Old 01-10-2015, 02:02 PM   #1
bogaabogaa
bogaabogaa is an unknown quantity at this point
trans grind after engine and trans swap
Hi guys trying to troubleshoot why my trans is grinding after a engine and trans swap from another s14 that was well running and im at a loss any help or ideas would be helpful. Thanks
bogaabogaa is offline   Reply With Quote
Old 01-10-2015, 02:29 PM   #2
g14novak
g14novak is an unknown quantity at this point
Did you install the engine with the trans in the car?
g14novak is offline   Reply With Quote
Old 01-10-2015, 03:44 PM   #3
bogaabogaa
pulled the engine and trans from a well running car and swapped it in another same year 240 then noticed she started to grind
Old 01-10-2015, 04:27 PM   #4
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
Did you drive the donor car first?
Did you ever have the new trans off of the engine?
Did you put fluid back in it?
Is the fluid level correct?
Could you bother to provide us with ANY information???
Old 01-10-2015, 04:34 PM   #5
bogaabogaa
I owned the donor car for a few months had no problems
the engine and trans was pulled from the car together and neveroff the engine
yes replaced all fluids before i drove the car and fluids are at the correct levels
what type of information do you need?
thanks for the help
Old 01-14-2015, 01:32 PM   #6
rebornS14
rebornS14's Avatar
rebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of light
Send a message via AIM to rebornS14
what fluid did you use? you can't use GL5 fluids on our cars. that'll eventually f-up the synchros
rebornS14 is offline   Reply With Quote
Old 01-14-2015, 09:46 PM   #7
r20crazy
r20crazy's Avatar
Trader Rating: (41)
r20crazy is an unknown quantity at this point
Feedback Score: 41 reviews
try adjusting ur clutch pedal under the dash. sounds like its not fully disengaging so u need more travel at the slave by adjusting clutch master pushrod length at pedal under dash for more travel. the 2 cars pedals probably were adjusted differently for different clutches and/or wear
welcome
Originally Posted by Your240sucks;
Dont really want to lowball you but Will you pay me too pick it up?
r20crazy is offline   Reply With Quote
Old 01-14-2015, 10:07 PM   #8
angel mkiv
angel mkiv's Avatar
angel mkiv is an unknown quantity at this point
Did you replace the throw out bearing?
Instagram username:angelmkiv
angel mkiv is offline   Reply With Quote
Old 01-15-2015, 08:50 AM   #9
supersayianjim
supersayianjim's Avatar
supersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enoughsupersayianjim will become famous soon enough
and did you brace your transmission with a good/new rubber mount?
supersayianjim is offline   Reply With Quote
Old 01-15-2015, 01:25 PM   #10
NoFlex
NoFlex is an unknown quantity at this point
hoping you used gl5 fluid.. and how much fluid did you use?
NoFlex is offline   Reply With Quote
Old 01-16-2015, 08:57 AM   #11
Agamemnon
Agamemnon's Avatar
Our transmissions take gl-4 fluid.
Old 01-16-2015, 10:06 AM   #12
SaUcEy
SaUcEy's Avatar
SaUcEy is an unknown quantity at this point
^^ This. GL5 will cause syncro issues as the additives cause corrosion on Nissan bronza syncros.
Its too early for that in this situation though. Check fluid level first and foremost. And unfortunately you may have a syncro issue..
SaUcEy is offline   Reply With Quote
