Old 10-18-2004, 11:11 AM   #1
XXX4life
XXX4life is an unknown quantity at this point
Send a message via AIM to XXX4life
car won't start after swap
The car is 90 240 that had asingle cam. Swappped in a dual cam following the article in the tech section. Fuel and spark is good. Timing is fine. Compression is fine. The engine will give me a little sputter than nothing. Just cranks. Swapped out for some non fuel fouled plugs and the still the same issue. I tried searching to see if there is a common sensor that goes bad hat won't allow it to start. I don't yet have the consult plug to wire in. All grounds are attatched and secure. I have one plug over buy the coil that is not being used. Its a 2 pin with a brown and a black wire. Any thing I'm missing? Thanks
04 Scion xb
90 240sx (ka24de)
www.entrustclothing.com
XXX4life is offline   Reply With Quote
Old 10-18-2004, 12:28 PM   #2
andrave
andrave's Avatar
andrave is an unknown quantity at this point
Send a message via AIM to andrave
I dunno mine sounds pretty much the same as yours. how is your timing? maybe the dist. is off a tooth? thats pretty common...
andrave is offline   Reply With Quote
Old 10-18-2004, 12:59 PM   #3
XXX4life
the timing seems to be fine and even if it's off it shouldn't bee of enough for it not to run, right now i don't know what to do, i'm beyond mad
04 Scion xb
90 240sx (ka24de)
Old 10-18-2004, 09:58 PM   #4
andrave
andrave's Avatar
yeah thats the same shit mine was doing too... timing should have been close enough to turn over... *shrugs*
if you figure it out tell me, cause I need to get mine running as well.
Old 10-18-2004, 10:37 PM   #5
XXX4life
i'm gonna set the motor to TDC and check the Distributor, i think it might be off that's the only thing i can think of
04 Scion xb
90 240sx (ka24de)
Old 10-18-2004, 11:37 PM   #6
phrozen
phrozen is on a distinguished road
Send a message via AIM to phrozen
:hammer: :hammer: :hammer:
This box is 400x200:
Please do not put your sig pic back if it exceeds this.
-Moderation
phrozen is offline   Reply With Quote
