Old 08-09-2014, 07:08 PM   #1
ulises619
ulises619 is an unknown quantity at this point
240sx rev problem!!!!
Ok so yesterday my car just stop turning on so I removed the starter and got it checked it was not working so I replaced it and now the car is working fine but when hit the rev limiter the rpms go down to aroun 3k even if my foot is all the way down then I can get it back to 6k. do you guys know what could be causing this.??The only things I removed yesterday were the distributor cap ,battery and a few connections to get the distributor out. Thank you any help would be greatly appreciated .
Motor ka24e
ulises619 is offline   Reply With Quote
Old 08-09-2014, 10:17 PM   #2
ulises619
Ok changed the distributor cap and rotor still the same problem this only happends when the car is still if the car is moving I can bounce off the rev.limiter at.6k.
Old 08-10-2014, 02:36 AM   #3
crossway
crossway is an unknown quantity at this point
Any error codes? It could also be a faulty fuel regulator or fuel pump.
crossway is offline   Reply With Quote
Old 08-10-2014, 09:31 AM   #4
ulises619
No error codes and this starter to happend after I changed the starter.
Old 08-10-2014, 09:34 AM   #5
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
Won't rev over 3k? Sounds like a bad maf
Have you checked fuel pressure, timing, CAS, compression, or ANYTHING actually?
Old 08-11-2014, 12:58 PM   #6
ulises619
No I can rev past 6k and bounce off the rev.limiter after like 2 seconds it goes down to 3k even if. Im all the way down on the gas. If the car is moving I can rev to 6k and bounce off the rev limiter if im not moving I cant it just goes down too 3k and the I can go back up.
Old 08-11-2014, 02:00 PM   #7
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
please see brndck's comment above... youre missing something
Old 08-11-2014, 06:24 PM   #8
crossway
I agree you are missing something. You might disconnected accidentally somewhere or something upon replacing the starter.
