Old 04-03-2015, 09:21 PM   #1
jxw
jxw is an unknown quantity at this point
vet 1000HP part out
Parting... ADDED SOME PARTS
VVL and other parts
-S15 motor - SOLD
This was the last block Tanner Faust drifted with when sponsored by Nissan. Big Tom built it for him, and it is done as well as any sr20 block you will ever find. It has Darton sleeves installed at 1 degree off vertical to improve torque curve. Bored to 89mm for effectively a 2.15L displacement. It has the pulsar lightened crank. Pauter X-beam rods, considered even better than the Manley Turbo rods. CP pistons at 8:1 comp, with gassing holes drilled for ring expansion under pressure, and enlarged wrist pins. It uses Bluebird squirters, has custom pin hole galleys added for better oiling. Freddy larger oil pan, Primera pick up tube, etc. 1/2" Mustang head studs. VE oil pump decked with block, and shimmed pulley for alignment. Lightened pulley set, etc etc...
-VET head - SOLD
Lightly polished, coated with a heat treat, has N1 cams, supertech higher rate dual valve springs, retainers and valve stem seals. All coolant and oil holes drilled and tapped for prep on a rwd application. Valve cover has 4 -10an bungs tigged in for pressure vent piping
- Stock VVL head - $SOLD
Has the holes drilled/tapped where applicable for rwd configuration
-N1 cams - $SOLD
They have been installed but zero miles
-Xcessive VET intake mani - $SOLD
-740 Injectors - $SOLD
-VET water neck relocation setup - $SOLD
-S15 block, head and trans. - $1200
I dont have a clutch for this set. Also I can give you a wiring harness with it, but it is not super clean anymore as it has been used in a VET with stand alone setup, so it has some mods.
-KA trans - $SOLD
-Z32 manual trans with Mazworks adapter kit - SOLD
Good shifting all gears Z32 tt manual trans. Bell housing machined, Maz SRVG adapter plate, trans mount, and shifter. Upsized 4" drive shaft. All in good working order, only 20 or so dyno pulls and maybe 5 miles on the street
-Spec triple plate clutch - $SOLD
Again, 20 dyno pulls and 5 miles on the street. One pass down the track at a 600HP setup turned a 6 puck ACT clutch to shrapnel. This clutch will hold much more. MSRP about $1400
-AEM gen 1 stand alone - $SOLD
-AEM twinfire and pencil coils - $SOLD
-Garrett gt4202r ball bearing turbo - $1350
-Full Race mani with single 44mm wastegate flange - $SOLD
-Tial 44mm wastegates, silver color, cant remember but think they have about a 12# spring - $SOLD
-BJ's customs Intake mani with dual fuel rails (8 injectors), set up for VE head in RWD configuration - SOLD
-Injector Dynamics 1000cc injectors - qty 8 - set of 4 for $400
-Tial 50mm BOV with pipe - $SOLD
-3" intercooler, Hybid brand, but has never leaked and fins in good shape - $200
-Primera cam angle sensor - $SOLD
-Primera VVL solenoids with relocations blocks - $SOLD
-XS Power S1600 16V battery, brand new -$200
-XS Power 16V charger - $150
-16V high capacity alternator - $150
-Q45 throttle body - $SOLD
-Deist parachute & release cable - $250
-5" bellmouth intake with 5" pipe to feed gt42 turbo - $100
-10" x 6" x 4" pressure relief box with 4 -10an inlets and 1 drain. 3 large K&N filters. All tigged, aluminum construction - $150
-Koyo radiator with FAL 210 fans - $240
-Custom 4" downpipe with Vband - $SOLD
-Full 4" exhaust with vbands. Catless and no muffler - $SOLD
-Bosch 044 inline pumps - qty 2 - $140 ea
-Aeromotive pre-pump filters - qty 1 -$60 ea
-Aeromotive post-pump filters - qty 1 - $60
-Aeromotive FPR - $SOLD
-Subframe with solid subframe bushings - $SOLD
-Driveshaft Shop 1000HP axles - SOLD
-Mechanical 1.5 (I believe) diff. Cant remember the details on the diff - $SOLD
-Fortune Auto coilovers - Basically new. Spring rates I believe are 8K front, 5k rear. Have additional 6K springs for rear. Perfect condition except 1 small scuff, otherwise like new. - $800
Z32 front calipers, rotors, aluminum 30mm - $SOLD
-Isis arms package, 0 miles but mounted - $SOLD
-Sway bars- suspension techniques - $SOLD
-5zigen fnolr-c in gray, with good rubber all around. 7.5" front, 9" rear, 17". 4 bolt pattern. Front rubber is Kumho ecsta 225's and rears are mt drag radials 275's. All rubber about 90% tread, rims in excellent shape, metallic gray color - $SOLD
-Mickey Thompson drag slicks & Greg Weld wheels, 10.5 x 26, 15s walls for more stability at speed. 15" diam x 10" wide, 4 114.3 Brand new, only mounted - $500
-Spearco racing seats - blue with 5 point harnesses, good condition - $200
-S13 stock gray front seats - $SOLD
-spare s13 front bumper - $40
-Auto Meter pro comp white 30psi boost gauge - SOLD
-AEM UEGO - $SOLD
-Auto Meter pro comp white oil temp gauge - $50
-Auto Meter pro comp white nitrous pressure gauge - $SOLD
-Auto Meter pro comp 11K tack - $125
Nitrous express kit with full 10# bottle and 75 nozzle - $SOLD
-AEM MAP 5 bar sensor - $50
-AEM AIT sensor - $SOLD
-Grex Greddy S14/S15 oil filter relocation kit - $SOLD
- Shell - $SOLD
pm or text with questions
josh
801.831.2369
jxw is offline   Reply With Quote
Old 04-04-2015, 10:29 AM   #2
kleenS14
kleenS14's Avatar
kleenS14 is an unknown quantity at this point
Goood gawd, free bump for you sir....straight gnarly and ridiculously good prices as well.
kleenS14 is offline   Reply With Quote
Old 04-06-2015, 11:48 PM   #3
GTR_240SX
GTR_240SX's Avatar
GTR_240SX is an unknown quantity at this point
I'm interested on the wastegate pm please!!!!
GTR_240SX is offline   Reply With Quote
Old 04-07-2015, 10:48 AM   #4
dans14.5
dans14.5's Avatar
dans14.5 is an unknown quantity at this point
Can the intake manifold work for an s14 sr?
dans14.5 is offline   Reply With Quote
Old 04-07-2015, 12:36 PM   #5
PeaceOnesxWai
PeaceOnesxWai's Avatar
Trader Rating: (34)
PeaceOnesxWai is an unknown quantity at this point
Feedback Score: 34 reviews
^Intake is for a VE head, wont work on SRDET
wish I have money for the block and head.. great f-ing deal!
PeaceOnesxWai is offline   Reply With Quote
Old 04-07-2015, 01:13 PM   #6
jxw
Correct, intake mani for VE/VET head. Thanks for bumps! PM's replied to.
Old 04-07-2015, 11:44 PM   #7
carsfreak88
carsfreak88 is an unknown quantity at this point
You have a pm
carsfreak88 is offline   Reply With Quote
Old 04-13-2015, 08:35 AM   #8
jxw
Lots of parts still for sale, some new parts added 4/13
Old 04-13-2015, 02:12 PM   #9
kasperjd4
kasperjd4 is an unknown quantity at this point
Did you get my PM?
kasperjd4 is offline   Reply With Quote
Old 04-14-2015, 08:07 AM   #10
jxw
pm's sent. still have a vet head, with all the accessories, and an s15 block & head, etc etc.
Old 04-15-2015, 10:44 AM   #11
claine650
claine650's Avatar
claine650 is an unknown quantity at this point
Payment sent, thanks alot!
claine650 is offline   Reply With Quote
Old 04-21-2015, 08:12 AM   #12
TurboBGN
TurboBGN is an unknown quantity at this point
Great seller and ships faster than anyone! Thanks man!
TurboBGN is offline   Reply With Quote
Old 04-21-2015, 06:03 PM   #13
doxie
doxie is an unknown quantity at this point
Pictures of the slicks an rim am interested
doxie is offline   Reply With Quote
Old 04-21-2015, 10:25 PM   #14
jxw
added a few of the slicks, text me if you want more
Old 04-21-2015, 11:10 PM   #15
1988montecarloss
1988montecarloss's Avatar
Trader Rating: (24)
1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute1988montecarloss has a reputation beyond repute
Feedback Score: 24 reviews
sell the RUCA's seperate?
IG: @Haley72692
1988montecarloss is offline   Reply With Quote
Old 04-22-2015, 04:31 AM   #16
doxie
The rims is 15x? what's the width of the rim
Old 04-22-2015, 08:19 AM   #17
jxw
15x10" wide, they are the greg weld's. The rubber is the 3053S, 26x10"
Old 04-24-2015, 07:37 PM   #18
jxw
Just saw an add on Zilvia of a VVL rwd kit that sold for ~2k a couple days ago, without CAS!!
People this stuff is all in this add:
-VVL head (already has taps where necessary for rwd, valve cover has tigged bungs for crank case venting) - $600
-Xcessive intake mani (will actually fit under your hood cause I milled the flange at a slight angle) - $300
-Fullrace exhaust mani, single 44mm - $700
-VVL water neck reloc - $50
-Mazwork reloc blocks WITH VVL solenoid and all stainless lines & fittings - $120
$1770 for same parts +/-
Add in the CAS (+300) and your at $2070
Then I give you a discount for buying a bunch of stuff together or ship for free, etc etc
I need a marketing degree, ha ha
Old 04-28-2015, 08:51 AM   #19
usrocket
usrocket is an unknown quantity at this point
Bump for a great seller
usrocket is offline   Reply With Quote
Old 05-11-2015, 07:35 PM   #20
jxw
Bump it one more time, still a bunch of high end and little parts. Will ship anywhere continental US
Old 05-12-2015, 09:41 AM   #21
TheRealSy90
TheRealSy90's Avatar
Any information available about installing the sleeves 1 degree off vertical? Never heard or even read of that before. Is this some secret tech?
Such a good signature.
Old 05-12-2015, 01:31 PM   #22
jxw
Big Tom prescribed it, under the premise it offers a better torque curve. It seemed to me it would put more strain on the rotating assembly, but I had no issues and sure enough, plenty of torque.
Other than that, I took him at his word. He was Tanner Fausts personal engine builder for years, and now is privately employed by Porsche drivers for the GT3 cup series. He also was the one who initially gave Mazworx the info on the rwd VVL swap. Good credentials...
Old 05-12-2015, 02:18 PM   #23
LuckyX2
LuckyX2's Avatar
LuckyX2 is an unknown quantity at this point
I'll take the water neck relocation and solenoids with adapter plates.
Would have taken the VET head too, lucky guy whoever got that.
Texting you now.
My S13 SR Street Mod Build
LuckyX2 is offline   Reply With Quote
Old 05-12-2015, 07:24 PM   #24
outlawstar1023
outlawstar1023 is an unknown quantity at this point
Send a message via AIM to outlawstar1023
free BUMP.
Great guy!
Received the intake manifold and N1 cams in 2 days as described.
outlawstar1023 is offline   Reply With Quote
Old 06-17-2015, 04:39 PM   #25
jxw
bump. Still have a bunch of high end parts:
-almost new garrett gt4202
-Full race exhaust mani
-VVL head & conversion parts
-s15 block/head/5 sp trans
-740 nismo injectors for great price
-1000cc ID's set of 4
-almost new fortune auto coilovers
-aem twin fire & pencils
etc etc etc
hit me up with offers
Old 06-18-2015, 06:09 PM   #26
hashim
hashim is an unknown quantity at this point
Gimme that s15 bare block josh! ima need help when i do my 2.2 stroker ve setup!
hashim is offline   Reply With Quote
