Old 03-14-2015, 11:07 AM   #1
Agamemnon
Agamemnon's Avatar
Z32 caliper bridge bolt size
Hi everyone. Yesterday I noticed that one of my bridge bolts that holds the 2 halves of the caliper together had backed out and is now gone and lost for the ages. The other 3 have been re tightened and seems to be keeping everything in good order. I need to find a replacement for the 4th bolt. However Nissan doesn't list this with a part number because the caliper isn't supposed to be split. My question for everyone is, what are the specs for this bolt? Anyone know the length, diameter, thread pitch, etc? I don't want to take off another bridge bolt for fear further damaging the caliper. Has anyone with crap caliper laying around can take some measurements for me?
Old 03-14-2015, 01:58 PM   #2
robinsone
robinsone is an unknown quantity at this point
I can get you some measurements later today if no one else chimes in...
robinsone is offline   Reply With Quote
Old 03-14-2015, 04:23 PM   #3
Agamemnon
Agamemnon's Avatar
If you could, that would be great!
Old 03-14-2015, 05:38 PM   #4
DJ 21o3
DJ 21o3 is an unknown quantity at this point
Blah, I see what you mean with how they don't list it. If the other guy doesn't get a measurement to you, i might be able to later.
DJ 21o3 is offline   Reply With Quote
Old 03-14-2015, 05:42 PM   #5
Agamemnon
Agamemnon's Avatar
You're thinking of the bolt that secures the caliper to the hub. The bridge bolt is not represented on that page.
Old 03-15-2015, 06:37 AM   #6
robinsone
m10 x 1.25 pitch
length of the bolt including head is 106.75mm
length of shank and thread 96.5
threads are 31.5mm
So any 14mm m10x1.25x100 should work (100 being 100mm in length). Bear in mind you will probably have to get a separate washer so that will reduce the length by a few mm. I've found it hard at times to find those flange bolts in certain sizing.
Look around and see, I'm sure you can easily find a replacement that will work.
Old 03-15-2015, 12:14 PM   #7
Agamemnon
Agamemnon's Avatar
Thank you a million time over! That information is perfect. I should be able to find something to make it work. Thanks again.
Old 02-28-2019, 07:30 AM   #8
Willied
Willied is an unknown quantity at this point
https://www.clipsandfasteners.com/1-...-p/pm33327.htm
This Bolt Works, Just need to the Add some threads
Willied is offline   Reply With Quote
Old 02-28-2019, 02:53 PM   #9
97nismo
97nismo's Avatar
Trader Rating: (53)
97nismo is an unknown quantity at this point
Feedback Score: 53 reviews
Old thread......
Feedback:
http://zilvia.net/f/itrader.php?u=78978
97nismo is offline   Reply With Quote
Old 02-28-2019, 03:23 PM   #10
drfftn
drfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond reputedrfftn has a reputation beyond repute
guys this thread is 4yrs old
drfftn is offline   Reply With Quote
