Old 04-11-2014, 11:28 AM   #1
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
anti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfection
Feedback Score: 37 reviews
Send a message via AIM to anti tyler Send a message via Yahoo to anti tyler
Not so mega s13 HB part out *PIC HEAVY
S13 Hatch partout[/B]
I have a 1993 s13 black hatch back I'm trying to get stripped down to donate the chassis to a friend.
He basically said to get rid of everything on the car before he wants the chassis so I want to make sure everyone gets a chance at the parts on the car before It goes to him and he trashes everything he doesn't want!
Basically has about everything left on it.
few things are removed and gone;
Door panels
Driver seat
Clutch pedal
Brake master cylinder
Climate control
Dome light
Glove box
To add some body to this I'll try to list everything thats left. Prices are best offers ( I don't have set prices for anything so offer up, lowballs welcome ) **SHIPPING AVAILABLE**
Starting at the rear;
Stock tail light
Rear Left Tail light SOLD
tail light sockets
tail light trim (under lights)
Bumper cover
Bumper support
Bumper energy absorber (foam insert)
Toe rods
Traction rods
Lower control arms
RUCA's
REAR R+L Spindles W/ hubs+dust shield attached
REAR R+L Brake dust shield
REAR R+L Calipers W/mounting bracketd
REAR R+L Brake lines
REAR R+L Marker Lights
FRONT R+L CalipersSOLD
FRONT R+L Brake linesSOLD
ka24de Motor SOLD
Ka24de Manual NON-ABS driveshaftSOLD
Ka24de 6 bolt axles PASS. SOLD
Ka24de STOCK open 6 bolt diff.SOLD
Ka24de Lower manifold with all attachments excluding throttle body.
Accessories fuse block with wires
Brake BoosterSOLD
Clutch master cylinder SOLD
Clust Slave Cylinder SOLD
Power steering pump SOLD
Power steering reservoir SOLD
Transmission cross member SOLD
Transmission mount SOLD
S13 speed sensorSOLD
s13 chuki bumper vents
s13 B piller outer covers R+L
Z32 MaF pigtail
Pass Headlight motor SOLD
Wiper amp switch SOLD
R+L window crank handles
Assorted interior plastic paneling
LEFT+RIGHT Head Light Assy (No bulbs)
Rear R+L seat belts x2 (1) SOLD
Stock 1 Piece Passenger seat Good condition no rips/tears
Brake pedal
Gas pedalSOLD
*Stock Older style carpet Grey
**Black newer style carpet
Gauge Cluster SOLD
Gauge Cluster surround trim
LEFT+RIGHT Side Mirrors (No glass)
Driver Side hood hinge x2
Pass side headlight cover
Assorted rear end bolts (toe rod/tension rod/ruca)
Rear subframe hardware (Nuts for all 4 posts, bottom plates/front side plates)
Full set of megan tracks (2 struts are bent) Not sure if they're rebuild-able
Various air filters
Spectre air duct 36" extended
Sunpro 3 gauge pod. Missing all bulbs & oil sensor. Brand new otherwise.
Ecu kick panel in black AND brown options.
Driver fuse panel with access door
**Brand new Airtex stock fuel pump + strainer + gas tank seal
**Brand new oxygen sensor
**Brand new Knock sensor (Square plug)
**Brand new knock sensor pigtail
engine harness SOLD
engine bay harness SOLD
Body harness $95 + SHIPPING OBO
80k trans in good condition shirter needs grommetSOLD
wiper motor
Steering column & linkageSOLD
radiator w/ single fan & hosesSOLD
clutch slave cylinderSOLD
Pignose bumper turn signal metal backings
center console
dash vents
Turn Signal stalk
wiper stalk
exedy pressure plate & clutch disc in awesome shape 3k miles ××make offer××
Door bottom trim pieces ( bottom of door opening )
White plastic carpet hold down pieces
Also have entire HVAC setup, blower/air mix servos, blend door actuators, ducting etc..
Also some bitchin' lame seat covers new.
Few of the New NON 240sx stuff;
NEW Metra Universal 1500watt amp wiring kit
NEW Peak Performance 800 watt power inverter
I literally have a ton of crap sitting in the house, I need to clean it out so I can condense down to only 3 cars instead of 4, Of course as always It's nearly impossible to think of every single thing I've got so I probably missed some stuff.. Like I said, MAKE AN OFFER.
And ask if there's something you're looking for. You never know, I might have it.
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Current for sale advertisement
anti tyler is offline
Old 04-11-2014, 12:27 PM   #2
PedroJG
PedroJG is an unknown quantity at this point
Do you have the power steering pump?
PedroJG is offline
Old 04-11-2014, 01:16 PM   #3
Whitey13
Whitey13 will become famous soon enoughWhitey13 will become famous soon enoughWhitey13 will become famous soon enoughWhitey13 will become famous soon enough
Do you have this piece?
Whitey13 is offline
Old 04-11-2014, 02:06 PM   #4
WithHonor037
WithHonor037's Avatar
WithHonor037 is an unknown quantity at this point
Looking for rear hatch plastic that goes over the bottom latch and a climate control shipped to 18326
They call me Dr. Frankenstein cuz I build monsters all night long..
WithHonor037 is offline
Old 04-11-2014, 02:37 PM   #5
acslater9
acslater9's Avatar
acslater9 is an unknown quantity at this point
Is the carpet straight up black? and is it in good condition?
Also what about the 5 speed transmission, did it work when the car was running? If no please list the problems it had.
By the way if the transmission is in good condition I might just buy everything needed for a 5 speed swap. So let me know asap!
acslater9 is offline
Old 04-11-2014, 02:43 PM   #6
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
Yes, No lines for it though. $15 or $29 shipped priority to your door.
If you're pointing to the A piller, or whatever that is. Yes I do. I'd have to see how long it was before I gave you an exact price. Shoot me a PM with your info and that picture so I have a reminder when I get off work to check.
The plastic thats like 2 1/2 feet long? I do have that. I'll measure it and get back to you VIA PM with the prices.
Climate control has been sold already
Carpet is straight up black as the night.
Tranny worked in the car, Condition is unknown. When I originally bought the car, I never drove it except to put it on a trailer. Tranny felt like the grommet on the bottom of the shifter was gone, causing the loose shifter feel. It did go into gear and drive up the trailor fine.
WillEastS14:
mannn u whylin son.
KA-T for life!
Old 04-11-2014, 02:45 PM   #7
adams 02rs
adams 02rs's Avatar
Trader Rating: (25)
adams 02rs is an unknown quantity at this point
Feedback Score: 25 reviews
Pm me if you have dual cam PS lines and throttle cable. Bump.
adams 02rs is offline
Old 04-11-2014, 02:53 PM   #8
WithHonor037
Yea the lower piece in the center. I think I see it laying in the hatch in the back of the 11th picture down.
Old 04-11-2014, 02:57 PM   #9
Certified G
Certified G's Avatar
Certified G is an unknown quantity at this point
you have a hatch with no holes decent conditon?
Certified G is offline
Old 04-11-2014, 03:27 PM   #10
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
No sir, No power sterring anything except the rack and pump
I do have a throttle cable but honestly it'd be easier to get a new one for the $40. If you do really need it though shoot me a PM we can work something out.
Yeah that looks like it, it's also ontop of the hatch in the 1st picture. I guess I have 2 of them lol.
The black hatch pictured has not leaked any that I've noticed the 6 months of owning it. I can go out and take a closer look seeing as my DD hatch leaked & I just resealed it.
WillEastS14:
mannn u whylin son.
KA-T for life!
Old 04-11-2014, 03:36 PM   #11
Certified G
sweet, as long as it doesn't have holes from an oem spoiler I'm interested. How much shipped to texas 78259?
Old 04-11-2014, 04:17 PM   #12
WithHonor037
Hard to tell in the first picture but it could be. How much would you want for it?
Old 04-11-2014, 04:19 PM   #13
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
You want the hatch shipped? Do you personally know of any company that would ship something of that size and weight for a decent price because I don't... I'll try to do some looking around though, but if you can find a good rate let me know through PM.
Depending on shipping I'll take $8 for it. Because it's so light I couldn't imagine it costing more than $5-$9 to ship.
WillEastS14:
mannn u whylin son.
KA-T for life!
Old 04-11-2014, 04:23 PM   #14
WithHonor037
So say $15 shipped then?
Old 04-11-2014, 05:26 PM   #15
adams 02rs
adams 02rs's Avatar
Trader Rating: (25)
pm me about front coil overs asap. Bumping again.
Old 04-11-2014, 08:42 PM   #16
PedroJG
Ok ill take the ps pump, pm me the info.
PedroJG is offline
Old 04-12-2014, 06:10 AM   #17
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
That works for me, I'll try to send you another PM. Not letting me send any right now.
PM sent but it wont let me reply to you anymore.
WillEastS14:
mannn u whylin son.
KA-T for life!
Old 04-12-2014, 09:37 AM   #18
86is300
86is300 is an unknown quantity at this point
Hey Tyler, are you going to three palms speedway today? Would like diff and axles.
86is300 is offline
Old 04-12-2014, 10:15 AM   #19
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
No sir, I'm pulling a motor at 1pm after work. If you're close you're more than welcome to grab the axles & diff
WillEastS14:
mannn u whylin son.
KA-T for life!
Old 04-12-2014, 09:03 PM   #20
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
Bump couple things sold, new items listed in Magenta color, tons of available items
WillEastS14:
mannn u whylin son.
KA-T for life!
Old 04-13-2014, 12:22 AM   #21
SubIElove
SubIElove is an unknown quantity at this point
Driver seat belt?
SubIElove is offline
Old 04-13-2014, 01:34 PM   #22
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
Which part the lap belt or the auto retracting shoulder belt?
WillEastS14:
mannn u whylin son.
KA-T for life!
Old 04-14-2014, 05:29 AM   #23
Darkcr3w
Darkcr3w is an unknown quantity at this point
s13
Rubber Shifter boot w/ metal ring shipped to 33774?
Darkcr3w is offline
Old 04-14-2014, 07:10 AM   #24
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
If you're talking about the piece that keeps heat from entering the car I don't have that.
WillEastS14:
mannn u whylin son.
KA-T for life!
Old 04-14-2014, 01:40 PM   #25
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
Bumping over the limit, someone needs some cheap stock replacement parts. come get them, I don't want to trash what little 240 parts are left on the market.
WillEastS14:
mannn u whylin son.
KA-T for life!
Old 04-15-2014, 01:40 PM   #26
IROYLE1
IROYLE1 is an unknown quantity at this point
I need the wire harness that goes from the gauge cluster to the body harness.
got one?
IROYLE1 is offline
Old 04-15-2014, 07:00 PM   #27
tobroketobuildarealcar
tobroketobuildarealcar is an unknown quantity at this point
Do you have a good cond diff
tobroketobuildarealcar is offline
Old 04-15-2014, 10:52 PM   #28
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
got one?
Yeah full harness is available on the car.
Diff is in good working order. Also have an axle available too
WillEastS14:
mannn u whylin son.
KA-T for life!
Old 04-16-2014, 10:13 AM   #29
icypuck17
icypuck17 is an unknown quantity at this point
e brake handle! how much shipped to 13617 pm me! plz and thanks
icypuck17 is offline
Old 04-16-2014, 11:09 AM   #30
Arrowking
Arrowking's Avatar
Arrowking is an unknown quantity at this point
Do either of the speed sensors have 21 tooth gears?
Arrowking is offline
