Old 11-02-2004, 10:25 AM   #1
jedc
jedc is an unknown quantity at this point
Send a message via AIM to jedc
help me with 5speed swap
I have a 98' automatic motor that I am putting in my 5speed S13. I am trying to remove the brass ring where the pilot bearing would go..this ring is not found on 5speed cars. I've tried a slide hammer but it doesn't have anything to really grip onto..If anyone has any ideas, I would love to hear them...I want to get my s13 on the road =(
jedc is offline   Reply With Quote
Old 11-02-2004, 10:27 AM   #2
jedc
Old 11-02-2004, 10:31 AM   #3
Jeff240sx
I hate you too...
Jeff240sx's Avatar
WTF is that? Why did you post a picture??
You need a pilot bearing removal tool, and a slide hammer. Then you need to get in behind the bearing, and open that tool up as much as possible. Like have a friend open it with a wrench while you hold. Then use the slide hammer. If that really doesn't work (and it does), you can use a pipe wrench. I don't suggest it.
And 5-speed cars do have the pilot bearing, but it's shorter. You need to install a manual pilot bearing after removing the automatic one.
-Jeff
Whatup?
Old 11-02-2004, 10:33 AM   #4
Eternal_240Sx
Eternal_240Sx's Avatar
Eternal_240Sx is making a name for him/her selfEternal_240Sx is making a name for him/her self
Are you talking about the donut ring right at the edge of the crankshaft? On my SR I had a problem with grip too, but what i did is use the hammer but dont slide the hammer too hard or it will keep slipping. Keep it as small tapping hits. Mine came right out.
Eternal_240Sx is offline   Reply With Quote
Old 11-02-2004, 02:54 PM   #5
jedc
-Jeff
I posted the picture so you could see what the fuck I was talking about..
What I highlighted wasn't the pilot bearing--the pilot bearing goes inside of that brass ring. There is little, if any, grooves inside of that ring and a slide hammer can't catch them..
I tried a pipe wrench but that didn't work either..
Old 11-02-2004, 10:43 PM   #6
TheSnail
TheSnail's Avatar
TheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to allTheSnail is a name known to all
Just like Jeff said. Use a Slide hammer. Not slide the hammer, what ever that means. For a slide hammer, you can get the peice for the end that is a three peice hook. My friend just got his out from using that, and the last one he and his friend did, they did not have the tool so they tack-welded a piece of metal to it, yanked it out (that worked well to).
TheSnail is offline   Reply With Quote
Old 11-05-2004, 08:17 PM   #7
jedc
Exclamation
Guys, I really need your help. I tried using the slide hammer with the pilot bearing remover and there is only a tiny lip for it to grab. Mine wouldn't really grab at all after tightening it as much as I could with wrenches. For clarification I am not removing the pilot bearing, it's the donut ring thing that only automatics have on the end of the crank. Since I couldn't get the slide hammer to work I sawzalled some slits in it to try and knock it with a flathead or something but that wouldn't work either. Anyone have suggestions? I couldn't find any other tools at autozone that would do the job with the slide hammer either.
Old 11-06-2004, 04:57 PM   #8
syco3d
syco3d's Avatar
syco3d is an unknown quantity at this point
Send a message via AIM to syco3d Send a message via Yahoo to syco3d
My post was a bunch of crap, and I couldn't remove it, so this is what u get.
Gimme a "A"!
Gimme a "P"!
Gimme a "C"!
What does that spell?
CRAP!
syco3d is offline   Reply With Quote
Old 11-07-2004, 09:02 AM   #9
270R
270R's Avatar
270R is a glorious beacon of light270R is a glorious beacon of light270R is a glorious beacon of light270R is a glorious beacon of light270R is a glorious beacon of light270R is a glorious beacon of light270R is a glorious beacon of light270R is a glorious beacon of light270R is a glorious beacon of light270R is a glorious beacon of light270R is a glorious beacon of light
Try using grease, a bolt the size of the pilot bearing and a hamma...er.. then eyyyy
270R is offline   Reply With Quote
Old 11-07-2004, 09:10 AM   #10
crioten
"buddy jesus"
crioten's Avatar
crioten is making a name for him/her selfcrioten is making a name for him/her self
Send a message via AIM to crioten
ummm yeah...wtf is that a picture of? it just looks like some random 3d object found on the net lol
IMG exceeds forum limit of 150kb
Originally Posted by Var
I'd rather take the bus with a bus-full of AIDS infected naked rape convicts than drive a VW.
crioten is offline   Reply With Quote
Old 11-07-2004, 09:19 AM   #11
jedc
I tried the grease trick many times. It was a picture of the automatic pilot converter.
Old 11-07-2004, 09:24 AM   #12
270R
270R's Avatar
I tried ...lol hehe
Old 11-07-2004, 09:26 AM   #13
270R
270R's Avatar
then get a bearing puller..
Old 11-07-2004, 10:58 AM   #14
KoukiMonster
KoukiMonster's Avatar
KoukiMonster can only hope to improve
http://www.son240sx.ca/forums/viewto...964b836829ddb5
KoukiMonster is offline   Reply With Quote
Old 11-07-2004, 06:26 PM   #15
jedc
Originally Posted by KoukiMonster
Thanks...but there was nothing relevant to my question on that thread.
My car is already manual just that the new motor was from an auto.
I will just try the slide hammer again and see how that goes. If not, the
sawzall will finish it up.
Old 11-07-2004, 07:35 PM   #16
phase12048
phase12048 is an unknown quantity at this point
I've got the same exact problem. I feel your pain I worked on trying to get out the bearing for 4 hours already
phase12048 is offline   Reply With Quote
