Old 04-09-2014, 12:56 AM   #1
Migit240sx
Migit240sx is an unknown quantity at this point
What driveshaft is needed to complete S13 swap? ABS/SUPER HICAS->SR20DET
Hello Zilvia!
I'm confused as to what driveshaft is needed to complete my SR swap.
My S13 shell consist of SUPER HICAS/ABS. Since I'm going Sr20, what driveshaft should I be looking for?
Migit240sx is offline   Reply With Quote
Old 04-09-2014, 01:00 AM   #2
zerodameaon
zerodameaon's Avatar
zerodameaon is an unknown quantity at this point
If the car came with a driveshaft and it matches your transmission(auto to auto etc.) you will use that. You need the ABS shaft that matches your transmission in other words.
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
Old 04-09-2014, 02:37 AM   #3
Migit240sx
My car did not come with a driveshaft, It's a bare shell
Old 04-09-2014, 03:45 AM   #4
zerodameaon
Ok just need an abs shaft out of any s13 so long as it matches your transmission type.
Old 04-09-2014, 08:13 AM   #5
240pimp
240pimp is an unknown quantity at this point
Why not just buy a one piece driveshaft from somewhere like Z1 performance in georgia?
The used 2 piece driveshafts can give you alot of headaches. vibration, having to buy several new pieces, etc. A new steel 1-piece solves all those problems, probably cheaper.
I run an aluminum one now......Awesomeness!
93 Hatch w SR20
240pimp is offline   Reply With Quote
Old 04-09-2014, 11:16 AM   #6
Migit240sx
That's the route I think ima go. To clarify, it's an s13 shell with abs/super hicas. I'm swapping over an s13 redtop. I'm guessing I only need an abs sr20 manual driveshaft?
Sent from my SGH-M919 using Tapatalk
Old 04-09-2014, 07:16 PM   #7
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
You just need to find a manual S13 ABS driveshaft...doesnt matter if its for an SR or KA, they're the same lenght. The difference between an ABS and non-ABS is the longer diff snout so the ABS ones are shorter.
CLICK HERE!!!
Old 04-09-2014, 07:17 PM   #8
Migit240sx
Thank very much sir! I'd give you kudos if there was a kudos button!
