Old 07-08-2014, 03:57 PM   #1
sean.arnold9012
sean.arnold9012 is an unknown quantity at this point
92 240sx running issues
hey guys and gals.
ok I might as well start.
I have a 92 Nissan 240sx convertible
the car starts fine. and seems to idle fine also.
runs cool. no codes.
I bought this car with this issue.
if I rev the engine while parked with no load everything seems fine.
but once a pull out to drive it. the car has no power and starts to get engine ping. I tried playing with the timing to eliminate the ping. when I retarded the timing the ping went away, but the power loss was even worse.
if I advance the timing back I get some power back but the pinging returns.
when I bought the car it did have some codes. it had a distributer sensor code. a maf sensor code, I fixed both codes but to no avail.
please ant help or ideas would be appreciated
now lets brain storm and get this solved
sean.arnold9012 is offline   Reply With Quote
Old 07-08-2014, 04:04 PM   #2
cbeuglas
cbeuglas is an unknown quantity at this point
Check fuel pressure
cbeuglas is offline   Reply With Quote
Old 07-08-2014, 04:05 PM   #3
cbeuglas
Most code issues cause rich state.
Old 07-08-2014, 04:05 PM   #4
cbeuglas
Also check for a vacuum leak.
Old 07-08-2014, 04:32 PM   #5
sean.arnold9012
running rich woundnt cause it to ping though would it?
ive double and triple checked for vacuum leaks nothing....
I have not checked the fuel pressure, ill check that asap.
would that cause a ping though?
Old 07-08-2014, 04:32 PM   #6
sean.arnold9012
im also getting ready to replace the knock sensor
Old 07-14-2014, 04:52 PM   #7
sean.arnold9012
need help bump
