Old 11-30-2014, 12:14 PM   #1
Almosttt
Almosttt is an unknown quantity at this point
Refinishing/Restoring wheels
Recently picked up a set of 350z wheels for pretty cheap but they've all got a bit of curb rash. I'm looking at refinishing/restoring them, I've found a couple DIY's but I wanted to see if anyone could share their personal experience with doing so before I get started and accidentally ruin a set of wheels.
Any tips/tricks..?
The DIY I found suggested using Bondo to fill in spots, but that seems kind of sketchy to me... should I use some type of aluminum filler?
Here is one of the DIY's I found...
http://my350z.com/forum/wheels-and-t...storation.html
Almosttt is offline   Reply With Quote
Old 11-30-2014, 12:52 PM   #2
silviaks2nr
silviaks2nr's Avatar
Grind it down and smooth it out. I've found that a paint remover 4 1/2" disk works well for smoothing aluminum after the initial grind. That filler stuff doesn't really work unless you have an acetylene torch. Once it's powdercoated you won't be able to tell where the repair was done if you do it well.
Old 11-30-2014, 01:33 PM   #3
pancakes
pancakes's Avatar
pancakes is an unknown quantity at this point
bump. same scenario on my z wheels. and my fronts seem to have just a bit more "shine" than my rears?
WTB s14 abs 5 speed drive shaft and vlsd
pancakes is offline   Reply With Quote
Old 11-30-2014, 03:44 PM   #4
Kingtal0n
Kingtal0n's Avatar
On this subject, I have these,
I was wondering what kind of coating they have? is it a clear coat? And how to best "finish it" or "protect it"
Old 11-30-2014, 06:35 PM   #5
KAT-PWR
KAT-PWR's Avatar
KAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really niceKAT-PWR is just really nice
JB weld, sand smooth
But if powder coating your only option is to sand the rash out, or weld and sand which would be a ridiculous amount of time.
MRP Manufacturing
KAT-PWR is offline   Reply With Quote
Old 11-30-2014, 07:07 PM   #6
shinhed
shinhed's Avatar
shinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of lightshinhed is a glorious beacon of light
I've used JB weld before, and supposedly you can powder coat over it too.
shinhed is offline   Reply With Quote
Old 11-30-2014, 10:18 PM   #7
DanielS14
DanielS14 is an unknown quantity at this point
i repair wheels, do not add a a filler. just sand smooth and repaint, i do this on lexus, bmw, lambo, ferrari , you name it wheels all day.
DanielS14 is offline   Reply With Quote
Old 11-30-2014, 10:24 PM   #8
Almosttt
Could you give an in depth description of your process please?
Old 12-01-2014, 04:34 AM   #9
AzS13hatch
AzS13hatch is an unknown quantity at this point
Use coarse grit to sand down worse areas and and fine grit to smooth to factory like finish. It might have a little dip in it when you are done in that area but if you blend everything well enough you will never be able to tell, especially if you powdercoat. If you want to spend some money have a profession do it and they can add to low spots and balance the wheel and make sure it is true for you.
AzS13hatch is offline   Reply With Quote
Old 12-01-2014, 08:37 AM   #10
Bushido
Bushido's Avatar
any tips for refinishing wheel bolts?
or know of a supplier to get black anodized hardware?
Old 12-01-2014, 08:51 AM   #11
tiemouths
tiemouths is an unknown quantity at this point
tiemouths is offline   Reply With Quote
Old 12-03-2014, 09:56 PM   #12
Chicago_one
Chicago_one is an unknown quantity at this point
I've done the sand/filler/spray paint/clear coat route But I only payed $80 for the set of wheels, so it wasn't a big deal. So far so good. Been about a year.
Chicago_one is offline   Reply With Quote
Old 12-07-2014, 11:38 AM   #13
Bmx240sx
Bmx240sx's Avatar
Bmx240sx can only hope to improve
Air craft remover, sand down as evenly as possibly if not use some body filler there's isn't a big deal if using it, sand it smooth and as straight as possible, paint and clear.
Bmx240sx is offline   Reply With Quote
