Old 08-01-2014, 05:37 PM   #1
NickS14
NickS14 is an unknown quantity at this point
KA-T SAFC II Settings
So, I'm pretty new to the KA-T world... To make a long story short, I blew my first KA when I went turbo, tunes it with the SAFC II but didn't have a 24/7 wide band going. Tune slipped.. BOOM! So, replaced the KA and went 5spd all in one shot. So, over the passed few months I've had to consistently take more and more fuel out of the tune and not sure what could be causing it.
Current Setup:
Garrett T3/t04 57 trim. .48 a/r
SR 370cc injectors
Walboro Fuel Pump
Stock MAF
Auto ECU
I started at about -30% while cruising, not in boost, and have since had to almost max out the SAFC current settings are -32% at idle, and -48% at lo-thrl... Is this normal? What could be the culprit? I feel like I shouldn't have to be taking out soo much fuel...
NickS14 is offline   Reply With Quote
Old 08-01-2014, 05:54 PM   #2
jr_ss
Get a real tune and throw that thing in the trash where it belongs. You're going to end up blowing another bottom-end.
Old 08-02-2014, 08:53 AM   #3
NickS14
The SAFC II? Appreciate the help... Suggestions?
Old 08-02-2014, 09:09 AM   #4
souljaseth33
souljaseth33 is a name known to allsouljaseth33 is a name known to allsouljaseth33 is a name known to allsouljaseth33 is a name known to allsouljaseth33 is a name known to allsouljaseth33 is a name known to allsouljaseth33 is a name known to allsouljaseth33 is a name known to allsouljaseth33 is a name known to allsouljaseth33 is a name known to allsouljaseth33 is a name known to all
Send a message via AIM to souljaseth33
Enthalpy, JWT, nismotronic
Poor people and excuses ruined two tones.
souljaseth33 is offline   Reply With Quote
Old 08-02-2014, 10:12 AM   #5
NickS14
Thanks, but there seems to be a greater issue, than just the shitty SAFC causing me to need to pull out so much fuel, just replaced plugs yesterday...
Old 08-02-2014, 10:34 AM   #6
bmaddock
bmaddock's Avatar
bmaddock is an unknown quantity at this point
You should read up some more on KA-T before you blow another motor. SAFC really won't help you much for a T3/T4 on stock tune. Look into ROM tunes such as RS Enthalpy. Don't be cheap on the tune, it costs nearly the same as a SAFC and is specific to you're setup. The SAFC just adjusts the signal from the MAF and has no timing adjustment.
I created this thread for a similar setup here: http://zilvia.net/f/showthread.php?t=572741
I would read through that and send Martin at RS Enthalpy an email.
bmaddock is offline   Reply With Quote
Old 08-02-2014, 03:36 PM   #7
jr_ss
I suppose ignorance is bliss, do yourself a favor and do some research. My suggestion is help, trust me.
Old 08-08-2014, 06:58 PM   #8
thegr8one013
thegr8one013 is an unknown quantity at this point
here are some settings
http://www.ka-t.org/forums/viewtopic.php?t=8089
i would highly recomend getting a air/fuel ratio sensor so you can make adjustments according to your setup. i found different setups online with the safc2 and non of them worked on my setup.
the safc is just a way to get the car started and basicallly driven to a shop to get properly tuned. the thing with the safc is that when you reduce fuel you advance timing which will cause detonation and eventually your bottom end will go.
at the end of the day its your engine, i gave you the information you were looking for plus some extra info. the decision is yours as to what you choose to do with it
thegr8one013 is offline   Reply With Quote
Old 08-09-2014, 09:10 AM   #9
Croustibat
Actually it is worse than that. It changes timing for sure, but sometimes it will go up, sometimes it will go down, and all the time it won't be where you want it to be, resulting in a really not smooth power delivery, power loss when timing is pulled, and melted pistons / det when it is advanced.
Old 08-09-2014, 09:22 AM   #10
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
anti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfection
Feedback Score: 37 reviews
Send a message via AIM to anti tyler Send a message via Yahoo to anti tyler
Does the fact that you're using a stock MAFs not raise any red flags? You don't just "blow a bottom end" driving normally around.
If you don't know what you're doing you shouldn't have gone KA-T.
Further more, asking for other peoples settings on the SAFC is not going to help.
You really need to make sure you've got the dec. air settings etc set correctly.
One does not simply "install SAFC and pull fuel" to make a reliable turbo car.
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Current for sale advertisement
anti tyler is offline   Reply With Quote
Old 08-09-2014, 03:25 PM   #11
wawazat8402
wawazat8402 is an unknown quantity at this point
Send a message via AIM to wawazat8402
Originally Posted by anti tyler View Post
One does not "install SAFC and end up with a reliable turbo car.
Fixed. You can get a close tune by sending your specs to JWT or Enthalpy. There is absolutely no reason to have an SAFC in these cars. Ever.
wawazat8402 is offline   Reply With Quote
Old 08-09-2014, 07:34 PM   #12
jr_ss
Sure there is, when you're a cheap, ignorant person, trying to bandaid something...
Old 08-09-2014, 08:29 PM   #13
Chaluska
too bad a "cheap band-aide" SAFC is like trying to cauterize a wound you don't have yet.
<<have used Enthalpy / Nistune..
<<also the original author of the "ultimate SAFC guide" on ka-t
Old 08-12-2014, 12:15 PM   #14
Scott@FontanaNissan
Scott@FontanaNissan's Avatar
Scott@FontanaNissan is an unknown quantity at this point
Send a message via AIM to Scott@FontanaNissan
sounds like you have a stuck injector, fuel leak, bad maf or something else mechanically / electronically wrong with your setup. something isn't right from our experience on simple 370cc injector setup on a stock KA24De ecu we tend to see ~ -27% at idle and low throttle cruise correction, some setups have seen as much as +13% up top under load. with that turbo you'll max out your injectors real quick. you should save up a little longer and get some Tomei 740CC injectors and a JWT tune or a Nistune ROM Tune.
-Juan
Juan Vargas - Motorsports Specialist Fontana Nissan/Nissanraceshop.com
email: [email protected]
Scott's Personal Website/Blog: http://www.scottandkerryann.com
Scott@FontanaNissan is offline   Reply With Quote
