Old 10-12-2004, 10:33 PM   #1
ihmeg
ihmeg is an unknown quantity at this point
Send a message via AIM to ihmeg
got my SR today
Alright tonight my SR arrived and everything looked ok and was accounted for in the order, ( ecu, uncut harness, ignitor ) but on the end of the transmition the circle is dented in a bit... is this bad?
also the shifter is stuck in what would i would guess to be 4th gear it seems like, is that normal or do i have a bad tranny?
I will try and get more information as i can but any help would be appriciated!!!
SR powered 1989 240sx
ihmeg is offline   Reply With Quote
Old 10-12-2004, 10:43 PM   #2
HaLo
from Canada, eh!
HaLo's Avatar
so you cannot shift at all? it's not normal.. your tranny might be fucked..
-> HaLo
Race Car: '98 E36 BMW M3
SOLD: 01 GPW Honda S2000
Old 10-12-2004, 10:50 PM   #3
silviasichigo
silviasichigo's Avatar
silviasichigo is an unknown quantity at this point
Well for shipping all the fluids have to be drained and depending on how long it was sitting after they drained the fluids is also a factor your gears could be so dried out that maybe a little condesation got in thurr and rusted something a little or it is just oxidized and stuck. The bent "Circle"....:P will be bad if you can insert the drive shaft and if it causes the rear seal.....not to....seal then yes it is bad.
silviasichigo is offline   Reply With Quote
Old 10-13-2004, 12:37 AM   #4
ihmeg
ok... so ... what should i do? this is just my luck....
Old 10-13-2004, 10:59 AM   #5
ihmeg
any ideas at all? i am really at a loss here
Old 10-13-2004, 05:52 PM   #6
Pepperoni
Pepperoni's Avatar
Pepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nicePepperoni is just really nice
Send a message via AIM to Pepperoni
Mine was a little hard to get out of gear at first but it was fine. Umm maybe try putting in oil and see if that helps at all (before you toss the tranny out). Worst comes to worse, just get a KA tranny and swap SR bellhousing
Turbo piping, Intakes and More:
http://www.pipingpro.com
Pepperoni is offline   Reply With Quote
Old 10-13-2004, 07:02 PM   #7
ihmeg
the shifter isnt just a little stuck though --- its a lot a bit stuck
somone suggested to me that i try and remove the tranny and reset the gears...but what part of the transmition do i remove the part that is on the block or the end near the shifter.... (im new sorry my terminology for some things arent accurate)
