Old 06-27-2014, 02:55 AM   #1
puerkone
puerkone is an unknown quantity at this point
240sx differential question?
Hi just out of curiosity, I was reading this link from nico club about different differental gear ratios. here is the link.
http://forums.nicoclub.com/the-ultim...d-t228683.html
How should I understand the gear ratios? I have a s13 vlsd in my 240sx. out of all of the nissan differentials, which gives higher topspeed and less acceleration? I have KA24DERT in my car and acceleration is crazy in my ka. however I reach top speed really fast. Let me know what you think. thanks.
puerkone is offline   Reply With Quote
Old 06-27-2014, 03:57 AM   #2
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
You have a twin charged KA but can't figure out how to google?
Gear ration is # of teeth on the ring gear / # of teeth on the pinion.
If you go "larger" like stepping up from a 3.9 to a 4.3, your off the line acceleration improves but your top speed decreases, and vice versa.
Old 06-27-2014, 04:06 AM   #3
puerkone
thank you for your reply. I just wanted clarification. I had a rough idea of gear ratios. just never put the time to actually think about it. so what do you think about the q45 vlsd differential in s13? too heavy? I was thinking about getting it because gear ratio is 3.5
Old 06-27-2014, 06:46 AM   #4
brndck
brndck's Avatar
What are your goals? Are you drag racing? What is it you're trying to accomplish?0
Old 06-27-2014, 12:29 PM   #5
Def
Stock 4.08 will do over 170 mph with a 7k rpm redline and decently sized tires.
A lower ratio gear will just make you slower if you can't pull to redline in 5th, which I don't think you have the power to do. Less drive wheel torque only makes since if you actually have too much in 5th gear and easily pull to redline.
DEFSPORT
Old 06-29-2014, 11:10 PM   #6
GSKChris
GSKChris's Avatar
GSKChris is an unknown quantity at this point
Brndck is correct. 3.9 gear ratio you will go through gears faster and top out sooner. 4.03 or 4.08 is mo betta in my experience.
GSKChris is offline   Reply With Quote
Old 06-29-2014, 11:30 PM   #7
snafupossum
snafupossum is an unknown quantity at this point
so has money to build super awesome ka that tops out 5th but cant figure out how to do simple math(gear ratios)? In for vids of said troll car topping out 5th with ANY gear ratio you can put in it.
snafupossum is offline   Reply With Quote
