Old 06-16-2015, 02:03 AM   #3331
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
godrifttoday is an unknown quantity at this point
Feedback Score: 82 reviews
Rpf1 18.5 , 305 rear with 30mm any pictures? Or similar
NEED Bolt kits for your car?
http://i48.tinypic.com/6gx5e0.jpg
godrifttoday is offline   Reply With Quote
Old 06-16-2015, 07:58 AM   #3332
Ilya
Ilya's Avatar
Ilya is an unknown quantity at this point
^What?! And no
Ilya is offline   Reply With Quote
Old 07-16-2015, 04:54 PM   #3333
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
So ive picked up a set of Super Advan Generation 2s that are 17x8.5 +30 and 17x9.5 +38.
question 1: ive never run wider wheels with higher offsets (without running 25mm spacers). im thinking the rears will clear the coils, but the fronts im pretty sure are going to wind up rubbing the springs. anyone have experience with these sizes/offsets? im currently running Fortune Auto V4 coils that have the eccentric adapters on the top holes of the brackets.
question 2: im not going for the hella flush look, but if i do add spacers, i would like to push the wheels out just a bit so they sit flush with the fenders (not super low). im thinking 15mm bolt on spacers, i want to keep a good amount of tire on these with minimum stretch. any input on good tire sizes to run. i was planning on 225/40R17 upfront and 245/40/R17 out back. my rear fenders are rolled and not pulled. front fenders are untouched.
please no flaming, im new to the proper fitting tire world and i need to get the tires ordered next week as the wheels are showing late next week i believe. any positive input would be appreciated
Old 07-16-2015, 05:25 PM   #3334
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
You can usually fit 9 +25 on the front, which has pretty much the same inner clearance. http://www.1010tires.com/Tools/Wheel-Offset-Calculator
245s all around is no sweat with some camber.
e1_griego is offline   Reply With Quote
Old 07-17-2015, 12:33 AM   #3335
gawdzilla
gawdzilla is an unknown quantity at this point
attempting to fit BFG R1S 275/35/18 (wide for the listed width) for this weekend on my time trial s14. rim is NT03 18x9.5+27.
front with 10mm spacer. very slight rub on spring, probably need a 12-15mm spacer. front fender is rolled but not pulled. going to need to pull it to clear. havent worked on it yet
rear no spacer, shock disconnected at the lower mount to simulate maximum travel. ignore the rubber marks, those wipe away. very slight rub on the fender after doing some pulling with the eastwood roller. plenty of room to go on the inside, but the wheels i got are too low offset. probably need another 3mm of fender pull:
original sized pics here: http://i.imgur.com/XRQFhHO.jpg and here: http://i.imgur.com/RIRzil2.jpg
gawdzilla is offline   Reply With Quote
Old 07-17-2015, 07:02 AM   #3336
DRFT180
DRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud of
I have a set of Panasport G7 C5C2's that are similar sizes
17x8.5 +38 Front 245/40/17 Added a 30mm spacer (effective +8)
17x9.5 +40 Rear 255/40/17 Added a 20mm spacer (effective +20)
Wheels sat perfect in my opinion. Front fenders are rolled flat and the rears have a slight pull. Front camber at -3.2, rear camber at -1.2
S14 Build
DRFT180 is offline   Reply With Quote
Old 07-17-2015, 09:29 AM   #3337
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
^^^ doesnt really do me a lot of good for fitment given you have an S14 and im running an S13... but i appreciate the pics for the tire sizes. i think i may try 235 upfront and 245 in the rear.
Old 07-17-2015, 10:01 AM   #3338
silviaks2nr
silviaks2nr's Avatar
This thread is disappointing now Where's all the 275+ rears!
Old 07-17-2015, 10:12 AM   #3339
CornSpeed
CornSpeed's Avatar
CornSpeed is an unknown quantity at this point
Seconded!!!!
CornSpeed is offline   Reply With Quote
Old 07-17-2015, 01:49 PM   #3340
jr_ss
I've got em'.
Old 07-17-2015, 01:53 PM   #3341
CornSpeed
CornSpeed's Avatar
Now I just need to save up some cash for wheels so I can run the same specs as Broadfield. It will happen.
Old 07-17-2015, 02:01 PM   #3342
RalliartRsX
Trader Rating: (32)
RalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfectionRalliartRsX is close to perfection
Feedback Score: 32 reviews
Chassis: S14
Wheels: 17x9.5 RPF1 + 38. Fronts rubbed and needed a spacer and camber, which was a paltry 1.2 at the time when this picture was taken. Rear clears by a country mile!
Tires: 275-40-17 NT05
RalliartRsX is offline   Reply With Quote
Old 07-19-2015, 08:01 AM   #3343
jr_ss
Damn that thing is low for those meats Ralliart. I'm assuming you have a 245/255 up front? What are your alignment specs in the rear?
Old 07-19-2015, 08:40 AM   #3344
Kuma
Kuma's Avatar
Kuma is an unknown quantity at this point
for a 9.5, more like 265-275.... I also have an s14, so I can't help give you a definitive answer on the fitment, but be ready to do a slight pull... probably about 5-10mm.
Kuma is offline   Reply With Quote
Old 07-19-2015, 11:14 AM   #3345
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
Back in 2006, I had the following on my S13 with nothing more than a roll. The fronts were VERY close to hitting the coil, but they DID clear... you will obviously have an additional 2mm of clearance up front. I did not have the car near as low as I do now though:
18×8.5 +32 245/40
18×10 +44 275/35
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
Old 07-19-2015, 02:35 PM   #3346
dorkidori_s13
ITS LISA'S FAULT!!!
Trader Rating: (41)
18×8.5 +32 245/40
18×10 +44 275/35
i was definitely using your car as a point of reference for what tire size to run for sure! i think initially im going to try 235 up front and 255 out back to see how that works. i need the wheels to get here first though to check clearance and all that jazz. cant move forward with tires until that happens ive seen various people say that Fortunes have clearance issues with anything under +25, but none of them have messed with the eccentric adapters in their upper mounts yet sooooooo... wont know til the wheels are here and on the car.
Old 07-20-2015, 06:11 AM   #3347
Skilz10179
Skilz10179 is an unknown quantity at this point
Last time I posted pics of my 275's here I was told they weren't wide enough for this thread...
Skilz10179 is offline   Reply With Quote
Old 07-20-2015, 06:40 AM   #3348
Reddrum13
Reddrum13's Avatar
Reddrum13 is an unknown quantity at this point
255/40/17 on a 9 +22
275/40/17 on a 10 +38
Reddrum13 is offline   Reply With Quote
Old 07-20-2015, 07:42 AM   #3349
RalliartRsX
Trader Rating: (32)
275-40 on BOTH ends in that picture. Front fenders are rolled with very "paltry" camber on front and rear.
Now, remember, some tires run wide and some run narrow. The NT05 run a bit narrow. Comparing my 265-40 Direzzas ZII Star Spec to the 275-40 Nitto NT05, the section width nod goes to the Star Specs although by definition, they should be 10mms NARROWER.
I think this went a long way in getting 275s to fit on the front of a S14 chassis without minimal modifications.
Old 07-20-2015, 07:52 AM   #3350
DRFT180
Well, On my S13 I've run a 255/40/17 RS-3 all the way around on 17x9.5 +18 RPF-1's. Front fenders were rolled flat, rears were pulled a little. You shouldn't have any problem fitting a 235/245.
I personally would go with a 245/255 and roll the fenders all around. You'll need a spacer up front.
S14 Build
Old 07-20-2015, 08:08 AM   #3351
tuzzio
tuzzio's Avatar
Currently running 18x9.5 +12 235/40 in the rear of my coupe.
The same wheel is offered in 10.5 +22, Considering these will only poke 2mm more...Im contemplating pulling the trigger and going with a 255/35. Anybody have a similar set up?
Old 07-20-2015, 10:26 AM   #3352
silviaks2nr
You must have over fenders
Old 07-20-2015, 02:06 PM   #3353
Yellow4g63
Yellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of lightYellow4g63 is a glorious beacon of light
Send a message via AIM to Yellow4g63
It was prob a 12" wide rim so he stretched the tire on it lol.
95 240sx RB20 415whp
91 Nx2000 VVL yo
Yellow4g63 is offline   Reply With Quote
Old 07-22-2015, 04:15 AM   #3354
Skilz10179
Nope, stock body, rolled and pulled.
It was 11" wide wheels, very mild stretch, nothing stupid...
Old 07-22-2015, 06:43 AM   #3355
Kuma
Kuma's Avatar
[img]ht9019576325_57b22ba506.jpg[/i
[img]https://farm1.staticflickr.com/32/19014697692_82ecb8d174.jpgg]
[img]https://farm1.staticflickr.com/41/18399527783_226bc348c9.jpgg]
you have any rubbing issues on the front when turning?
that doesn't constitute as max tire for your wheels. stretching tires is not max rubber.
Old 07-22-2015, 06:54 AM   #3356
Reddrum13
Reddrum13's Avatar
Nope! Also haven't driven the car yet... but rolling it around I have not rubbed any.
Old 07-22-2015, 05:41 PM   #3357
Broadfield
Broadfield's Avatar
So by that logic, an S13 with a 7" and a 225 would be max fitment!?! I look at this thread being about max tire fitment for the car, not the wheel.
I'm running an 11" with a 285... yes, it's "slightly" stretched. But I'm running a 285 on a fairly low, stock sheet metal S13. If that doesn't count for maximum tire, then I don't know what does.
You can argue it either way, I just choose this way
My Portfolio
Please Share
Check Out My Builds
Old 07-27-2015, 02:39 PM   #3358
Sumslapper
Sumslapper's Avatar
Sumslapper is an unknown quantity at this point
295/30/18 on 18x11 SSR sp1. I think they look cool, but I've swayed to go towards a slight stretch to reduce sidewall flex.
Sumslapper is offline   Reply With Quote
Old 07-27-2015, 03:41 PM   #3359
silviaks2nr
295/30 is perfect for 18x11
Old 07-27-2015, 04:01 PM   #3360
Broadfield
Broadfield's Avatar
Yeah, I sure as hell wish I could fit 295's.
My Portfolio
Please Share
Check Out My Builds
