Old 03-05-2014, 09:13 PM   #1
Microe16
Microe16 is an unknown quantity at this point
need assistance
i removed my intake manifold to replace the gaskets and add an oil catch can on my ka24de afterwards put everything back together and tryed starting it up (it was running before i took off the intake manifold) turned over for maybe a couple seconds struggled to stay on and just shut off i figured it'd be the vacuum lines but they seem to be fine its cranking but not getting any fuel tryed looking for other forums with same issue none could be found.so any suggestions what to check?
Microe16 is offline   Reply With Quote
Old 03-05-2014, 09:35 PM   #2
Jesus_lopez405
Jesus_lopez405's Avatar
Jesus_lopez405 is an unknown quantity at this point
Fuel lines backwards??
Jesus_lopez405 is offline   Reply With Quote
Old 03-05-2014, 09:56 PM   #3
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
How do you know it's not getting fuel?
Old 03-05-2014, 10:48 PM   #4
coupesallday!
coupesallday!'s Avatar
Trader Rating: (18)
coupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the roughcoupesallday! is a jewel in the rough
Feedback Score: 18 reviews
Send a message via MSN to coupesallday!
Why are you putting a oil catch can on a stock motor?
Throw some glitter flake and crazy glue in there.
coupesallday! is offline   Reply With Quote
Old 03-06-2014, 12:18 AM   #5
Aspire818
Aspire818 is an unknown quantity at this point
Make sure all the hose are connected it happen to me once i couldnt figure it out till 1 hour later -.-
Aspire818 is offline   Reply With Quote
Old 03-06-2014, 04:58 PM   #6
Microe16
my fuel pump working but fuel not going into the regulator ideas?
Old 03-06-2014, 05:00 PM   #7
blkvrtswp
blkvrtswp's Avatar
blkvrtswp is an unknown quantity at this point
Listen to Jesus.....
blkvrtswp is offline   Reply With Quote
Old 03-06-2014, 05:43 PM   #8
rebornS14
rebornS14's Avatar
rebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of light
Send a message via AIM to rebornS14
Jesus will lead the way
rebornS14 is offline   Reply With Quote
Old 03-07-2014, 06:32 AM   #9
sonimatebi
sonimatebi is an unknown quantity at this point
good,Make sure all the hose are connected it happen to me once i couldnt figure it out till 1 hour later
sonimatebi is offline   Reply With Quote
Old 03-07-2014, 07:46 AM   #10
Driftwire
Driftwire's Avatar
Driftwire is an unknown quantity at this point
Fuel lines are probably backwards bro.
The lines go like this
Fuel filter > Rail > FPR > Return
The Feed should not be going into the FPR it should be going directly into the rail and exiting through the FPR.
/Thread
Originally Posted by Hoffman5982 View Post
Did you check the potato fuse located in the front right corner of your gas tank?
Originally Posted by RB33 View Post
No i haven't. To be honest i didnt know there was a fuse there. Thats not a fuse for the fuel pump is it?
Driftwire is offline   Reply With Quote
