Old 06-05-2015, 12:31 AM   #1
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
SOHC performance! JWT ECU, crank pulley, Injen intake
Jim Wolf ECU
This is a JWT ECU for a SOHC S13. I JUST pulled it out of my PERFECTLY running S13 so it has NO ISSUES. It is only tuned as an upgrade for the stock engine, but JWT can re-tune it for about $100. This would be perfect for someone building a turbo SOHC. Also, this is a federal ECU so it will not set an EGR DTC. As it is on a stockish engine it's still a very nice upgrade. Improved throttle response, a bit more power, and it still passes smog.
SOLD!
SOHC ASP crank pulley
This is an ASP crank pulley for a SOHC KA. The pulley is in great shape, only small marks on the backside from removing it. It does underdrive the water pump and alternator. It is also sleeved for the crankshaft seal so it won't wear and leak. Altogether this is a REALLY nice pulley, I wish it worked on a dualcam...
$60
SOHC Injen intake
This is a COMPLETE Injen intake system for a SOHC KA. EVERYTHING you need is included, just bolt it in and go. Also included is a custom bracket if you do not have the stock fan shroud. You would need to get a rubber mounting bushing or put together a spacer arrangement to mount the bracket though as I re-used the mount bushing on my dualcam intake.
$100
Old 06-05-2015, 07:34 PM   #2
racepar1
racepar1's Avatar
Bump........
Old 06-05-2015, 08:18 PM   #3
ka24epacer
ka24epacer's Avatar
ka24epacer is an unknown quantity at this point
ones you interested in the ecu if JWT can really re-tune it
ka24epacer is offline   Reply With Quote
Old 06-05-2015, 11:07 PM   #4
racepar1
racepar1's Avatar
I contacted JWT directly with pictures of the rom chip to verify it was theirs and they told me it can be re-tuned for about $100. I think I still have the e-mails even.
Old 06-06-2015, 06:17 PM   #5
Apex Eight
Apex Eight is an unknown quantity at this point
PM sent. Interested
Apex Eight is offline   Reply With Quote
Old 06-08-2015, 01:21 PM   #6
ka24epacer
ka24epacer's Avatar
Pm sent about jwt ecu will PayPal you this afternoon when I get home from work
Old 06-08-2015, 09:18 PM   #7
racepar1
racepar1's Avatar
Bump........
Old 06-09-2015, 09:00 PM   #8
ka24epacer
ka24epacer's Avatar
Paypal sent for jwt ecu thanks for the patience!
Old 06-10-2015, 03:39 AM   #9
newkid99
newkid99 is an unknown quantity at this point
Just wondering, KA motors both sohc and dohc have the same crank / short block right? why would the pully not work with a dual cam KA?
newkid99 is offline   Reply With Quote
Old 06-10-2015, 11:52 PM   #10
green_bullet
green_bullet is an unknown quantity at this point
I see your in simi, I live in the sfv and can probably swing by on Friday or the weekend and pick up the crank pulley. Not sure what day/time would be best.. Pm me
green_bullet is offline   Reply With Quote
Old 06-11-2015, 12:31 AM   #11
racepar1
racepar1's Avatar
The timing marks are in a different spot, opposite sides of the timing cover. You could bolt it on, but you couldn't ever set your timing again.
Will do...
Old 06-12-2015, 09:04 PM   #12
racepar1
racepar1's Avatar
Bump........
Old 06-15-2015, 10:46 PM   #13
racepar1
racepar1's Avatar
Bump........
Old 06-16-2015, 10:49 PM   #14
ka24epacer
ka24epacer's Avatar
Thanks for the ecu just received it!!
Free bump legit seller!
Old 06-19-2015, 10:56 PM   #15
racepar1
racepar1's Avatar
Bump, intake and pulley still available...
