Old 09-29-2004, 05:21 PM   #1
rancid240
Trader Rating: (72)
rancid240 will become famous soon enoughrancid240 will become famous soon enoughrancid240 will become famous soon enough
Feedback Score: 72 reviews
has someone invented this yet?
A wheel/tire height calculator that includes stretch when calculating total height?
rancid240 is offline   Reply With Quote
Old 09-29-2004, 05:26 PM   #2
HyperTek
http://www.miata.net/garage/tirecalc.html
Keep it Classy
Old 09-29-2004, 05:29 PM   #3
rancid240
Trader Rating: (72)
Originally Posted by HyperTek
That one doesnt factor in stretch.
Old 09-29-2004, 06:20 PM   #4
mrmephistopheles
mrmephistopheles's Avatar
stretch will differ between manufacturers and tire width. that'd be a damn hard thing to calculate for
Old 09-29-2004, 06:46 PM   #5
Var
Var's Avatar
Send a message via AIM to Var
i was thinking the same thing. I wish someone would write a program for that.
Hi
Old 09-29-2004, 10:25 PM   #6
KA24DESOneThree
KA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfectionKA24DESOneThree is close to perfection
I wish they wouldn't. That way, people would have to find out the hard way and maybe in all that work, they'd realize that hipari is UGLY.
KA24DESOneThree is offline   Reply With Quote
Old 09-30-2004, 01:48 PM   #7
Equinox
Equinox will become famous soon enoughEquinox will become famous soon enoughEquinox will become famous soon enoughEquinox will become famous soon enoughEquinox will become famous soon enough
Send a message via AIM to Equinox
Why would you really need to calculate for tire stretch? If you have to stretch your tires then the rim width should be the widest part. Just use that measurement for the width. The only measurement that would be slightly off with stretched tires would be the amount of sidewall, but I think this would be fractions of an inch at most.
-Steve
http://www.controlledspin.com
Equinox is offline   Reply With Quote
Old 10-01-2004, 02:35 PM   #8
Chernobyl
Chernobyl's Avatar
Chernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond reputeChernobyl has a reputation beyond repute
Total height is not affected by sidewall stretch. Have a nice day.
Chernobyl is offline   Reply With Quote
Old 10-01-2004, 03:26 PM   #9
Var
Var's Avatar
I would think it would be..depends on the extent of the stretch doesnt it?
Hi
Old 10-01-2004, 03:30 PM   #10
Chernobyl
Chernobyl's Avatar
Ok, take a dismounted tire and try to squeeze it to a different diameter while keeping it round. I bet you can't do that.
Stretching changes the angle of the sidewall, not the diameter of the tire.
Old 10-01-2004, 04:25 PM   #11
Andrew Bohan
normal tire |___|
stretched tire \___/
you have to make the sidwalls taller to keep the wheel-to-tread distance the same. otherwise the wheel-to-tread has to be less.
basic geometry
Old 10-01-2004, 05:18 PM   #12
Var
Var's Avatar
yes..the shortest distance between two points is a straight line (sidewall facing straight up and down)
When you angle the sidewall outwards, either the sidewalls would have to be taller or it would make the diameter of the tire less.
Hi
Old 10-01-2004, 07:50 PM   #13
Chernobyl
Chernobyl's Avatar
ugh. its hopeless. Go to a tire shop and ask them to show you how a tire beads on a wheel. I'm not gonig to try to explain it further.
Stretching tires will NOT change overall tire diameter. Maybe a nanometer or two...
Old 10-04-2004, 09:57 AM   #14
Var
Var's Avatar
So it does change. I didnt say it would change my much, i was thinking a mm or 2, but still. It makes sense that it would be affected.
Hi
Old 10-04-2004, 10:15 AM   #15
Zemus
Zemus's Avatar
Zemus is an unknown quantity at this point
Send a message via AIM to Zemus
Hah streaching does change it just a bit. Exp
I had a 215/50/15 on a 7inch wheels, and I had 215/50/15 (same tire) on a 8.5inch wheel and it was quite a bit smaller, Like I could tell by looking at it. Optical illusion... possably, :shrugs: It seems a bit shorter
Zemus is offline   Reply With Quote
Old 10-04-2004, 11:11 AM   #16
Var
Var's Avatar
What about your speedometer? did it change at all?
Hi
