Old 11-04-2004, 12:03 PM   #1
HyperTek
question about smog test cali...
Real quick, my 84 ford ranger only fails on HC (PPM) reading on smog test... what does HC mean? It didnt fail by much, just wondering if a seafoam treatment is worth it becuase I just did it to my s13 and it helpd big time..
Keep it Classy
Old 11-04-2004, 12:28 PM   #2
Ritz S14
Ritz S14's Avatar
HC = Hydro Carbons also known as incomplete combustion
What are your exact readings for HC/CO/NOX for the 15 and 25mph test? and what city are you in?
Ritz S14 is offline   Reply With Quote
Old 11-04-2004, 12:44 PM   #3
HyperTek
readings are as follows
15mph 136 Max 136 Measured
24mph 108 Max 113 Measured
Im in riverside.
Keep it Classy
Old 11-04-2004, 12:54 PM   #4
Ritz S14
Ritz S14's Avatar
Check spark plugs, make sure your CAT is super hot, and pour in some premium octane or fuel injector cleaner.
Old 11-04-2004, 05:26 PM   #5
91rusty240sx
91rusty240sx's Avatar
91rusty240sx is on a distinguished road
change your oil and air filter, might wanna change your fuel filter while your at it. make sure your cat is really hot, so drive it hard around the block a couple of times right before the tech brings it in to test.
if you do use seafoam, youll probably want to change your spark plugs afterward.
Tony
91rusty240sx is offline   Reply With Quote
Old 11-04-2004, 10:29 PM   #6
RiversideS13
RiversideS13's Avatar
RiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond reputeRiversideS13 has a reputation beyond repute
Send a message via AIM to RiversideS13
I know a place at san bernadino (near loma linda) will make it pass for $200-$250
but i think you can just simply improve it by adjust the timing
RiversideS13 is offline   Reply With Quote
