Old 10-05-2014, 09:20 PM   #1
LuckyRPS13
LuckyRPS13 is an unknown quantity at this point
S13 SR20DET Black Top Part out
Located in Louisville KY, I am parting out most of a S13 SR20DET Black Top. Let me know what you want from it I may have it. I will post more details and pictures later.
Rocker Arm Stoppers for Nissan SR20DET $40
OEM Rocker Arms for Nissan S13 SR20DET $15 each
cas $100
O2 sensor $50
IACV $75.00
5 Speed transmission $350
Coilpacks $120.00
OEM Fuel rail with FPR $30.00
OEM upper oil pan $30.00
OEM lower oil pan $30
5 Speed transmission plate $25.00
Valve cover $50
SR20DET block $50 Sold along with most of what was left of the bottom end.
o2 housing $50
down pipe $80
o2 sensor has about 3000 miles on it and is still available.
OEM fuel rail with FPR $30
Timing set with 3k miles on it $30
Water neck $30
Turbo inlet and outlet $50
CAS $100
Power steering pump $80- Sold
Power steering Bracket $50 - Sold
or both pump and bracket $100- Sold
Coil packs $100 for the set or $30 each
Coil pack sub harness $30
Blitz BoV $125
Do you need;
Right side (USDM Passenger side) Replica S13 OEM Silvia Aero Bumper Grill
S13 Silvia J's, Q's, K's, A's Bumper grill inserts.
Male Plugs for S15 headlights
PM me if you need them.
LuckyRPS13 is offline   Reply With Quote
Old 10-08-2014, 08:20 PM   #2
LuckyRPS13
Bump to the top
Do you need;
Old 10-09-2014, 09:29 AM   #3
sr20drifter
sr20drifter's Avatar
sr20drifter is an unknown quantity at this point
How much for the tuned ecu shipped to 95961 and who was it flashed by.
sr20drifter is offline   Reply With Quote
Old 10-09-2014, 01:33 PM   #4
chrisbmx68
chrisbmx68 is an unknown quantity at this point
I am also interested in the ecu lmk your price.
-Chris
chrisbmx68 is offline   Reply With Quote
Old 10-09-2014, 02:14 PM   #5
adamhanna
adamhanna is an unknown quantity at this point
$40 shipped for rocker arm stoppers to v9t1v8?
adamhanna is offline   Reply With Quote
Old 10-13-2014, 02:17 AM   #6
LuckyRPS13
Sorry for the slow responses, been tied up for the past few days.
-Chris
$100 for the ECU and it was flashed by a shop called Raced Performance some where in Ohio.
I will check n cost of shipping but I will most likely lock it in for that.
Do you need;
Old 10-13-2014, 07:08 AM   #7
LuckyRPS13
ECU Sold.
msglngth
Do you need;
Old 10-13-2014, 11:08 AM   #8
s13shane
s13shane is an unknown quantity at this point
Fuel rail to 27513
s13shane is offline   Reply With Quote
Old 10-15-2014, 02:38 PM   #9
LuckyRPS13
Originally Posted by s13shane View Post
Fuel rail to 27513
$40 shipped
Do you need;
Old 10-15-2014, 02:46 PM   #10
s13shane
Pm'd about fuel rail
Old 10-16-2014, 09:03 AM   #11
LuckyRPS13
Bump to the top
Do you need;
Old 10-17-2014, 09:57 AM   #12
LuckyRPS13
Block, used crank, oil pans, misc other items all sold
Do you need;
