Old 08-23-2014, 03:27 PM   #1
Payableondeath6
Payableondeath6's Avatar
Payableondeath6 is an unknown quantity at this point
Need help car stranded. Not obvious no start issue.
I'm fine, I have another vehicle and the car is only 2 miles away from my house, but it's a pain running back and forth. I have an interesting no start issue currently making me scratch my head, any help is appreciated. I have never had any starting troubles with the car, but over the last week or so I have caught the alarm going off for no reason twice. Yesterday morning I went out and started my car, drove to PT, and after PT when I went to start it to drive to work I got one click and no cranking, then everything went dark. No chimes, no lights on dash, no cranking, no clicking with the key in any position. I suspected the battery was low since the alarm has likely drained it and my short commute doesn't recharge it fully, so I tried jump starting it and bringing the battery home to charge overnight both to no avail, no changes at all. This morning I checked all the fuses and found the 7.5A "EGI" fuse blown. I replaced this and the car started just fine, I let it run for 10 mins but I could not drive it home because I had both of our vehicles with me. When I returned 10 mins later it acted the exact same as before and the "EGI" fuse was fine?! It acts the exact same now. As a note the ignition switch was changed about a month ago and I have had no problems with starting at all. Only things I can think of is the new ignition switch failing or the battery chassis ground (I noticed this was not screwed down when I removed the battery, but that hasn't changed recently). I'm going to fix the battery ground and hopefully that fixes it, but any ideas are greatly appreciated.
'95 240sx SE KA-T
GO NAVY!
Payableondeath6 is offline   Reply With Quote
Old 08-23-2014, 03:38 PM   #2
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
anti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfection
Feedback Score: 37 reviews
Send a message via AIM to anti tyler Send a message via Yahoo to anti tyler
before I read all this tow it home. Even if your other vehicle is a small car. throw a tow rope on it and get it home.
First of all are you still getting no lights? Or are the lights coming on but no cranking still
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Current for sale advertisement
anti tyler is offline   Reply With Quote
Old 08-23-2014, 03:49 PM   #3
Payableondeath6
No lights at all. Tried zip tying the battery ground down and it made no difference.
'95 240sx SE KA-T
GO NAVY!
Old 08-24-2014, 04:54 PM   #4
Payableondeath6
Got the car up and running now. Ended up being the ground and probably a bad cable end. Cleared off a new ground and bolted it down and I replaced the negative battery cable end and it started right up.
'95 240sx SE KA-T
GO NAVY!
