Old 05-02-2015, 02:37 AM   #1
Ljensen11
Ljensen11 is an unknown quantity at this point
NEED HELP sr20det surges in hard acceleration into 2nd
So when ever i power shift into 2nd or try to do a 2nd gear burnout it surges and dies out anyones have any ideas on what it could be i know i dont have the bov hooked up but not sure if that matters heres what its doing https://www.youtube.com/watch?v=z26IuExZPgc
Ljensen11 is offline   Reply With Quote
Old 05-02-2015, 04:41 AM   #2
cotbu
cotbu's Avatar
Make more power, or keep your revs up!
The choice is yours!
Sent from a Highly Tuned Note 4.5!!!
Old 05-02-2015, 07:06 AM   #3
OnTheChip
OnTheChip's Avatar
OnTheChip is an unknown quantity at this point
Sounds like it might be hitting the overboost rev limiter. What ECU are you running?
OnTheChip is offline   Reply With Quote
Old 05-02-2015, 09:21 AM   #4
Ljensen11
Running stock 62 series se ecu and it has enough power just won't let me do it just surges out
Old 05-02-2015, 01:26 PM   #5
cotbu
cotbu's Avatar
After you dump the clutch you need to keep the revs up by blipping the throttle. If your just mashing the throttle to the floor, you'll need to make more power.
I can't really see what's happening, but that's what I hear. A failed attempt at a 2nd gear burnout!
From a Highly Tuned Note 4.5!!!
Old 05-03-2015, 05:03 PM   #6
Ljensen11
It does this going on the highway too
Old 05-03-2015, 05:27 PM   #7
cotbu
cotbu's Avatar
Wide band afr, fuel pressure readings?
Pull codes clear codes, then start data logging see if you can pin point the problem, knock sensor code or cas code is my guess for codes.
Old 05-04-2015, 06:51 AM   #8
ngbusyders
ngbusyders is an unknown quantity at this point
ngbusyders is offline   Reply With Quote
