Old 08-18-2014, 06:41 PM   #1
Rclarocque
Rclarocque is an unknown quantity at this point
KA KA24DE smoking fuel?
so my gf drove her car to work on a rainy day and when she pulled up to work her car was shaking,puffing white smoke (fuel), and has a very low rough idle, it's eating gas like no tomorrow, we ended up diving the car home which was about 10miles and the car guzzled 3/4 of a tank. now I've been trying to diagnose the car so I have replaced all 4 injectors, spark plugs, maf sensor and I just cleaned the fuel pump connector cause it was corroded. the car struggles to start only way to get it to run is by pumping the gas, then once it's started you can let off, no rpm gauge but I figure it running around 3-5 hundred rpms and the engine shakes and tranny shakes making a pretty annoying sound as well, as you give it gas it's just a smoke show, all white and yes it is fuel, smells like fuel and it's spitting fuel out as well. no coolant. also should add the car had a Lake inside the passenger side, ecu could have easily gotten wet, next I will be replacing ecu but I'd like to know if anyone has had this problem or something I need help ASAP if anyone would like a video you can also ask for my number and ill text a video thanks for everything!
Rclarocque is offline   Reply With Quote
Old 08-18-2014, 06:48 PM   #2
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
anti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfection
Feedback Score: 37 reviews
Send a message via AIM to anti tyler Send a message via Yahoo to anti tyler
Pumping the gas...
Have you tried starting it with the pedal to the floor? (Shutting injectors off)
Also do a quick fix and see what you get, change the coolant temp sensor, if it's bad it's telling the ecu the car is running cold causing an extreme dump of fuel.
Report back with your findings and we can take other steps,
I'm guessing it's not the MAFS if you're able to go above 2500rpms.
Edit**
Try unplugging the coolant temp sensor with the car running and see if it's idle changes.
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Current for sale advertisement
anti tyler is offline   Reply With Quote
Old 08-18-2014, 06:53 PM   #3
SaVAgES14
SaVAgES14 is an unknown quantity at this point
What does the oil look like? Never heard of white smoke relating to a fuel issue... Usually means you have coolant contaminant in the oil.
SaVAgES14 is offline   Reply With Quote
Old 08-18-2014, 06:56 PM   #4
Rclarocque
I'll give the coolant temp sensor a try!
and the oil was half fuel so it's basically flooding itself, I did an oil change tho clean fresh oil still spitting fuel but im gonna try the sensor
Old 08-18-2014, 07:05 PM   #5
Rclarocque
Originally Posted by anti tyler View Post
Pumping the gas...
Edit**
unplugging sensor didn't change anything
Old 08-18-2014, 07:11 PM   #6
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
At idle and a nice and cold motor it didn't change at all?
WillEastS14:
mannn u whylin son.
KA-T for life!
Old 08-18-2014, 07:14 PM   #7
Rclarocque
when I plugged it back in idle got a little higher then back to normal rough idle
Old 08-18-2014, 07:14 PM   #8
SaVAgES14
That sounds like the problem, just that color smoke is throwing it off.
Old 08-18-2014, 07:16 PM   #9
SaVAgES14
No check engine light? Send me that video please. Pm your number
Old 08-18-2014, 07:30 PM   #10
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
Yeah replace that coolant temp sensor for sure.
It's totally possible that the ecu still thinks the car is running on a cold start & dumping fuel into the system. if that's your only problem then count your blessings
WillEastS14:
mannn u whylin son.
KA-T for life!
Old 01-30-2017, 01:06 AM   #11
Laujpha
Laujpha is an unknown quantity at this point
I recently fail smog with my 93 240sx for gross polluted. My s13 have alot of white smoke coming from the exhaust tail pipe. i decided to change head gasket, valve seal, fuel filter, o2 sensor, new spark plug, air fliter, clean my egr, intake gasket, header gasket, valve cover gasket, new water pump, new termostat, new tps,clean my iacv, ect.. pretty much the whole head gasket set kit.. with that being said...i still have white smoke and car smell like its burnig to much gas...did compression test and all cylinder have 155 psi...any suggestions and help i would really appreciate it.
Laujpha is offline   Reply With Quote
#240sx, #ecu, #fuel, #ka24de, #s13
