Old 07-05-2014, 09:01 PM   #871
d3x
d3x is an unknown quantity at this point
Thanks for the pics man...ill have to order my mvs and housing now :P.....
COuld youy get a clear pics of where you had to trim the motor mount?
d3x is offline   Reply With Quote
Old 07-19-2014, 06:06 PM   #872
Rb26kouki
Rb26kouki's Avatar
Trader Rating: (63)
Rb26kouki is an unknown quantity at this point
Feedback Score: 63 reviews
For the people running 3in inlet compressor housings what are you guys using for intake?
Rb26kouki is offline   Reply With Quote
Old 07-19-2014, 07:36 PM   #873
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
3" silicon elbow and then homebrew the rest.
I think a 90* works better than a 45* but it really depends on your ps high pressure line setup.
e1_griego is offline   Reply With Quote
Old 07-19-2014, 11:12 PM   #874
boost addict
boost addict's Avatar
boost addict is making a name for him/her selfboost addict is making a name for him/her self
Finally got my setup tuned after just cruising around on 8psi for like a year.
Car made 330whp on 20psi and didn't seem to be as responsive as I thought it was going to be. I believe the car was tuned a little rich just because of time restraints so I'm going back to lean it out a little and clean up the tune some and possibly up the boost. I am way more interest in response than an actual power number so Im just looking for ideas on what will help spool. Theres an event next weekend which will be my first with this tuned setup so I'll see how it feels. Some of the setup is..
GTX2863R at 20psi
93 pump gas
Peakboost turbo mani
Greddy style intake
PBM high mount IC
BC 264 cams
Stock compression
Been debating on going back to stock cams to shift the powerband back down as well as the OEM intake mani (or a different option) to help with low end power and tq
Someone embed this video for me cause it isn't working worth a damn haha
https://www.youtube.com/watch?v=-L1y_2isPHU
boost addict is offline   Reply With Quote
Old 07-19-2014, 11:17 PM   #875
unijabnx2000
unijabnx2000's Avatar
unijabnx2000 is an unknown quantity at this point
Im no expert, but i think something's not right.
20psi for that turbo with 264 deg cams sounds way low...
unijabnx2000 is offline   Reply With Quote
Old 07-19-2014, 11:18 PM   #876
Rb26kouki
Rb26kouki's Avatar
Trader Rating: (63)
I agree with this ^^ guy
Old 07-20-2014, 01:42 AM   #877
huffandpuff00
huffandpuff00's Avatar
huffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura about
boost addict, what exhaust housing are you using and do you have the dyno so we can see when you hit 20psi
huffandpuff00 is offline   Reply With Quote
Old 07-20-2014, 09:36 AM   #878
boost addict
I'll get the dyno sheet later but i have the smaller .63ar housing and if i remember correctly it hit 20psi right around 4k which I also thought sucked haha. I plan on boost leak testing my manifold setup and see if Im losing psi anywhere
Old 07-20-2014, 09:25 PM   #879
300kws13
300kws13 is an unknown quantity at this point
I just fitted and had had tuned a gtx2867r on my sr20.
Made 312kw (about 415hp) on 18psi and making full boost by about 3,600rpm. Absolutely stoked with how its going. Best turbo choice for an sr that i have come across so far.
300kws13 is offline   Reply With Quote
Old 07-20-2014, 09:26 PM   #880
Theyoung1.
Theyoung1. is an unknown quantity at this point
What's cams are you running more info on the set up please!
Theyoung1. is offline   Reply With Quote
Old 07-20-2014, 09:34 PM   #881
300kws13
Some of these brands are New Zealand made so you guys made now of heard of them.
JE Pistons
Eagle Rods
ACL bearings, head studs.
Cosworth head gasket.
Kelford cams full race port and polish
Tomei valve springs
Kelford 260 inlet and 266 exhaust with 11.5mm lift (lift is just as important if not more important than duration on SR's. Big duration cams do not nessisarily = big power.
Sinco customs exhaust manifold (look them up online they are awesome manifolds).
Tial 44mm v band wategate
3" full exhaust.
GTX2867r 0.63ar (i think) t25 style inlet and 5 bolt rear housing.
850cc injectors.
Standard intake mainfold and det throttle body.
Running rb25det gearbox.
Running link G1 ECU (again look up LINK ECU, best ECU's money can buy in my opinion.
Old 07-20-2014, 09:54 PM   #882
Theyoung1.
Awesome set up mate! And thanks for the info...
I'm running a s14 vtc sr jwt s4 cams
1mm bigger valves
wisco 9.1 87mm postons
Stock mani ported
T-31 t25 plus turbine housing moded for mvs 38mm gate
.63 ar 3in v band outlet
Gtx2867
Aeromotive a750 fuel pump and Nismo 740cc injectors I'm hopping to see 400 at 19 psi on 93 should be running in the next month
Old 08-02-2014, 08:37 PM   #883
xilovelsdx
xilovelsdx's Avatar
xilovelsdx is on a distinguished road
Send a message via AIM to xilovelsdx
Got some new toys
xilovelsdx is offline   Reply With Quote
Old 08-13-2014, 06:56 AM   #884
metako42
metako42 is an unknown quantity at this point
312kw at the wheels at 18psi? What kind of dyno was that? That sounds like the best result so far from this turbo. Could you post up a dyno chart?
metako42 is offline   Reply With Quote
Old 09-13-2014, 02:30 PM   #885
BlackZenkiS14
BlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond repute
Send a message via AIM to BlackZenkiS14
Well, even with all the weird issues I am having, car still makes good power!
-Kyle
BlackZenkiS14 is offline   Reply With Quote
Old 09-13-2014, 02:36 PM   #886
Tom N
Tom N is an unknown quantity at this point
That's a real nice dyno graph. How much boost?
98 240sx w/ S15 SR20DET, T2 20g, 11.22 @ 124.98
Tom N is offline   Reply With Quote
Old 09-13-2014, 02:48 PM   #887
BlackZenkiS14
Honestly don't know exactly, wasnt watching on dyno. But on the street its 19-20ish
-Kyle
Old 09-13-2014, 04:10 PM   #888
eDmSiL80
eDmSiL80 is an unknown quantity at this point
I have one of these for sale if anyone is interested just PM me.
eDmSiL80 is offline   Reply With Quote
Old 09-14-2014, 08:42 AM   #889
cotbu
cotbu's Avatar
KA
More like 22/24psi, if you were going there for diagnostics? you should have more data, knock, boost, afr, egt etc. With zero smoothing to compare with nds
I like it, but it looks more like a 2871r graph as compared to most gtx67r graphs, I've been seeing. The torque is lower, but stays true. That makes for a better powerband. Than the peeky mountainous dropoffs usually assoiciated with the gtx2867r imo.
Old 09-14-2014, 12:56 PM   #890
BlackZenkiS14
I dont think it would be 22-24psi, I've never run more than 20psi before at all.
It was a quick dyno day, so they weren't hooking up all the sensors. It was as quick $50 for 3 pulls.
They did do AFR, but it only worked properly for 1 of the pulls because they had issues with machine first pull, then the wideband blew out of the exhaust on the last pull...kind of a bummer.
But I need more fuel up top. Its fat down low, and leaner than I want to be up top.
-Kyle
Old 09-14-2014, 12:58 PM   #891
BlackZenkiS14
I'd love to catch your input on here though:
http://zilvia.net/f/showthread.php?t=568844
-Kyle
Old 09-15-2014, 02:06 PM   #892
angel mkiv
angel mkiv's Avatar
angel mkiv is an unknown quantity at this point
What spark plugs are you guys using that are in the 400hp range? Coppers or iridiums? And heat range 7 or 8 with good results?
Instagram username:angelmkiv
angel mkiv is offline   Reply With Quote
Old 09-15-2014, 03:14 PM   #893
BlackZenkiS14
I'm on 7's, currently coppers, but I've always run Iridium in the past, and will be changing these to Iridium as well.
-Kyle
Old 09-15-2014, 04:08 PM   #894
Tom N
I have been running BKR7eix's but will be switching to BKR8eix's once the new motor is broke in. I just run standard BKR6e's during break in.
Old 09-16-2014, 03:51 PM   #895
cotbu
cotbu's Avatar
Iridium plugs tend to burn through small contaminants, so they'll mask some problems. I run copper bkr7's, 400up
I did way in on your problem thread, but it was based on what I heard and your description of the issue, but if you switched from iridium to copper and then the issue occurred, then maybe Mike and I weren't that far off. Have you tried a different ecu?
Take a look in the cylinders after the issue occurs.
Or check the injectors for leaking or just a slow lazy injector.
Sent from my Highly Tuned Galaxy S3.5!!!
Old 09-16-2014, 04:27 PM   #896
BlackZenkiS14
Well, its had this problem the whole time since the new engine. But I may go ahead and throw a set of Iridiums in there like I used to run.
Havent tried a new ECU, I dont have anyone locally with the same setup to swap Rom tunes with.
Injectors should be good, they were just checked over and cleaned/flow tested by witch hunter just 1000 miles ago.
-Kyle
Old 09-16-2014, 09:46 PM   #897
BlackZenkiS14
Here is my graph with the AFR shown, and the smoothing set to 0. Looks like I need to find a way to add some more fuel after 5500rpm
GTX2867R w/ .64 hot side @ 20psi
-Kyle
Old 09-16-2014, 10:20 PM   #898
RalliartRsX
Trader Rating: (32)
RalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfection
Feedback Score: 32 reviews
^ Holy crap! Anything over 11.8 A/F in boost means you are sitting on a ticking time bomb! I am surprised the tuner didn't shut it off at about 6K RPM!
RalliartRsX is offline   Reply With Quote
Old 09-16-2014, 10:30 PM   #899
Tom N
That would really depend on what fuel he's running.
Old 09-16-2014, 11:06 PM   #900
cotbu
cotbu's Avatar
Im baffled and amazed at the same damn time. I would have expected to see more jagged peeks, with an afr plot like that. Have you looked at the fuel pressure regulator? Did your incar wideband look like that too? Or did it log different? Did you run out of injector? Was there any knock?
gt2871, gtx, gtx2867r
