Old 01-15-2015, 07:08 PM   #1
Javi802
Javi802's Avatar
Javi802 is an unknown quantity at this point
fuel pump prime when car is off.
Have any of you ever had this happen?
Sometimes, when ever i shut my car off and take the key out of the ignition, it sounds as if my fuel pump will prime...
And just last night when i was putting my rear shocks in, out of nowhere i hear what sounds to me like the fuel pump, priming. Keys weren't in the ignition. Only ever started recently..
Is this common on a faulty fuel pump?
Javi802 is offline   Reply With Quote
Old 01-15-2015, 08:25 PM   #2
kojiki88
kojiki88's Avatar
kojiki88 is an unknown quantity at this point
Same thing has happened to me. I have a Walbro 255 and a few months ago it did that so I changed my fuel pump out thinking it was that(4-5 years old). Put in the new one and everything seemed fined until it did it again, doesn't do it all the time and the car drives fine on and off boost so I stopped worrying about it.
kojiki88 is offline   Reply With Quote
Old 01-15-2015, 09:23 PM   #3
Ilya
Ilya's Avatar
Ilya is an unknown quantity at this point
Happens to me too. I can't decide though whether it is the pump or the auto antenna. Ask me how much I care
Ilya is offline   Reply With Quote
Old 01-15-2015, 10:19 PM   #4
pacotaco345
pacotaco345's Avatar
pacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond repute
fuel pump continues running for 5 seconds after your car is shut off
pacotaco345 is offline   Reply With Quote
Old 01-16-2015, 07:25 AM   #5
Javi802
Javi802's Avatar
so do you know why it would randomly run, out of nowhere?
My car had been off for a few hours and i was underneath it doing some stuff and all of a sudden i hear the fuel pump.
Old 01-16-2015, 07:34 AM   #6
Ilya
Ilya's Avatar
You are not the only one this happens to.
Old 01-16-2015, 07:41 AM   #7
Javi802
Javi802's Avatar
Lol alright. I just thought it was weird. Ive had the car for 3 years and its never happened before. 2 years with a ka in it and going on one year with the sr
Old 01-16-2015, 07:55 AM   #8
Ilya
Ilya's Avatar
Yeah man. Mine just randomly started doing it and does it randomly. I'm still scratching my head why it would it at random times. I think mine is also ambient temperature dependent.
I've had crazy theories like air particles charging one of two capacitive plates aka body panels and then them discharging or, since my car is a vert, static charge building on the fabric and being released when I close the circuit somehow. Who knows
Old 01-16-2015, 01:01 PM   #9
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
no it doesnt, well it shouldnt, the process is as follows, KOEO=fuel pump prime for ~5 seconds, without a crank,camangle sensor detected by the ECU fuel pump shuts off via the ECU. SO if your pump continues to run longer then 5 seconds with NO crank/camangle sensor, OR runs when you key off, then either the ECU has a fault, the fuel pump relay is sticking, OR there is a wiring issue. This is all based on the assumption that the wiring in the car is stock (unmodified)
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 01-16-2015, 06:18 PM   #10
Javi802
Javi802's Avatar
Well the engine harness is a wiring specialties. Everything else has been left alone.
A new, bigger fuel pump was wired in when i first did the swap
