Old 05-08-2014, 08:24 AM   #1
Kaifd3s
Kaifd3s's Avatar
Kaifd3s is on the path to ruinKaifd3s is on the path to ruin
10mm Bolt On Spacer Question
Was looking at some 10mm bolt on spacers as I purchased new wheels. The thing is the front require a 10mm spacer. I am not trying to spend close to $200 for a set of Project Kics ones.
I went on Ebay and saw these. How the hell do they bolt to the hub??
http://www.ebay.com/itm/10MM-ALUMINU...b3e475&vxp=mtr
Kaifd3s is offline   Reply With Quote
Old 05-08-2014, 08:48 AM   #2
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
When you want to save money by purchasing cheaper (possibly lower quality) parts, think about the location and where it goes. If it breaks or is defective, are you okay with the consequences?
As for how they are mounted on the car, the picture on the background is how they SHOULD be mounted. But the product photo looks to be slip on spacers.
For Sale #1 | For Sale #2
zooopreme is offline   Reply With Quote
Old 05-08-2014, 09:09 AM   #3
!Zar!
!Zar!'s Avatar
I haven't even heard of 10mm bolt on spacers.
I would imagine the nuts would protrude out further than the spacers.
Do the wheels you run have clearance on the back-pad for this? If not, your wheels won't sit flush on the spacer.
Old 05-08-2014, 09:28 AM   #4
Dustxking
Dustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of lightDustxking is a glorious beacon of light
!Zar! I agree with him, never heard of a bolt on spacer that is 10mm.
15mm I have seen and purchased before in the past from poweredbymax.net.
The ones pictured above are for a European car such as VW, Audi, Mercedes, ect. Those are lug bolts which our Japanese cars do not use.
Purchase these if you are in "need" of spacers.
http://www.partsshopmax.com/page.php?38
Dustxking is offline   Reply With Quote
Old 05-08-2014, 09:36 AM   #5
Kaifd3s
Kaifd3s's Avatar
Yes the wheels have clearance slots cut on the back for this.
Old 05-08-2014, 10:19 AM   #6
srstan
srstan's Avatar
srstan is an unknown quantity at this point
those are not bolt on spacers. they provide you with longer bmw style wheel studs that will not work with your car. If you install longer wheel studs these will work though.
srstan is offline   Reply With Quote
Old 05-08-2014, 02:01 PM   #7
lude4life13
lude4life13 is an unknown quantity at this point
I think getting slip on spacers (10mm) and extended ARP studs is your best option. Make sure they have hub rings as well or they may keep your wheels from mounting correctly. At one point I had the ichiba v2 bolt on spacers and the studs on those POS's were loose after a while. I took out the studs making them slip ons, and haven't had any problems since.
lude4life13 is offline   Reply With Quote
Old 05-08-2014, 03:10 PM   #8
Revue
Revue's Avatar
Revue is an unknown quantity at this point
I'm running these with extended ARP studs
http://www.ebay.com/itm/4-12mm-Hubce...-/231119110883
Revue is offline   Reply With Quote
Old 05-08-2014, 03:43 PM   #9
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
Never had a problem with these with my xd-9's:
http://www.frsport.com/Ichiba-NS-502...m_p_12869.html
spooled240 is offline   Reply With Quote
Old 05-09-2014, 07:46 AM   #10
Kaifd3s
Kaifd3s's Avatar
Thanks everyone, Spooled you saved the day again.
Old 05-09-2014, 09:25 AM   #11
jaxshawn
jaxshawn is an unknown quantity at this point
the ones originally pictured are VW style spacers, they you a lug stud instead of the typical stud and lug nut like most cars
jaxshawn is offline   Reply With Quote
Old 05-09-2014, 10:37 AM   #12
spooled240
spooled240's Avatar
np, just make sure the studs are pressed all the way in when you install them.
Old 05-09-2014, 10:50 AM   #13
SkyS13Walker
SkyS13Walker's Avatar
SkyS13Walker is an unknown quantity at this point
Send a message via AIM to SkyS13Walker
Just get the isis spacers from en ju enjuku racing. They slip right on and you won't need extended studs till you go 15mm
Love her like ya bitch and i aint talkin about ya girl
SkyS13Walker is offline   Reply With Quote
Old 05-09-2014, 05:16 PM   #14
InsTanCeZ
InsTanCeZ's Avatar
InsTanCeZ is an unknown quantity at this point
Why not just get 15mm bolt ons? It's only 5 more mm and you won't need extended studs, or Parts Shop MAX. They're adjustable from 3mm - 30mm.
ACE マジック HEART
InsTanCeZ is offline   Reply With Quote
Old 05-10-2014, 09:15 AM   #15
Kaifd3s
Kaifd3s's Avatar
Looks like I might do the PBM spacers, gives me another reason to buy some front arms to save on shipping.
Old 05-10-2014, 09:25 AM   #16
5280VertDET
5280VertDET's Avatar
5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light5280VertDET is a glorious beacon of light
I bought these, very impressed with them. Identical to other "name brands" I've seen.
http://www.ebay.com/itm/201024825371...84.m1439.l2649
I would avoid slip on spacers, if you can.
S13 Vert | SR | PE1420 | 5-Speed | 15x9.5 - 0 |
5280VertDET is offline   Reply With Quote
Old 05-12-2014, 07:17 AM   #17
Revue
Revue's Avatar
For why do you say this?
Old 05-12-2014, 07:56 AM   #18
zooopreme
Trader Rating: (38)
There's a lot of debate about the safety of wheel spacers. Slip on's typically don't have a hubcentric ring so the wheels and much of the load is put on the studs on the hub. Having old stock studs plus slip on spacers is risky and should not be done if you haven't replaced and/or extended your studs. But I've seen guys use ARP studs and slip ons and they were just fine.
Bolt ons are the same affair, imo, especially the PBM ones which are only hubcentric on the hub side and not the wheel side. Not 100% sure if that makes a difference but I would imagine that much of the load will be placed on the PBM studs which isn't ideal.
Old 05-12-2014, 09:07 AM   #19
5280VertDET
This. Thank you. Also, the ebay ones I posted are hubcentric.
Old 05-12-2014, 10:14 AM   #20
Revue
Revue's Avatar
Ah, I agree, I've ran non hub centric and they're awful. The link I posted is hubcentric for Nissan which is why I suggested
Old 05-12-2014, 10:19 AM   #21
TMW
TMW's Avatar
TMW is a well-known jackass
I have 20mm ebay bolt on spacers and they've been fine for over a year so far. They're just spacers lol.
@tannermwilson
TMW is offline   Reply With Quote
