Old 12-08-2014, 07:45 PM   #1
Reeefo
Reeefo is an unknown quantity at this point
Timing Chain Guide Broke
Hey guys, so my timing chain guide was broken when i bought it and the chain doesnt rattle. I needed to drive to san francisco to la this thursday and was wondering if its okay?
Reeefo is offline   Reply With Quote
Old 12-08-2014, 08:03 PM   #2
Rustys14
Rustys14's Avatar
Rustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of lightRustys14 is a glorious beacon of light
I'm assuming you have a single cam ka since they have the most issues with the guides. To answer your question its doable but not suggested as there is a water jacket in the timing cover that the chain will eventually eat into if you drive with without the guide for too long (I'm not sure if the jacket is located in the same spot on twin cams or sr20s). Another reason that I would advise against it (with any motor) is because all of the little pieces of the timing guide are now in your oil pan and can clog your oil pickup causing pressure issues.
Originally Posted by bossin240 View Post
I have a pretty badass neon.
Rustys14 is offline   Reply With Quote
Old 12-08-2014, 10:31 PM   #3
chato de shamrock
chato de shamrock's Avatar
chato de shamrock is an unknown quantity at this point
Originally Posted by Rustys14 View Post
I'm assuming you have a single cam ka since they have the most issues with the guides. To answer your question its doable but not suggested as there is a water jacket in the timing cover that the chain will eventually eat into if you drive with without the guide for two long (I'm not sure if the jacket is located in the same spot on twin cams or sr20s). Another reason that I would advise against it (with any motor) is because all of the little pieces of the timing guide are now in your oil pan and can clog your oil pickup causing pressure issues.
Wait, so driving without the timing guides is bad? I also have to open up my engine to take care of these and have been reading up on it. Until your comment I've only read they should be removed and left out. Even read a comment or two that the Nissan shop workers advise they are useless and you should just remove them when the rattling starts.
chato de shamrock is offline   Reply With Quote
Old 12-08-2014, 11:05 PM   #4
Primo's Silvia
Primo's Silvia's Avatar
Primo's Silvia is an unknown quantity at this point
The reason why u have/had timing chain slap was due to your chain being old and a lil stretched, i have a Dohc ka my upper guide was already removed and it was slapping the second one so i removed it and i have had no problems at all, i do constant oil changes and havnt seen any noticable shavings, some say diffrent i am just saying what i expirenced.
Originally Posted by adams 02rs View Post
Here yee have found zilvia...WELCOME TO HELL.
Primo's Silvia is offline   Reply With Quote
Old 12-08-2014, 11:14 PM   #5
Reeefo
Yeah i just took out my oil pan today and cleaned that shit out. thats how i found out it was broken. But i plan on getting a new kit from amazon for their evergreen kit. yes i do have a ka24e
http://www.amazon.com/gp/product/B00...06R8QG6HEH745Q
Old 12-09-2014, 11:27 AM   #6
Rustys14
Rustys14's Avatar
We're talking about different guides. It is perfectly fine and recommended to remove the upper guide on the early DE motors. The guide that the OP is speaking of is the main guide that along the chain from the block to the head. The main guide is fairly important and should not be removed. Nissan had issues with the plastic guide breaking changed the design to include a metal backing sometime in the mid to late 90s (I forget the exact date of the change over). Nissan even issued a service bulletin about this for the SOHC motors but never did a recall, instead they called it "recommended service".
Old 12-09-2014, 11:38 AM   #7
Rustys14
Rustys14's Avatar
That kit should be fine since it has the updated metal backed guide. Most people on here will recommend that you stick with OEM timing components but I haven't had any issues with the aftermarket stuff in the past. I've used them fairly often to since I have had to put the updated guides on EVERY single cam I've owned lol.
