#781 |
![]() Join Date: Nov 2003
Pretty stoked to finally be able to post up, and actually have something to contribute today! Got everything installed yesterday, and so far has gone really well. Working out some boost control issues with my EBC, but I'll be sorting that out today hopefully!
Turbo is installed!! ![]() ![]() ![]() ![]() ![]() ![]() ![]()
-Kyle ![]() |
#782 |
![]() Join Date: Apr 2004
Got some pretty big PS leaks there!
I'd also be careful with the bend you have in that teflon oil feed line. Once that teflon liner kinks, you'll get almost zero oil flow through there. The outer braid will straighten out and you probably won't be able to tell.
S13 Hatch - Goes around tracks quickly DEFSPORT |
#784 |
Walbro 255 can easily handle 350 rwhp on stock fuel lines and gas. It can even do it on E85 with enough injector, but you're starting to push the limits of stock lines a little past there.
#785 | |
![]() Join Date: Nov 2008
Also, to answer your question about the internal WG flap, I actually just got a locker bar for mine. ![]() |
#786 |
What does your AFR look like in 2nd and 3rd?
In my car, if I do a full pull in 4th, it is dead solid 11.6-11.7 all the way til 8k pretty much. However, in 2nd it hangs around 12.3, and 12.0 in 3rd. I just figured that the fuel pump wasnt able to keep up since it rips through those gears so fast?
-Kyle ![]() |
#789 | |
#790 |
The leaner AFR in lower gears is the hysteresis of the MAF affecting the measurement vs. actual more and more. You also have hysteresis in your wideband O2 that is probably affecting results somewhat as well.
#791 |
Nice, I removed my engine to do the clutch, replace the rear main seal and to get the manifold welded up by codyace for an EWG. I just ordered the stage 8 bolts, some of the new studs I used to install the turbo seemed looser than when I installed them a month ago.
#793 |
BKR7EIX's - stock 0.028" gap should be fine for this turbo. I'd maybe think about 8's if you're doing a lot of track time. Mine would range from looking fine to maybe a hair on the hot side with lots of track usage.
#796 |
Ngk bkr7s as well. I ran 30 gap until I went to a bigger turbo. Had to go down to 24 gap when I got past 430rwhp.
Sent from my SGH-T999 using Tapatalk
Mazworks | HKS | Greddy | T4 GTX3076r | Full Race | Tial | SPL | Feal |
#797 |
Ok, so I lost compression in #4 this weekend at the track (only 80psi), so looks like Im going to do a full rebuild. What kind of build specs are you guys running on built engines? how long have you had it together and running (miles/years)? And how has it affected reliability and driveability?
-Kyle ![]() |
#799 | |
1.Why not use the stock locking plates(where the tabs fold up) instead of where you have those nordlocks? 2. Can Nordlocks be used instead of those copper locking nuts? Or is it well known that new copper locking nuts will hold? 3. Does anyone ever have issue with the bolts that hold the center section to the inlet/exhaust housings coming loose? I'd like to just spend money on the hardware now and not have to worry about stuff coming loose. Open to suggestions. |
#800 | |
#801 |
JWT ECU. Very happy with it.
New build coming, .020 over, CP pistons, Manley rods, refreshed head, apexi head gasket, OEM bearings, Splitfire ignition, full complete -AN power steering setup, etc...should be back in the car in about a month.
-Kyle ![]() |
#802 |
Hey guys had a few questions as to where my set up might stack up..
Vtc s14 sr 9.1 wiseco 87mm 1.2 tomei gasket 1mm over sized valves 3 angle intake 5 angle exhaust Jwt s4 cams Stock turbo mani ported and coated T25+ t31 turbine housing moded for external gate Gtx2867r Should be getting on a dyno in a few months My question is with the t31 t2 housing it flows like a full t3 at .63ar will this flow more like a .86 t2 or more like the .64? I want a really quick response Also what do y'all believe my limit on boost with pump gas will be I'm running a custom cell -6 fuel line areomotive a750 pump feeding Nismo 740cc injectors will be doing an ls2 coil upgrade soon but first dyno will prolly by on the stock ignition system... Any input would be great! |
#805 |
Well my 740's will limit me to petrol but I've been thinking of running a race gas pump mix, I'd like to see 400 whp with crazy fast spool... And maybe full race gas and 20+ psi to see what the set up is really capable of.
Sent from my iPhone using Tapatalk |
#807 |
![]() Join Date: Jul 2006
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 9 reviews
I would of sold you my housing!
http://zilvia.net/f/showthread.php?t=564456 |
#809 |
New Garrett GTX2867r
huffandpuff00 if only I would have known this over the weekend I would have bought yours.... What's your reason for selling? How's was response on this housing
#810 |
Y'all are making me feel confident with the set up
![]() Sent from my iPhone using Tapatalk |
Tags |
gt2871, gtx, gtx2867r |
