Old 08-12-2014, 06:36 PM   #1
teddyjr
teddyjr's Avatar
teddyjr is an unknown quantity at this point
RB25DET Tachometer Recalibration for S14
In my pre-made RB25DET-to-S14 conversion harness, Wiring Specialties provided a how-to for recalibrating the S14 tach. The ECU shows 900RPM and the tach reads 1100ish. Anyway, the instructions read, "...The adjustment screw will be in the back of the tach-no need to take the face of the gauges is needed..."
Aside from the freaky grammar, this seems straightforward, but before I pull the tach I thought I'd ask if anyone has a photo showing the location of the potentiometer trim screw? I'd rather know what I'm looking for before pulling the cluster back out. Mr. Google (web and images), and Zilvia/Nico search have revealed nothing of value.
Thanks in advance!
teddyjr is offline   Reply With Quote
Old 11-20-2014, 09:17 PM   #2
rodneyfromtrini
rodneyfromtrini is an unknown quantity at this point
bumping old tread. I would like to see the location of the adjustment screw as well.
rodneyfromtrini is offline   Reply With Quote
Old 11-20-2014, 09:30 PM   #3
Yellow4g63
Yellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of light
Send a message via AIM to Yellow4g63
I adjusted my S14 tach and you won't see it untill you take out the tach from the cluster and jumper it to make it work while you adjust it. small phillips screw.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Yellow4g63 is offline   Reply With Quote
Old 12-29-2014, 11:27 PM   #4
Steve15
Steve15's Avatar
Steve15 is an unknown quantity at this point
Anyone know if this method will work for s15? Or if s15 has a potentiometer as well?
Steve15 is offline   Reply With Quote
Old 12-29-2014, 11:39 PM   #5
feito
feito's Avatar
feito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymore
i dont know, but if my mind serves me right, on my 98 i didnt use jumper wires, i just removed the speedometer and gained access to the adjustment screw. And if I remember correctly, some earlier s14's have the adjustment screw on the back.
feito is offline   Reply With Quote
Old 12-30-2014, 04:37 PM   #6
Steve15
Steve15's Avatar
S15 doesn't have anything like that on the cluster, I checked Sorry to thread jack, but does anyone know how to make RB25 tacho work for s15?
calibration, rb25det, s14, tachometer
