pickup tube
16. Mazworx or taarks water pipe
17. aem / denso pencil coils for p11 or s15 coil packs for p12 head
18. Head gasket of choice
19. Cut / flip stock upper intake manifold or xcessive, hypertune, mazworx plenum (xcessive / hypertune are the only options right now for p12 heads)
Pretty sure that's about it.
This is a great list, but how come no one talks about ecu choices??
If you are using a 20v CAS, can you not use the stock ecu the sr20ve came with and get it rom tuned?? I personally prefer not to run standalones b/c of price and mainly b/c there are no good tuners here in town. They all want to make max power and can't setup a reliable tune
Also, this is great! S14 intake manifold bolts right up to this it looks like
slideways2004 is offline   Reply With Quote
Old 03-03-2014, 10:09 PM   #68
Yellow4g63
Yellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of light
Send a message via AIM to Yellow4g63
That's a custom billet job. The VVL intake ports are bigger than the S14's.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Yellow4g63 is offline   Reply With Quote
Old 03-04-2014, 01:03 AM   #69
rbs14kouki
rbs14kouki's Avatar
2500$ us for an intake / throttle body and fuel rail is way to much for my budget !!!! If i could i would dont worry
AV FABRICATION
Old 03-04-2014, 01:33 AM   #70
SamsonS4
what's another 2500 when vet setup is already a big baller set up
Old 03-04-2014, 01:39 AM   #71
SamsonS4
All fun and games aside as you are already aware of to build a proper vet setup is some big money and down time.
Def not a set up if budget minded is your game but no expense spared maximum power and response is your game. I read about in aussie land there was a event there was a rb28 tomei powered car and a sr22vet s15 going at it and the vet set up out performed the r28. Very impresive.
Old 03-04-2014, 09:45 AM   #72
simmode1
simmode1's Avatar
All fun and games aside as you are already aware of to build a proper vet setup is some big money and down time. Def not a set up if budget minded is your game but no expense spared maximum power and response is your game.
Yeah, I think that's why I probably won't do this. I love everything I've read about the VET swap, but ontop of the cost of doing it, I feel like you'd also need to totally revise your drivetrain & suspension to put all this power/response to the ground, even further increasing costs. Definitely not the route to go for someone like me looking for a simple & mild low 300hp range 240. VET is big boy stuff. But if I hit that point when 300hp+ is no longer enough for me... VET, here I come.
Old 03-04-2014, 10:15 AM   #73
rbs14kouki
rbs14kouki's Avatar
You can upgrade to vet for reliability too !
I started from scratch with this sr20vet
Sold my racecar that had a ls1 with g-force gsr too buy my house and stsrted this project on the side
A 400 to 500whp sr wont need all that much $$$
PJ's (fastest s13 with a h-patern transmission and street legal tire) makes 900whp with an xcessive intake that cost 300$ compare too all the other option that are close to 1000$ and up !!!
My friend has 425 whp
sr20vet:
Precision 5830
Topmount manifold
Stock head + dual valve springs upgrade
S15 transmission with exedy super single
Nothing to special
And he drives the car every day to work (he will upgrade the transmission when it brakes)
Personnaly I would not built a vet to run a t28 and have 300whp
AV FABRICATION
Old 03-04-2014, 10:36 AM   #74
Drift_FX
Drift_FX's Avatar
Drift_FX is an unknown quantity at this point
almost done.....
Drift_FX is offline   Reply With Quote
Old 03-04-2014, 10:39 AM   #75
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
I notice that everyone talks about the parts needed to make the conversion to reality, but what do everyone use as the engine harness?
Is there anyone other plugs on the wiring harness to run the head which is different if at all different from the SR20? Will the standalone PFC work with the head?
To make the VVL work, will a multi-switch need to be installed to turn it on or off?
I've been making decisions for the last year and half if I should go this route if I'm not hitting my goals just with my SR. I'm looking at what would work to make to a reality if I don't have to much to work with.
What are the options for this?
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 03-04-2014, 10:43 AM   #76
jr_ss
You can use your S13 harness for all the necessary sensors. You'll need to run an RPM switch to control the solenoids.
As for EMS, Nistune or ROM tuning can be utilized.
Old 03-04-2014, 10:45 AM   #77
Drift_FX
Drift_FX's Avatar
im doing a completely custom harness, but the majority of the harness is unchanged when switching to this head, you just need to modify it to accept the different coils and ignition box.
Old 03-05-2014, 07:28 AM   #78
autotechmotoring
Banned from the Marketplace
autotechmotoring will become famous soon enoughautotechmotoring will become famous soon enoughautotechmotoring will become famous soon enoughautotechmotoring will become famous soon enoughautotechmotoring will become famous soon enough
Existing engine harness stays the same. A tuneable ecu is a plus. You can use a MSD 8969 to activate the VVL and just wire in the solenoids to the unit.
Another plus that alot have not mentioned is that the VVL head uses solid shaft mounted rockers vs. free floating rockers in the std DET head. The chances of breaking rockers with the VVL head is 0 to none.
autotechmotoring is offline   Reply With Quote
Old 03-05-2014, 03:43 PM   #79
Imarvin240
Trader Rating: (18)
Imarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura aboutImarvin240 has a spectacular aura about
Feedback Score: 18 reviews
https://instagram.com/eck_matthew/
Imarvin240 is offline   Reply With Quote
Old 03-05-2014, 07:24 PM   #80
slideways2004
The sr20ve stock ecu plugs into S13 redtop/blacktop ecu plug?
Old 03-05-2014, 07:42 PM   #81
jr_ss
No, you use the DET ECU with a ROM tune or Nistune...
You'll be running the DET harness and ECU, but have it tuned for your setup.
Old 03-05-2014, 09:04 PM   #82
Yellow4g63
S13 ecu run the Nismotonic daughter board. It will kick the VVL for you if you use one of the outputs on the board and run a map sensor and 20X20 tables.
91 Nx2000 VVL yo
Old 03-06-2014, 08:39 AM   #83
Ramonesfreak2010
Ramonesfreak2010's Avatar
Ramonesfreak2010 is an unknown quantity at this point
Decided to mock up the head and manifold on the block for some extra motivation. Been a slow build since I am paying for this semester of college at the moment.
Ramonesfreak2010 is offline   Reply With Quote
Old 03-06-2014, 08:42 PM   #84
slideways2004
Thanks for your help!
All of a sudden it doesn't look that complicated anymore. lol
p11 head, here I come.
Old 03-07-2014, 08:27 AM   #85
autotechmotoring
Nope it honestly isnt. Other than wiring in the new Denso or equivalent coils and your VVL solenoids, its pretty much a straight forward swap over.
Old 03-07-2014, 10:15 AM   #86
s13silvia123
For the turbo manifold or exhaust manifold, would you have to notch the existing bolt holes to accomodate with the VET head? Does the exhaust ports match with the DET turbo manifolds?
Reason for the turbo manifold is because I don't want to buy another manifold since I am using the PowerLab twin scroll.
Old 03-07-2014, 10:20 AM   #87
jr_ss
Exhaust ports share the same centerlines, you just need to lift the manifold up roughly .125". So oblonging the holes is a must if you have a DET manifold. The ports are higher in the head because of the coolant passages and different chamber and valve angles.
Old 03-07-2014, 11:07 AM   #88
autotechmotoring
Or there are several manifold options out there already that can accomodate both DET and VE setups
Old 03-07-2014, 11:15 AM   #89
jr_ss
He doesn't want to purchase a new manifold.
Old 03-07-2014, 11:29 AM   #90
GroundPerformance
GroundPerformance's Avatar
Trader Rating: (44)
GroundPerformance is an unknown quantity at this point
Feedback Score: 44 reviews
You should really need to spend much on manifolds or relocation blocks to convert to VVL if your not planning to go on monster build. I'm actually doing this now and I will share it with Zilvia on the Builds thread. Just waiting for Admin approval.
SoCal KA24DET/KA24ET Owners
<< Join the FB Group >>
GroundPerformance is offline   Reply With Quote
