Old 11-01-2004, 10:55 PM   #1
import_racer87
import_racer87 can only hope to improve
please explain this turbo setup to me
i was always under the impression that the intake pipe from the filter went to the hole in the turbo where you can see the compressor but ive seen a lot of setups that look like this (that hole is just left open)
how does this work? do people run without filters or is there a filter somewhere in there?
import_racer87 is offline   Reply With Quote
Old 11-01-2004, 11:12 PM   #2
NZO
NZO's Avatar
NZO is an unknown quantity at this point
Send a message via AIM to NZO
Most likely a blowthrough setup where the map/maf is placed after the cold side of the turbo and before the intake manifold.
sentinelguild.com/nzo/PFCDB/
NZO is offline   Reply With Quote
Old 11-02-2004, 12:19 AM   #3
silviasichigo
silviasichigo's Avatar
silviasichigo is an unknown quantity at this point
He probably just went Air flowless using the MAP sensor instead of the MAF sensor. That is how my set up is.
silviasichigo is offline   Reply With Quote
Old 11-02-2004, 12:46 AM   #4
import_racer87
but where is the air filter in this setup?
Old 11-02-2004, 12:53 AM   #5
240Stilo
Junkie
240Stilo's Avatar
240Stilo is an unknown quantity at this point
Send a message via AIM to 240Stilo
They decided not to use a filter in this setup. It usually goes where you mentioned before. Just that he/she wants to be living on the edge without it.
-Juan
240Stilo is offline   Reply With Quote
Old 11-02-2004, 02:44 AM   #6
mrmephistopheles
mrmephistopheles's Avatar
What 240Stilo said. Better for suction, worse for turbine longevity.
Originally Posted by PHLIP
Old 11-02-2004, 02:51 AM   #7
blu808
blu808's Avatar
blu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfectionblu808 is close to perfection
Send a message via AIM to blu808
What mrmephistopheles said also goes for the motor.
No filter = Motor crapping out quicker.
blu808 is offline   Reply With Quote
Old 11-02-2004, 10:22 AM   #8
Eternal_240Sx
Eternal_240Sx's Avatar
Eternal_240Sx is making a name for him/her selfEternal_240Sx is making a name for him/her self
I can see how this set up would reduce the life of the turbo but can someone explain to me how this would effect the life of the motor?? thanks
Eternal_240Sx is offline   Reply With Quote
Old 11-02-2004, 10:33 AM   #9
Ritz S14
Ritz S14's Avatar
Debri will enter the turbo and circulate to the combustion chamber causing valves and cylinder wall damage.
Ritz S14 is offline   Reply With Quote
Old 11-02-2004, 10:33 AM   #10
Jeff240sx
I hate you too...
Jeff240sx's Avatar
What goes in must... go in further.
They probably don't drive around on the street like that. It's a dyno shot or something.
On high powered MK4s, at around 1000hp, you can pick up 40rwhp by removing the air filter. Even if it was the best flowing filter on the market. That's why they do it.
-Jeff
Whatup?
Old 11-02-2004, 11:12 AM   #11
crioten
"buddy jesus"
crioten's Avatar
crioten is making a name for him/her selfcrioten is making a name for him/her self
Send a message via AIM to crioten
ever see those turbo drag cars? they have the compressor usually mounted directly to a hole in the bumper...
it makes sense to use that kind of setup on a dyno or a drag car....but street driving is just dumb
IMG exceeds forum limit of 150kb
Originally Posted by Var
I'd rather take the bus with a bus-full of AIDS infected naked rape convicts than drive a VW.
crioten is offline   Reply With Quote
Old 11-02-2004, 11:37 AM   #12
import_racer87
thanks for the explanation guys, yea i guess i could see if you had a drag car that you rebuild all the time, but doing that on a street car would be so stupid.
Old 11-02-2004, 11:47 AM   #13
the head
the head's Avatar
correct man no real street use for the filter delete unless you can afford to replace rebuild stuff rather often
